FZR600 chain/tyres?
PostPosted: 15:32 - 08 Mar 2010    Post subject: FZR600 chain/tyres? Reply with quote
Anyone know what pitch/links the chain is on a 1989 FZR600 Genesis 3HE model.
Its one of the last things I need, along with an MOT and tax!
All in all been a quick, cheap and fun project! Just want to able to ride it out of the garden now!
Karma to someone who can get the info..
thank youuu! Thumbs Up
also a quick one, I ordered a rear wheel from egay as the original was...broken to say the least Laughing
Stock tyre is like 140/70-18 but one i recieved has a 160/60/18 on it, not alot of tread so its coming off anyway, but is it safe to buy that size and pop it on again?
Obviously it fits, but if its pointless i'll stick to the smaller rubber Thumbs Up
Paddy Blake
PostPosted: 15:59 - 08 Mar 2010    Post subject: Reply with quote
Check the side of the links that are on it for a number like 525.
The stock tyre should be cheaper.
PostPosted: 16:38 - 08 Mar 2010    Post subject: Reply with quote
I would..if it wasnt bright orange Razz
Im looking at the stock tyres, only about £20 in it.. just thinking whether its worth the larger tyre
PostPosted: 18:05 - 08 Mar 2010    Post subject: Reply with quote
I think yamaha would have invested £££££££ getting the handling set up on these bikes. I would trust that rather than the previous owners personal choice. It may be worth checking the rear wheel is the original though. Find the part number and google it.
PostPosted: 18:34 - 08 Mar 2010    Post subject: Reply with quote
Yeah the rear wheel is from the exact same year/model as mine.
Guy breaking the whole bike etc.
Vincent wrote:
Chain should be a 530, 160 links.
If that is so, then I shall buy one, reason i ask, I see the chain/sprocket sets, but my brother gets them in alot cheaper and gets different colours, me being a tart wants a purple/pink one to match Razz
PostPosted: 19:46 - 08 Mar 2010    Post subject: Reply with quote
Chain is a 530 with 106 links.
As to the tyre, depends what size the wheel is. Early bikes had a (from memory) 3.5" rim while the later ones had a 4" rim. 150 is about right for a 4" rim (140 tyre is stock, 150 a slightly over size fitment), but would probably be far too oversize for the narrower early rim (stock tyre for an early rim was a 130).
However it is difficult to find a 150/60 18 ZR rated rear tyre.
PostPosted: 20:01 - 08 Mar 2010    Post subject: Reply with quote
Yea the stock on i believe is a 140, thats easy enough to find, the 150 is hard but the 160 is in stock at local shop!
I can wait anyway, but is it alright to say get the 160 and put a 120 on front? they sell this as a set at the local shop.
Thanks re: the chain, 106 links? damn you Vincent Razz free karma anyway!
PostPosted: 20:08 - 08 Mar 2010    Post subject: Reply with quote
Not sure I would like to try a 120 on the front. It is a 3" front rim.
By the way, suspect if you did use a 160 on the rear then there might well be clearance problems. Clearance between the chain and a 150/60 BT010 on my FZR600 was less than 5mm.
PostPosted: 21:34 - 08 Mar 2010    Post subject: Reply with quote
ah ok, cant you usually go up a size without hassle?
thats why i thought a 120 would fit.
well worst comes to it, i'll buy them individually.
is a 150/60-18 a nice fit on the rear?
PostPosted: 21:43 - 08 Mar 2010    Post subject: Reply with quote
The size of tyre you can get away with is pretty much down to the rim width. Most of the time the makers don't run that close to the max you an get away with. But use too wide a tyre and it will be badly distorted and probably result in it handling like a pig.
If you have the 4" rim a 150/60 will fit fine. Although as far as I know the only ZR rated rear tyre in that size is the BT014.
PostPosted: 21:58 - 08 Mar 2010    Post subject: Reply with quote
do i need a ZR tyre?
PostPosted: 22:25 - 08 Mar 2010    Post subject: Reply with quote
Bike has a top speed a touch over 140mph. H rated tyres are only good for 130mph (and don't know of any V rated tyres in the right size).
Legally you are probably OK using H rated tyres in the UK, although our insurance company might take a dim view of it. Think in Germany it is illegal to have tyres with a speed rating not suitable for the max speed of the bike.
PostPosted: 22:27 - 08 Mar 2010    Post subject: Reply with quote
ouch.. im not likely to hit anything over 75...maybe 80.
already tempted fate, 8 crashes, 3 points...not really up for top end racing anymore..
The last post was made 16 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 84.35 Kb
