Bar Wobble?
SpicyBlimp
PostPosted: 00:24 - 09 Mar 2010    Post subject: Bar Wobble? Reply with quote
Not rode my bike for a while, did a 300+ mile journey and on the way decided to take my hands off the bars.
This is when I noticed the bars starting to wobble side to side then starting to become more violent. I can feel it starting when loosely holding the bars also, didn't notice it particularly when accelerating, braking or cornering though.
Any idea what the problem could be?
The road was smooth and I tried it on a few anyhow, the tyre pressure had been checked that morning and when I got home, this happened under engine braking (well 6th gear 'coasting' down a gentle hill).
Iain, sorry for the crappy post, confused as ever. Laughing
neil.
PostPosted: 06:57 - 09 Mar 2010    Post subject: Reply with quote
Have you checked your steering head bearings for notches? i.e. front wheel off the ground, turn steering from lock to lock slowly. Should move freely and not 'bind' or feel rough or 'notch' where it would stick in one place. Other than that it might just be normal 'tank slapper' stuff which your bike might be prone to.
iooi
PostPosted: 09:53 - 09 Mar 2010    Post subject: Reply with quote
Got a top box ?
Or had some heavy weight on the rear of the bike on that trip.
Also check the rear end for loose bearings. Many a front wobble are cause by something at the back.
PostPosted: 10:12 - 09 Mar 2010    Post subject: Reply with quote
Steering head bearings would be my first guess. But can easily be loads of other things. Check tyre pressures, wheel balance, fork seals, play in the rear suspension linkages, rear shock, etc.
PostPosted: 11:23 - 09 Mar 2010    Post subject: Reply with quote
You haven't lost a wheel balance weight have you?
SpicyBlimp
PostPosted: 23:11 - 10 Mar 2010    Post subject: Reply with quote
iooi wrote:
Got a top box ?
Was the first trip I had done with my top box and panniers, didn't really think about that.
The head bearings are good and i'm pretty sure all my balance weights are still there.
It's not a big problem (I don't think), was just curious about a possible cause.
Serendipity
PostPosted: 15:10 - 11 Mar 2010    Post subject: Reply with quote
Definitely the top box. I used to get the same on my Diversion when I put heavy stuff in the top box.
Another cause of bar wobble I’ve had was when Chiswick Honda managed to warp a brand new rear disk on my CBR600, but that tended to wobble under acceleration rather than coasting.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
dobby
PostPosted: 15:16 - 11 Mar 2010    Post subject: Reply with quote
on piaggios when a top box is fitted heavier bar end weight are fitted aswell... dunno if this applies to all bikes but cud be a cure as a noticeable difference if felt with these
YZFR1-Dave
PostPosted: 16:23 - 11 Mar 2010    Post subject: Reply with quote
+1 on a warped disk.
When i let go of the bars i got a wobble from the bars, but like other folk said it could be fork seals or a weight has fallen of the wheel?
The last post was made 16 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 69.92 Kb
