Spark plug cap stuck
snowdude2004
PostPosted: 21:34 - 10 Mar 2010    Post subject: Spark plug cap stuck Reply with quote
Yet again there's another problem I've come across I can't seem to solve. When removing the old spark plug to replace the new one the end cap on the old one managed to get stuck inside the boot shape connector which I can not get out.
I've tried to thread it back in and pull it out but its just not gripping so then I tried putting a touch of superglue on the spark plug and tried pulling it out again and no successs.
Looked online and someone suggested on another forum to use a wire hanger to put through the cap and try pulling it out but it just doesn't want to come free.
attached are the new and old spark plug aswell as the connector the part is stuck in.
https://i31.photobucket.com/albums/c376/snowdude2004/CIMG1048.jpg
https://i31.photobucket.com/albums/c376/snowdude2004/CIMG1049.jpg
CBT passed: 26/09/09, Theory Passed: 18/08/10, Mod 1 passed: 20/10/10, Mod 2 passed: 26/10/10.
Current Bike: Honda CBR 400 Nc23
Bikeless
PostPosted: 21:38 - 10 Mar 2010    Post subject: Reply with quote
Just buy a new HT lead cap,they are a few quid.
lonner
PostPosted: 21:39 - 10 Mar 2010    Post subject: Reply with quote
the boot thing is the HT cap
buy a new one and you will be fine as there only a few quid Thumbs Up
they should be changed every few yrs ideally.
hth
ps check weather it needs the top of the plug removing as most do before fitting to the plug.
ask at the shop if your unsure Thumbs Up
finpos
PostPosted: 21:49 - 10 Mar 2010    Post subject: Reply with quote
You sure that cap actually uses the screw-on bit? My guess would be you throw that part in the bin to use the plug with the type of cap you have.
f.
snowdude2004
PostPosted: 21:54 - 10 Mar 2010    Post subject: Reply with quote
im sure it uses it since its the same spark plug and that cap simply goes over the top of the plug so need to get it out, i'll give it a few more attempts before I call it a day and buy a new cap.
Before I remove it at the end of the night and risk damaging anything else, how do you take it off. Do you simply pull the black wire out of that cap or do you need to twist it or something.
finpos
PostPosted: 21:57 - 10 Mar 2010    Post subject: Reply with quote
Cap unscrews from the cable.
do yourself a favour and try the new plug in the cap without it's little metal hat on. You might find the cap is designed to grip the threaded section.
f.
snowdude2004
PostPosted: 00:12 - 11 Mar 2010    Post subject: Reply with quote
Well Finpos I did what you said and with a slight bit of force I got it in however soon as I pushed in the lead to put it back on the engine the HT lead snapped right at the end.... possibly from corrosion or most likely from me being a bit too hasty getting it on.
I looked at the CDI coil from where it snapped at it says its a Ducati energia with the number: 323990 10 00 7
I'm wondering if this CDI coil now needs replacing or I can simply but a new HT lead like this one: https://beedspeed.com/product_info.php?cPath=76_90_179&products_id=4601
Here's the damage
https://i31.photobucket.com/albums/c376/snowdude2004/CIMG1050.jpg
https://i31.photobucket.com/albums/c376/snowdude2004/CIMG1052.jpg
finpos
PostPosted: 01:09 - 11 Mar 2010    Post subject: Reply with quote
I'm pretty sure with that type of ignitor (it's a cdi and a coil in the same package) you can re-connect the HT lead. Pull off the dust boot from wherever you managed to tear the HT lead from (top right on the photo), you should find a hole the diameter of the HT lead with a sharp screw in the middle. The screw is actually where the spark comes from. Cut off the torn end of the lead so it's straight and screw it into the hole and onto the screw, it's designed so the screw will go into the center of the lead and make contact with the copper core. Don't forget the dust boot!
The terminals on the Coil are labelled -
AT = Alta Tensione (High Tension)
Verde - green
Bianco - white
rosso - red
stop - err... stop (killswitch)
Standard fitting to every small Italian thing from about the 70's!
f.
Marmalade
PostPosted: 08:29 - 11 Mar 2010    Post subject: Reply with quote
Is this a serious question?
If it is, please, please don't ever attempt any maintenance on brakes, you will surely be killed
Quite obviously you've cost yourself god knows how much cash, hassle and time when you needed to......
.... unscrew the adapter from the top of the new plug - job done
ZRX61
Victor Meldrew
PostPosted: 07:45 - 12 Mar 2010    Post subject: Reply with quote
What Bramble said.. & I can't believe the amount of halfwitted morons who also didn't know that.... Rolling Eyes
The last post was made 16 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 64.51 Kb
