ZZ600 R forks
pepperami
PostPosted: 21:14 - 15 Mar 2010    Post subject: ZZ600 R forks Reply with quote
i am helping a mate do the fork seals on his ZZ600 R.
they were fairly straight forward, if a little sticky & tight due to dirt and corrosion.
however we do not have a manual for that particular bike!!, and i cant find the manual to my ZX6R which might of been able to help as they are similar bikes.
what we need to know if anybody out there knows, is how much fork oil to replace in the forks now we have a nice new set of seals in place.
anybody!!
PostPosted: 21:20 - 15 Mar 2010    Post subject: Reply with quote
Exactly what model of ZZR is it? Think the D and early E models had one amount / grade, while the later E models had a different amount and grade.
pepperami
PostPosted: 21:35 - 15 Mar 2010    Post subject: Reply with quote
It`s on a H plate.. it`s a 91 model ...... is that any help??
PostPosted: 21:41 - 15 Mar 2010    Post subject: Reply with quote
At that age a D model I think. From the Kwak manual, 10W20 oil, about 384ml when changing the oil or 452ml from disassembled and dry. Either way it should be a 140mm air gap (springs out and forks compressed).
pepperami
PostPosted: 21:45 - 15 Mar 2010    Post subject: Reply with quote
top banana Mr Kick Smile thank you..... now we wont over fill it and burst the seals/ force them out!!
pepperami
PostPosted: 17:28 - 16 Mar 2010    Post subject: Reply with quote
Job done ! whahoo!! Smile
pepperami
PostPosted: 21:07 - 17 Mar 2010    Post subject: Reply with quote
just took the ZZR for a spin after putting all the fairing back on & cleaning up the calipers.
it handles a whole heap better now (obviously!) the forks are working with the same amounts of oil in them and the calipers & discs are not getting a mist of oil on them Smile
it will need a new oil cooler at some time as the one on the bike has taken a hiding from rubbish on the road, but it`s sound so that can wait.
PostPosted: 23:50 - 17 Mar 2010    Post subject: Reply with quote
Our ZZR used to handle horribly. Tried loads of things. finally found the problem was that someone in the past had rebuilt the forks, and it looks like they used the wrong specs. The fork oil in one fork was far thicker than the other. Looks like they used the oil listed for the early bikes in this one which is a later one.
pepperami
PostPosted: 10:15 - 18 Mar 2010    Post subject: Reply with quote
now the front end is done, we need to think about the rear shock.
it`s just been rebuilt and put back on the bike, but we need to set it up/get the right adjustment...... it`s a tad soft so we need to click it round a couple of notches with a c-spanner.
PostPosted: 10:33 - 18 Mar 2010    Post subject: Reply with quote
Good luck. It is a pain to get at. Probably easiest to remove it to adjust it.
The last post was made 15 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 66.23 Kb
