Replacing silencer flange with slip on end
bunglehaze
PostPosted: 16:06 - 17 Mar 2010    Post subject: Replacing silencer flange with slip on end Reply with quote
Hi folks, just looking through the available parts for my bike and I am left wondering if the 3 stud flange that is standard on the ZX6R 2002 A1 model can be modified to accept standard slip ons from other models?
Anyone done it and if so what was it like cost wise and availability on other models.
leigh Smile
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
Fawbish
PostPosted: 17:05 - 17 Mar 2010    Post subject: Reply with quote
Modifying the flange itself is easy, you just drill where you want it to line up. (assuming thats far away enough from the original holes - if it sits withing a few degrees of the existing holes it'd be a bit wank.
The hard part is finding a standard can of the right bore, the 'holding bracket' lining up lengthways along the can to your rear peg hanger etc. but then you can also modify the hanger.
Its more a question of matching up a decent can than modification.
The question is, does the cost of picking up a standard can from another model make it significantly cheaper when factoring in the mods needed - if its just for fun, fair enough.
bunglehaze
PostPosted: 17:10 - 17 Mar 2010    Post subject: Reply with quote
Fawbish, its not intended to keep the flange, I want to get rid of it and go with slip on options but I am not 100% certain if the bore of the pipe is larger than most slip on's (if that makes sense) as it does seem a bit beefy.
The problem is that while I can almost certainly find slip ons from other models I am unsure if any will fit the bore as standard.
The other option of course is to go with a full system which will give me a slip on link pipe but until I know if I am selling on the A1P this year I dont want to fork out that kind of readies.
leigh Smile
PostPosted: 17:14 - 17 Mar 2010    Post subject: Reply with quote
Are you dead set on a slip on? bolt on is better IMO, Slip ons cans can come loose.
There are plenty of bikes cans that will fit your bike including
Pre 2000 bandit 1200
rf4/6/900's
All Triumph 4 cylinder 600's TT600 daytona S4 etc.
ZX4/7/9r around 2000
I'm sure I've forgotten some
Why do you want a slip on?
PostPosted: 17:15 - 17 Mar 2010    Post subject: Reply with quote
If you cut off the flange you can have the pipe swaged to whatever size you want (if you can find someone with a swaging machine). I did this when building my 3" bore pipe.
bunglehaze
PostPosted: 17:19 - 17 Mar 2010    Post subject: Reply with quote
Chris, the slip on idea is simply because a lot of manufacturers are not making new models for this fitting so reviewing new exhausts relies on having a bike with the correct fitting and its either buy a new model bike which I cant do with a baby on the way or find an alternative.
Pete, thanks I might have a look around for that.
leigh Very Happy
PostPosted: 17:23 - 17 Mar 2010    Post subject: Reply with quote
Edit if you want to check if a can will fit your bike go on the leo vince website.
https://www.leovince.com
Select the can that fits your bike, there is an option for technical drawing which gives you the size of the bore and the distance and size of the bolt holes.
I'm 99% sure all those bikes I listed fit your bike. I have a Speed Four and it has a ZX6R (2001) model exhaust on it I checked the technical drawing of the speed four can and the ZX6R (636, 2002) model and the flanges where the same.
PostPosted: 17:24 - 17 Mar 2010    Post subject: Reply with quote
leigh Very Happy
Well Leo vince do, failing that get a second hand one on ebay, there are plenty about, unless you are dead set on a specific exhaust I think that it is more toruble that it is worth hacking the exhaust up.
bunglehaze
PostPosted: 17:34 - 17 Mar 2010    Post subject: Reply with quote
cheers
leigh Very Happy
The last post was made 16 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 63.85 Kb
