graphics card help
dransy
PostPosted: 20:45 - 07 Mar 2010    Post subject: graphics card help Reply with quote
Im after a new card but i dunno what card will fit my board?
my motherboard is an asus A7N8X-X 5 PCI,1AGP
and my current g card is a radeon x800 pro256mb
How do i find out what other cards will fit my board?
thanks
L3G3ND_MTX
PostPosted: 20:54 - 07 Mar 2010    Post subject: Reply with quote
By the sounds of it you have quite an old out-dated mother board that only takes AGP cards, so anything AGP will fit just make sure your power supply unit can handle it aswell (should be labled the wattage on the back) almost all graphics cards now-a-days are pci-e (express).
Simple answer find any graphics card that will fit an AGP slot.
dransy
PostPosted: 20:58 - 07 Mar 2010    Post subject: Reply with quote
hey thanks https://www.cclonline.com/product-categories.asp?category_id=125 so are they the kinda cards that would fit?
L3G3ND_MTX
PostPosted: 21:03 - 07 Mar 2010    Post subject: Reply with quote
Yes they will fit, like i said check what power supply it needs and make sure you have enough, if it requires 500w and you only have 500w be very carefull because you will be running at max load constantly with it if i remember correctly.
Also best thing to check is the clock speeds on them there could be a 50gb graphics card with a 300mhz clock speed and a 500mb graphics card with 500mhz and the 500mb will work better, clock speeds are everything don't just see a 1gb card and be like oooo lots of memory.
Hope this helps.
dransy
PostPosted: 21:52 - 07 Mar 2010    Post subject: Reply with quote
Arrgghhh this is so confusing
Can anyone recommend a card!?
Its mainly for wow
these are the requirements on the wow website
Minimum: 3D graphics processor with Hardware Transform and Lighting with 32 MB VRAM Such as an ATI Radeon 7200 or NVIDIA GeForce 2 class card or better
Recommended: 3D graphics processor with Vertex and Pixel Shader capability with 128 MB VRAM Such as an ATI Radeon X1600 or NVIDIA GeForce 7600 GT class card or better
But my boards agp as above can anyone recommend something?
im presuming i dont really need a hd card either?
neil.
PostPosted: 21:56 - 07 Mar 2010    Post subject: Reply with quote
Out of interest, have you tried WoW on your current card to see how it runs?
dransy
PostPosted: 22:00 - 07 Mar 2010    Post subject: Reply with quote
yeah i have been playing for ages .
im lucky to see over 15fps, in the newer parts in the latest expansion im lucky to get over 5!
Neorion
PostPosted: 10:07 - 08 Mar 2010    Post subject: Reply with quote
A 6800Gt is a good card I am sure they were models you could buy both AGP and pci-e but finding one new might be a different story.
What processor do you have? It may be cheaper to get a cheap mobo and a mid range ATI card.
This is only £220, you would still need a card but its a good starting point and from what you using now it would last a while.
https://www.overclockers.co.uk/showproduct.php?prodid=BU-029-OE
VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google"
MarkJ
PostPosted: 10:50 - 08 Mar 2010    Post subject: Reply with quote
Loads of AGP cards here: clicky
dransy
PostPosted: 13:17 - 08 Mar 2010    Post subject: Reply with quote
i got a ASUS RADEON HD3450 for 30squid
600mhz clock speed too and 512 mb
The last post was made 16 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 16 - Page Size: 68.13 Kb
