TZR 125 1990... Does it have a powervalve?
Aleks
PostPosted: 23:38 - 07 Mar 2010    Post subject: TZR 125 1990... Does it have a powervalve? Reply with quote
Hi guys, I'm not particularly good at the whole bike engineering thing but I'm giving it my best Smile
Basically I've got a 19 year old TZR with only 20k miles on the clock, I'm just basically cleaning the spark plug when suddenly I think "Why not go the whole hog and clean the engine! Seeing as it's never been cleaned it can't hurt, I'll even Derestrict it while I'm there!
Now... I've been doing a lot of googling and youtubing and I've gathered the powervalve is controlled by a servo... I'm fairly sure my bike doesn't have a servo, it's kickstart for gods sake Razz
Here's a picture of the engine, I really can't see where the powervalve would go or if it even has one... The bike's code is 3PC2 if that helps
https://photos-b.ak.fbcdn.net/hphotos-ak-snc3/hs406.snc3/24600_348491675891_584260891_3798845_4396487_n.jpg
Thanks in advance
-Aleks
Aleks
PostPosted: 23:39 - 07 Mar 2010    Post subject: Reply with quote
Oh yeah if you're wondering, the kickstart did snap off Razz
Fortuna
PostPosted: 23:55 - 07 Mar 2010    Post subject: Reply with quote
If it is, it will be where I've circled.
Looks like it hasn't got one though, no cables or motor.
Aleks
PostPosted: 23:57 - 07 Mar 2010    Post subject: Reply with quote
Thanks Smile Tomorrow after college I'll open it up and take a picture Razz
Cheers mate
Billing
PostPosted: 00:34 - 08 Mar 2010    Post subject: Reply with quote
the PV stuff is on the other side Wink just because there's no cables or motor doesn't mean its not got one, on the contrary it's almost certainly got one, it'll just be fixed in one position.
Theres 2 ways to derestrict it as such.
1) turn the PV to the fully open position, low end power will be down, but you'll get more power at the top end.
2) find and fit a servo motor. you'll need the pulley, the housing and either the servo and control box OR a 4dl servo, this has the control box embedded in it already.
my one is soon to get a motor, it's coming after the USD front end
PostPosted: 18:44 - 08 Mar 2010    Post subject: Reply with quote
UK ones were restricted by leaving out the servo and control unit for the power valve, leaving it in the low rev position.
Bikeless
PostPosted: 18:49 - 08 Mar 2010    Post subject: Reply with quote
When i was a kid you just took the powervalve out and turned it around so it worked at high revs but you lose low/mid range.
Fortuna
PostPosted: 21:50 - 08 Mar 2010    Post subject: Reply with quote
Exactly,
how was I wrong lol.
Aleks
PostPosted: 23:12 - 08 Mar 2010    Post subject: Reply with quote
Sweet Smile I've put the valve to open. Wide open.
I wonder, does this now require a rejet?
Also, if I half opened it, would I get the performance increase be equal in all ranges, or would my engine just explode?
Cheers guys, you're a great help Smile
PostPosted: 09:27 - 09 Mar 2010    Post subject: Reply with quote
Not sure on the jetting, but don't think they need rejetting. The Yamaha manual didn't list any different jetting for UK restricted and non UK full power models (although it does for the Swiss market ones).
Turning the power valve part of the way would probably lose you some low down power and gain you a bit of top end power. But I wouldn't really expect it to be a good compromise (fairly sure in use the valve is just open or shut).
You need to turn the valve so the flat lines up with the top of the exhaust port in the cylinder. I think that the power valve adjustment holes are lined up when the valve is in the fully open position. As such if you have the pulley wheel then you should be able to put a pin in (4mm diameter) to the adjustment holes to lock it in the open position.
Aleks
PostPosted: 10:42 - 09 Mar 2010    Post subject: Reply with quote
Thanks man, I'll keep that in mind, I'm considering doing some googling and/or ebaying and finding a powervalve servo and cables, I did a bit of looking last night and found one PV servo but the guy wants £60... Definately not worth the price. I'll just hunt around and find a servo and cables second hand for like £20.
Would my idea work though? I mean Yam made the bikes with the servo and everything, then took it off and bolted it shut for sale in the UK?
(I could be wrong on that, correct me if I am)
I like the idea of re-powering the power valve Razz
PostPosted: 11:46 - 09 Mar 2010    Post subject: Reply with quote
For the UK market they left the servo and control unit off. They were available as extras from Yamaha if you had a full licence, but few people bought them and they are as rare as hens teeth now (hence they cost a fortune to buy when they occasionally turn up 2nd hand).
ben350
PostPosted: 19:03 - 10 Mar 2010    Post subject: Reply with quote
£60 is a fair price mate, I paid £75 delivered for one for my 125R as I couldnt be arsed riding to work on a light switch engine. You will find the early TZR YPVS servo very hard to come by as they were never officially sold here and if I remember correctly no TZR125 shaped like yours had a servo in the UK. Make sure you get the same number of wires on your wiring loom - the DT has 2 different servo's so you might find TZR's are the same Wink
Ducati 996 Biposto
Suzuki Goose 350
DT125R Supermoto (Project)
PostPosted: 20:26 - 10 Mar 2010    Post subject: Reply with quote
The servos were available in the UK, but only (in theory) if you could prove you had a full licence. Suspect they were readily available in Northern Ireland (250 learner law in NI at the time, and the RD125, AR125 and a few others were sold in full power form).
Servo might well be the same as the late RDZ125LC (but then UK ones of those didn't have the power valve servo fitted either).
The last post was made 15 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 88.13 Kb
