VFR400 Brakes, help needed
PostPosted: 12:38 - 09 Mar 2002    Post subject: VFR400 Brakes, help needed Reply with quote
My flate mate just 'serviced' the brakes on his VFR400 NC21, I think they're pretty similar to at least the early NSRs.
They did rub a bit, but now it's a load worse. It could be something to do with the previous owner replacing the discs a bit dodgily as it only rubs on one place per revolution. Someone else reconed it was probably the seals, any one got any ideas?
Korn
Admin
PostPosted: 16:55 - 09 Mar 2002    Post subject: Reply with quote
Take the discs off the wheel and reattach them, make sure you tighten all the retaining bolts to the same torque. If it still rubs it's probably a warped disc. You can get it straightened easily enough by seperating the rotor and holder and placing the bugger in a big press. Try your local breakers they should be able to press it flat for you for a few quid.
The last post was made 24 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 31.22 Kb
