Wiring
Alabama Blacksnake
PostPosted: 19:31 - 16 Mar 2010    Post subject: Wiring Reply with quote
Does any one know how to wire a sat-nav in to a bikes electrics. What is the best way around it, wire in a cigaret lighter socket in the electics so i always have it if i need it or just straight wire it in?
What are the tools i may need aswell.
Cheers Tom
Bikes i've owned: mobylette ----- Ts 50er ------ GS 400e ------ CB250n superdream ------r6 ------ bandit 400 ----- 2005 kx 125
Bikes i have:dtr125 field bike that doesnt not seem to die!!! 1992 gsxr 750 Very Happy
trevoriv said: Leathers are like teenage girls, the tighter the better.
Blue_SV650S
PostPosted: 19:48 - 16 Mar 2010    Post subject: Re: Wiring Reply with quote
Yep, wire up a lighter socket - job done .... you can charge your mobi too!! Wink
Your only decision you then need is if it will be permanently or switched live ....
I have gone permanent with all of mine Thumbs Up
Alabama Blacksnake
PostPosted: 19:54 - 16 Mar 2010    Post subject: Reply with quote
Have you got a wiring diagram for it. I never though about charging the mobile to Thumbs Up
Tom
Blue_SV650S
PostPosted: 19:57 - 16 Mar 2010    Post subject: Reply with quote
Tom
If it is permanent then just wire it direct to the battery (red to +ve, black to -ve). If there is a long run from there to where you intend to place the socket, then put an in-line fuse in there too. Thumbs Up
PostPosted: 20:03 - 16 Mar 2010    Post subject: Reply with quote
Stinkwheel's only recently posted a guide for this. Now if only the forum had something to let you look for posts, maybe a "search" function, if you will...
https://www.bikechatforums.com/viewtopic.php?t=192684
Alabama Blacksnake
Ah ok all nice and simple then cheers.
Tom
barnhatter
PostPosted: 10:26 - 17 Mar 2010    Post subject: Reply with quote
I connected mine to the Fan wiring. The fan does not go on much so the only load will normally be the satnav, also it is switched off when the keys are turned off.
The trouble with a socket is will it be moisture proof.
PostPosted: 11:04 - 17 Mar 2010    Post subject: Reply with quote
I did mine to the rear brake light feed Thumbs Up
kawakid
PostPosted: 12:44 - 17 Mar 2010    Post subject: Reply with quote
I've always gone down the relay route.
On some bikes, the rear brake light swith is a good one to hack in to, to provide the relay trigger, On my ER6 i've used the rear number plate light.
I've fitted the relay, and then put in a cigarette lighter socket under the seat.
Because my sat nav needed a long cable, I purchased a cigarette lighter to USB connector, (ie £2 from ebay), I then purchased a 2 metre Mini 5-Pin Type B usb cable again about £2 from ebay.
Job done.
ie
https://cgi.ebay.co.uk/USB-Car-charger-universal-mobile-phone-ipod-pda-mp3-mp4_W0QQitemZ280473310075QQcmdZViewItemQQptZUK_CE_MP3Access_RL?hash=item414d83137b
https://cgi.ebay.co.uk/2M-HI-SPEED-USB-2-0-CABLE-LEAD-A-MALE-TO-MINI-B-5-PIN_W0QQitemZ260379700320QQcmdZViewItemQQptZUK_Computing_USB_Cables?hash=item3c9fd6ec60
I've a twin and a 4.
The last post was made 16 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 63.25 Kb
