Honda x8r intake manifold
The Artist
PostPosted: 16:07 - 07 Mar 2010    Post subject: Honda x8r intake manifold Reply with quote
Tube coming off the intake manifold to a sealed black plastic box.
What is this for? Ped won't idle unless I remove the tube to breath fresh air and it then revs quite high.
air/fuel mix screw is fully in for some reason
spark plug is perfect colour
idle screw is fully in.
Dies as soon as I cover this tube. It is quite a big 10mm ID rubber tube.
cb1rocket
PostPosted: 00:15 - 08 Mar 2010    Post subject: Reply with quote
tube to black platstic box is air filter
pilot screw should not be fully in, this will cut off the fuel basically with just air. Resulting in a lean mixture.
screw this out by 2 - 3 turns from stop
Leave the tube off and start bike .
If it runs then the mixture was buggered and the air filter is blocked or filter needs replacing.
It may run very high idle as the screw is right in! Adjust the idle screw out till it ticks over nicely.
Tune the pilot screw until you can achieve the highest rpm then back out 1/2 a turn, then adjust idle screw until it ticks over ok.
The Artist
PostPosted: 00:48 - 08 Mar 2010    Post subject: Reply with quote
Not the air filter. A separate rubber tube comes from the manifold to a completely sealed small black box on top of the air filter. It is confusing.
cb1rocket
PostPosted: 08:56 - 08 Mar 2010    Post subject: Reply with quote
on some hondas I have seen, its known as a secondary air filter system.
Yes it sounds confusing but did own one of the X8R-X. X being the moto crosser type.
Theres an S version just for info as the Sports model
truslack
PostPosted: 11:35 - 08 Mar 2010    Post subject: Reply with quote
Some sort of "boost bottle"?
The Artist
PostPosted: 17:23 - 08 Mar 2010    Post subject: Reply with quote
That is what i was thinking. It is a big tube going to a tiny 100% sealed box. Why does it rev high when this is off though? Is it running really lean making it rev?
truslack
PostPosted: 17:35 - 08 Mar 2010    Post subject: Reply with quote
Without the pipe it's sucking in more air between the carb and the head, like an air leak on the rubber, so will make it race.
The last post was made 16 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 50.68 Kb
