If SV1000 had a much heavier flywheel,
kawashima
PostPosted: 13:55 - 15 Mar 2010    Post subject: If SV1000 had a much heavier flywheel, Reply with quote
will it run at low rev like cruiser motor?
own:2020 Serow 250
EnergyInducti...
PostPosted: 14:03 - 15 Mar 2010    Post subject: Reply with quote
Well no, it just means it would take longer to build up revs, And would keep its revs better when the engine should be slowing down even under full power (E.g. up a hill in a much taller gear)
low revs are due to a longer stroke, which increases instability in the crankshaft as revs increase.
Correct me if I'm wrong here! I only know what I've learnt from my own studies lol
Riding: Yamaha RXS100
Aiming for : RD350 + Test
Dream bike: Suzi RG500 Gamma
Robby
Dirty Old Man
PostPosted: 14:12 - 15 Mar 2010    Post subject: Reply with quote
A heavy flywheel can make the motor (but not the transmission) less snatchy and smoother at lower engine speeds, so it could make an SV1000 run more smoothly at lower revs.
However, it would be slower to rev and to slow down. Generally a low revving motor would have a longer stroke combined with a heavier flywheel, and of course the correct cams, fuelling and electrics to suit.
I can see why you're thinking about it, I always find Japanese engines too bloody revvy. I'd like to get a big Japanese V-twin cruiser and get some weight into the flywheel one of these days, but that's not so easy in itself. Modern bikes don't have a proper flywheel like cars, although some classic bikes did. You would probably need to find a way to add weight to the clutch basket and/or balancer mechanism.
kawashima
PostPosted: 15:06 - 15 Mar 2010    Post subject: Reply with quote
Thanks. Longer stroke(ratio?) is more important than flywheel.
Reading your response, I noticed that there are many aspects which make suitable for low rev power, not only flywheel weight.
I wondered if a heavier flywheel will make an engine which has both MT-01 bottom end and SV1000 top end, but it was too optimistic Doh!
own:2020 Serow 250
Frost
PostPosted: 15:29 - 15 Mar 2010    Post subject: Reply with quote
A piston can only move so fast, and has to stop at the top and bottom, so if it must travel further it will do so less often and the rev's will be lower. This is why larger engines rev lower than smaller ones.
The last post was made 16 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 46.29 Kb
