fitting new cams
bob_s
PostPosted: 12:56 - 17 Mar 2010    Post subject: fitting new cams Reply with quote
Hi all
just a quickie.....can any one tell me if new cams can be fitted to a 03 zzr1200 without dropping the engine.
many thanks bob
Cigaro
PostPosted: 18:36 - 17 Mar 2010    Post subject: Reply with quote
I would drop the engine for easier access; it's not that difficult on most bikes.
Don't know about the ZZR; it's doable on my bike but that's a single cylinder. I'd imagine it's a 4cyl 16v (am I right?) and I can imagine it'd be very difficult.
PostPosted: 18:43 - 17 Mar 2010    Post subject: Reply with quote
I've don it on a GS500 and I reckon i could do it on my Speed Four, you might as well try.
PostPosted: 18:50 - 17 Mar 2010    Post subject: Re: fitting new cams Reply with quote
You shouldn't need much more access than you do to do the valves, so should be ok I'd have thought.
bob_s
PostPosted: 19:25 - 17 Mar 2010    Post subject: Reply with quote
many thanks to all !
will have a go and come back to you
bob
Barry_M2
PostPosted: 19:35 - 17 Mar 2010    Post subject: Reply with quote
Bob,
You'll probably find the frame runs very close to the side of the engine, meaning that you will have difficulty seeing the timing marks on the cam sprockets when you try and line them up.
Firstly, I reckon you'll struggle to even get the cam cover out while the motor is still in.
But, give it a try none the less, you might be lucky! Wink Thumbs Up
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
hmmmnz
PostPosted: 23:30 - 17 Mar 2010    Post subject: Reply with quote
if its like the zxr750 hen you should easily be able to do it,
the early zxr's required you to remove the cams to change the shims,
looking at the manual, it looks like the zzr1200 is the same,
you should have no dramas getting the cams out Very Happy
have fun, and dont drop the chain Very Happy
the humans are dead
I kick arse for the lord
mattsprattuk
PostPosted: 00:22 - 18 Mar 2010    Post subject: Reply with quote
do any engines need to be dropped to remove/replace cams? Confused
hmmmnz
PostPosted: 02:43 - 18 Mar 2010    Post subject: Reply with quote
yep, my xz400 requires you to drop the engine just to get the rear rocker cover off Very Happy
im yet to see a inline 4 that you had to drop the engine though,
basically if you can get the rocker cover off, then you can get the cams out (providing its a ohc engine)
the humans are dead
Barry_M2
PostPosted: 08:22 - 18 Mar 2010    Post subject: Reply with quote
No, if can be done with the cams in place quite easily. Wink Thumbs Up
hmmmnz
PostPosted: 09:39 - 18 Mar 2010    Post subject: Reply with quote
how?? it has the cam directly over bucket which is over the shim,
your model is the best system ive ever seen with a shim setup, just push the rocker to the side.. easy access,
the humans are dead
Barry_M2
PostPosted: 10:33 - 18 Mar 2010    Post subject: Reply with quote
Ah, you're thinking ZX7, which uses the bucket over the top of the valves. So yes, on a ZX7 you need to remove the cams. Do the H models use buckets too then, I've never worked on and old H engine?!
But the ZXR J/K/L & M (& ZX9-B) doesn't and you can just slide the rocker out of the way to remove the shim (like you said). It is fiddly, but easily do-able. Thumbs Up
hmmmnz
PostPosted: 11:38 - 18 Mar 2010    Post subject: Reply with quote
yeah zxr750 h1 ad h2 are cam over bucket over shim,
arse of an idea Very Happy but i suppose 1 less thing not to go wrong Very Happy
the humans are dead
The last post was made 15 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.71 - MySQL Queries: 13 - Page Size: 80.32 Kb
