Yamaha DT losing water...{is this normal? last post...}
PostPosted: 18:53 - 09 Mar 2010    Post subject: Yamaha DT losing water...{is this normal? last post...} Reply with quote
Last time i used it the temp light come on.Turns out it had no coolant.
On closer inspection i noticed the coolant was in the gearbox oil Confused
Am i right in thinking the only thing that would cause that to happen is the waterpump oil seal?
Anyway i changed that today and took it back out and noticed coolant now pissing out of the overflow pipe.
The more i rev the more it comes out.
Took the lid off the radiator and seeing bubbles when i rev the engine.
So head gasket gone? after only 1000 miles (top end rebuild just a few weeks ago using all genuine yamaha gaskets)
If it was the headgasket all along that still wouldn't explain the coolant in the Gearbox oil would it?
Ideas please
Very Happy
DRZ-400sm
evoboy
PostPosted: 19:36 - 09 Mar 2010    Post subject: Re: Yamaha DT losing water... Reply with quote
Ideas please
Very Happy
Probably blown the head gasket when it overheated from lack of coolant...
APT Motorcycles
Paddy Blake
PostPosted: 19:49 - 09 Mar 2010    Post subject: Reply with quote
When the water pump seal went and it over heated from low coolant it could have then blown the head gasket.
PostPosted: 20:04 - 09 Mar 2010    Post subject: Reply with quote
Blown head gasket.
PostPosted: 21:54 - 10 Mar 2010    Post subject: Reply with quote
Changed the headgasket today and it popped that one aswell Crying or Very sad
water pissing out of it.
So head must be warped?
Just seems weird how the original gasket blew after just 1k miles 80% of which were only using 1/4 power at most due to running in.
Turns out the water didn't mix with the oil either ( i just assumed by the colour of the oil,then noticed the oil i use is the same'ish colour as my coolant Laughing ) so what caused the head gasket to blow in the first place Evil or Very Mad
Wondering if there's any mistakes that could have been made when the engineer re-sleeved my barrel?
DRZ-400sm
PostPosted: 00:43 - 11 Mar 2010    Post subject: Reply with quote
When i first rebuilt the engine i didn't Embarassed but it was running absolutely perfect throughout the whole run-in process.
There would have been signs before now surely if they weren't fully tight ?
I cranked them right down today when i tested the new gasket and i only did a few miles.
DRZ-400sm
PostPosted: 16:27 - 11 Mar 2010    Post subject: Reply with quote
Vincent wrote:
I take it you torqued them down in the right order Question
Yup,definately got that bit right Smile. I'll make sure i re-check them in future though Thumbs Up
BLUEX5 wrote:
If some monkey has relined the barrel it's possible the liner has dropped.
Close...
Engineer has just rang to tell me the sleeve was sitting slightly proud Confused only by a couple of thou but it's obviously enough to cause this!
Bit of a twat really since it's cost me the price of 3 head gaskets and the base gasket that i now need.
Then there's the coolant (only £10 but it adds up) not to mention the 3 weeks+ i'll be off the road until the new gaskets arrive from japan Crying or Very sad
It's not as though he done the job cheap either .
Oh well,live and learn.
DRZ-400sm
PostPosted: 20:05 - 11 Mar 2010    Post subject: Reply with quote
I really don't understand this bloke.Ask pretty much anyone in newcastle about engine work and they ALL send you to this place.
He used to have a race team years ago and is supposed one of the best with 2 strokes.
He didn't even file down the sleeve at the ports when he first fitted it which you'd think should be done as a part of the job!
I'm going to have a word with him about getting some money back for my troubles although i know what his answer will be Confused
DRZ-400sm
PostPosted: 18:55 - 12 Mar 2010    Post subject: Reply with quote
Picked it up from the engineer today and he's now got the top of the liner flush,but closer inspection shows this:
(thumbnails due to pic size)
https://i187.photobucket.com/albums/x13/fronterapics/th_Image707.jpg
https://i187.photobucket.com/albums/x13/fronterapics/th_Image708.jpg
Not sure how well you can see that but there is a very small gap in places where the liner meets the barrel?
Should that be there? i would have thought it should be a perfect tight fit all the way round?
DRZ-400sm
The last post was made 16 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.43 - MySQL Queries: 13 - Page Size: 80.26 Kb
