| Aleks |
 Aleks Two Stroke Sniffer
 Posted: 23:38 - 07 Mar 2010 Post subject: TZR 125 1990... Does it have a powervalve? |
Hi guys, I'm not particularly good at the whole bike engineering thing but I'm giving it my best
Basically I've got a 19 year old TZR with only 20k miles on the clock, I'm just basically cleaning the spark plug when suddenly I think "Why not go the whole hog and clean the engine! Seeing as it's never been cleaned it can't hurt, I'll even Derestrict it while I'm there!
Now... I've been doing a lot of googling and youtubing and I've gathered the powervalve is controlled by a servo... I'm fairly sure my bike doesn't have a servo, it's kickstart for gods sake
Here's a picture of the engine, I really can't see where the powervalve would go or if it even has one... The bike's code is 3PC2 if that helps
https://photos-b.ak.fbcdn.net/hphotos-ak-snc3/hs406.snc3/24600_348491675891_584260891_3798845_4396487_n.jpg
Thanks in advance
-Aleks |
| Aleks |
 Posted: 23:39 - 07 Mar 2010 Post subject: |
Oh yeah if you're wondering, the kickstart did snap off  |
| Fortuna |
 Fortuna World Chat Champion
| Aleks |
 Posted: 23:57 - 07 Mar 2010 Post subject: |
Thanks Tomorrow after college I'll open it up and take a picture
Cheers mate |
| Billing |
 Billing World Chat Champion
 Posted: 00:34 - 08 Mar 2010 Post subject: |
| Fortuna wrote: | If it is, it will be where I've circled.
Looks like it hasn't got one though, no cables or motor. |
the PV stuff is on the other side just because there's no cables or motor doesn't mean its not got one, on the contrary it's almost certainly got one, it'll just be fixed in one position.
Theres 2 ways to derestrict it as such.
1) turn the PV to the fully open position, low end power will be down, but you'll get more power at the top end.
2) find and fit a servo motor. you'll need the pulley, the housing and either the servo and control box OR a 4dl servo, this has the control box embedded in it already.
my one is soon to get a motor, it's coming after the USD front end ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| Bikeless |
 Bikeless World Chat Champion
| Fortuna |
| Aleks |
 Posted: 23:12 - 08 Mar 2010 Post subject: |
Sweet I've put the valve to open. Wide open.
I wonder, does this now require a rejet?
Also, if I half opened it, would I get the performance increase be equal in all ranges, or would my engine just explode?
Cheers guys, you're a great help  |
 Posted: 09:27 - 09 Mar 2010 Post subject: |
Not sure on the jetting, but don't think they need rejetting. The Yamaha manual didn't list any different jetting for UK restricted and non UK full power models (although it does for the Swiss market ones).
Turning the power valve part of the way would probably lose you some low down power and gain you a bit of top end power. But I wouldn't really expect it to be a good compromise (fairly sure in use the valve is just open or shut).
You need to turn the valve so the flat lines up with the top of the exhaust port in the cylinder. I think that the power valve adjustment holes are lined up when the valve is in the fully open position. As such if you have the pulley wheel then you should be able to put a pin in (4mm diameter) to the adjustment holes to lock it in the open position.
| Aleks |
 Posted: 10:42 - 09 Mar 2010 Post subject: |
Thanks man, I'll keep that in mind, I'm considering doing some googling and/or ebaying and finding a powervalve servo and cables, I did a bit of looking last night and found one PV servo but the guy wants £60... Definately not worth the price. I'll just hunt around and find a servo and cables second hand for like £20.
Would my idea work though? I mean Yam made the bikes with the servo and everything, then took it off and bolted it shut for sale in the UK?
(I could be wrong on that, correct me if I am)
I like the idea of re-powering the power valve  |
| ben350 |
 ben350 Trackday Trickster
 Posted: 19:03 - 10 Mar 2010 Post subject: |
£60 is a fair price mate, I paid £75 delivered for one for my 125R as I couldnt be arsed riding to work on a light switch engine. You will find the early TZR YPVS servo very hard to come by as they were never officially sold here and if I remember correctly no TZR125 shaped like yours had a servo in the UK. Make sure you get the same number of wires on your wiring loom - the DT has 2 different servo's so you might find TZR's are the same  ____________________ Ducati 996 Biposto
Suzuki Goose 350
DT125R Supermoto (Project) |
| Vincent |
 Vincent Banned
 Posted: 19:20 - 10 Mar 2010 Post subject: |
Are the TZR servo and controller the same as the RD125LC (1GU)  |
 Posted: 20:26 - 10 Mar 2010 Post subject: |
The servos were available in the UK, but only (in theory) if you could prove you had a full licence. Suspect they were readily available in Northern Ireland (250 learner law in NI at the time, and the RD125, AR125 and a few others were sold in full power form).
Servo might well be the same as the late RDZ125LC (but then UK ones of those didn't have the power valve servo fitted either).
The last post was made 15 years, 350 days ago. Instead of replying here, would creating a new thread be more useful? |
