Air filters - reusable vs disposable
Dan79
PostPosted: 20:29 - 09 Mar 2010    Post subject: Air filters - reusable vs disposable Reply with quote
I am considering getting a reusable K & N air filter for my motorcycle. Are these worth getting, or is it best to stick with the disposable type ?
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
neatbik
PostPosted: 20:35 - 09 Mar 2010    Post subject: Reply with quote
They work out cheaper in the long run as they can be cleaned.
Only thing is they will flow more air than a standard one which will make your bike run leaner - how much of a problem this is depends on which bike you are fitting it to. On some there is no noticable difference in performance/power delivery, others could benefit from a dynojet kit/power commander or similar Thumbs Up
dobby
PostPosted: 10:48 - 10 Mar 2010    Post subject: Reply with quote
you can buy a foam or fibre air filter oil which is good to use once you have cleaned the air filter, i use one from a company called bell-ray but im pretty sure k&n do the own brand air filter cleaner and oil...
PostPosted: 10:52 - 10 Mar 2010    Post subject: Reply with quote
K and N filters can make your bike run lean, especially with an aftermarket exhaust.
Depends if you want to go to the bother of doing a dyno run really I suppose.
temeluchus
PostPosted: 13:49 - 10 Mar 2010    Post subject: Reply with quote
You can usually compensate for the leaner running of an aftermarket air filter by raising your needle a clip or two(assuming you are running the carburettors) as it mostly affects the midrange.
If you also have an aftermarket legal pipe you may need to go up one jet size, a few more if its a loud pipe.
The last post was made 15 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 43.33 Kb
