Engine exhaust popping - bike not been started for months.
Gazz
PostPosted: 20:03 - 10 Mar 2010    Post subject: Engine exhaust popping - bike not been started for months. Reply with quote
Just started my bike after about 3 months and the engine seems to be running fine, but the exhaust pops and sounds like it is misfiring on idle. The bike runs fine and sounds fine when the revs are above idle.
Please help.
neatbik
PostPosted: 20:06 - 10 Mar 2010    Post subject: Reply with quote
What bike is it mate?
Gazz
PostPosted: 20:10 - 10 Mar 2010    Post subject: Reply with quote
Hyosung GT650R - V-twin
PostPosted: 20:14 - 10 Mar 2010    Post subject: Reply with quote
Duff spark?
Start it up on idle and feel if one pipe is cooler than the other, if so change the plug on that cylinder and see if it helps...
neatbik
PostPosted: 20:19 - 10 Mar 2010    Post subject: Reply with quote
Yeah, investigate the spark plugs first. Sometimes they dont like being sat for a while then started up. Whip them out and a have a look at the electrodes - post the results up here and someone will post a comment Thumbs Up
Gazz
PostPosted: 17:04 - 11 Mar 2010    Post subject: Reply with quote
Changed the plugs and it is still popping away - bang, bang, bang.
Could there be an issue with the carbs ?
Gazz
PostPosted: 17:16 - 11 Mar 2010    Post subject: Reply with quote
Here are the plugs:
https://i94.photobucket.com/albums/l100/Photobucket_Gazz/DSCF9387-1.jpg[/img]
Alex A
PostPosted: 19:07 - 11 Mar 2010    Post subject: Reply with quote
err... time to invest in a new pair. They're both fooked, especially the one on the left.
neatbik
PostPosted: 19:38 - 11 Mar 2010    Post subject: Reply with quote
I agree, they look knackered Thumbs Up
Gazz
PostPosted: 19:39 - 11 Mar 2010    Post subject: Reply with quote
Got a new set in the bike now.
KevTM
PostPosted: 20:31 - 11 Mar 2010    Post subject: Reply with quote
the far away one looks rusty, is that a problem with water getting into the plug 'cylinder', could be your HT lead will be corroded or even just very damp? Just a thought when I see then rust on the plug there.
Alex A
PostPosted: 20:38 - 11 Mar 2010    Post subject: Reply with quote
Does it pop all the time or mainly when you close the throttle/change gear whilst moving?
Gazz
PostPosted: 18:51 - 12 Mar 2010    Post subject: Reply with quote
Just when it is sitting idle.
A few times every minute.
PostPosted: 01:22 - 13 Mar 2010    Post subject: Reply with quote
well check the seal between the end can and the end of the pipe, the 07 GT650 had sh*t seals there.. not sure what its called...
Joenitro
PostPosted: 01:27 - 13 Mar 2010    Post subject: Reply with quote
In the past when i've had stuff like that happen it's been down to a duff battery. May be wrong though Smile
PostPosted: 01:46 - 13 Mar 2010    Post subject: Reply with quote
Quite possible,
GS500 broke down as battery was that weak, ran on 1 cylinder though, popped gargled and was a right ass..
wouldnt charge, blew a fuse...managed to charge at some guys hous, limp it home the 25 miles and replaced the fuse.
iooi
PostPosted: 08:39 - 13 Mar 2010    Post subject: Reply with quote
Take it out for a good run. Should clear the cobwebs out of it.
Closeset plug looks sooty, but a clean should sort that out. Most likely cause is running rich on choke after its been stood for so long.
Other plug does look a bit iffy on its body, but it could be its out of focus rather than heavy rust. Could be the carbs are a bit gummed up if you did not drain them.
If you have changed them. All i would do is get out and give it a dammed good ride. Thumbs Up
The last post was made 16 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 87.56 Kb
