Tips for Grips
rac3r
PostPosted: 16:36 - 18 Mar 2010    Post subject: Tips for Grips Reply with quote
My new grips came today and I can't bloody put them on! I can get it about 1/2 way then it's too hard to move.
Is there a way of putting the grips on like using some water or something?
Chequered Flag
PostPosted: 16:42 - 18 Mar 2010    Post subject: Reply with quote
Hair spray.
PostPosted: 16:51 - 18 Mar 2010    Post subject: Reply with quote
Heat them up, if you have a airing cupboard or something, even pooring hot water over them would make them softer and easier to deal with.
virus
PostPosted: 17:04 - 18 Mar 2010    Post subject: Reply with quote
check youve got them the right way around, one has a larger ID for the throttle body, fitting the left grip on the right doesnt work too well. also as said hairspray, lubes em up to get em on and dries sticky so they dont fall off.
John
own: 81 xs1100g...
rac3r
PostPosted: 17:10 - 18 Mar 2010    Post subject: Reply with quote
Yep they're the right way round. I'll try the hairspray then Thumbs Up
Chequered Flag
Fawbish
PostPosted: 17:30 - 18 Mar 2010    Post subject: Reply with quote
banged mine in a bowl of boiling water, slipped on a treat
rac3r
PostPosted: 17:35 - 18 Mar 2010    Post subject: Reply with quote
As in boil the kettle and pour in a bowl? Mr. Green
Chequered Flag
Serendipity
PostPosted: 17:50 - 18 Mar 2010    Post subject: Reply with quote
I soaked mine in rubbing alcohol which evaporates off after they've slipped on.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
CRF_Rider
PostPosted: 18:49 - 18 Mar 2010    Post subject: Reply with quote
hair spray Thumbs Up works a treat.
Why is it everything i race, seems to be going backwards?
Current: Honda CRF 450 R Supermotard
Previous: Yam TY250 x2, Gas Gas TXT 200, Sherco 290, Suzuki TS 50,Honda CG 125, Yam SR250, Suzuki DR-Z400E, Yamaha YZF R6 112rwbhp
Dibble
PostPosted: 21:25 - 18 Mar 2010    Post subject: Reply with quote
If you have an airline you can use the blowgun thing and a penny washer as a spacer if needed.
You blow air down the open end of the grip whilst pushing it on and blocking the other end of the bars.
Sounds complicated but the air expands the grip and it slips on, once you have the knack it's easy.
Smile
PostPosted: 21:47 - 18 Mar 2010    Post subject: Reply with quote
Thouroughly clean bar/throttle tube.
Bowl of boiled water.
Submerge new grips.
Leave for a min.
Shake excess out of grips.
Slide on.
Wipe grips.
Ready to ride in 5.
Always worked better than hairspray for me.
Pat
rac3r
PostPosted: 14:53 - 19 Mar 2010    Post subject: Reply with quote
I used the boiling water trick and it worked....only to find out the grips are short!! Mad
On the left it doesn't look too bad but on the throttle side you can see about 1/2 inch of the throttle. Any ideas? Crying or Very sad
Chequered Flag
PostPosted: 16:42 - 19 Mar 2010    Post subject: Reply with quote
On all bikes there is a small gap between the end of the grip and the block of switches etc. (Throttle side) But 1/2 inch like you say is abit on the large side. If it were me i'd live with them for abit and then source some OEMs/Genuine when i was flush.
The softer of the rubber types will stretch abit so maybe try twisting them clockwise abit more.
The kettle of boiled water is again your friend with this task Smile
Pat
rac3r
PostPosted: 18:24 - 19 Mar 2010    Post subject: Reply with quote
Pat
But these ones look cool Crying or Very sad
Chequered Flag
Peirre oBollox
PostPosted: 18:34 - 19 Mar 2010    Post subject: Reply with quote
Probably a bit late
But if you lube the grips, the odds are they`ll stay slightly slippy.
Compressed air is ideal for getting grips on/off.
Ideally you need a mate with a compressor, but basically just loosen the bond of the grip with a screwdriver, then shove the metal tip of an airline into the end of the grip, try & get the tip of the airline between the grip and handle bar, with air pressure the grip will be like the end of a balloon your letting the air out of, flapping around. While this is happening, pull the grip off.
fitting the new grip ............. push it on slightly to line it up, apply compressed air and push on. Once in place stop, the grip should be fixed onto the bar because the joint in between them is dry
simples https://www.youtube.com/watch?v=buwXnnHWHVg
Kal
PostPosted: 18:44 - 19 Mar 2010    Post subject: Reply with quote
So I am the only one that used a rubber mallet then?
Kal...
Dazbo666
PostPosted: 18:55 - 19 Mar 2010    Post subject: Reply with quote
I managed the mallet technique getting the grips onto a mountainbike some years ago... as well as burring the opposite end, and gouging a chunk out of the garage wall where the other end of the bar was "resting" Rolling Eyes LOL
Word of the day : DILLIGAF
PostPosted: 20:40 - 19 Mar 2010    Post subject: Reply with quote
..Yes use a great big 5lb lump hammer. Swing with force and determination.
Pat
seantobin43
PostPosted: 00:25 - 20 Mar 2010    Post subject: Reply with quote
washing up liquid works really good to
SEAN TOBIN Very Happy
Imonster
PostPosted: 02:29 - 20 Mar 2010    Post subject: Reply with quote
It's totally counter-intuitive, but I always use (a light spray of) WD40 on mine. Works fine, to the extent where I've done it and then gone offroading half an hour later.
Much easier than compressed air guns and the like Thumbs Up
Those who make peaceful revolution impossible will make violent revolution inevitable.
rac3r
PostPosted: 11:47 - 20 Mar 2010    Post subject: Reply with quote
OK Ok I've got them on but there's a new problem now....they're too short Laughing
Chequered Flag
Peirre oBollox
PostPosted: 11:15 - 21 Mar 2010    Post subject: Reply with quote
Having a tape measure handy before you buy them is a good ideal Rolling Eyes
Jamie S
PostPosted: 11:23 - 21 Mar 2010    Post subject: Reply with quote
I swill some thinners around inside them , turn upside down over the bin to empty the excess , fit the grip and with in a few mins the grip is solid, I like this way as it means you are able to reposition them properly (mostly good for motorcross grips with the extra ribbed part for your fingers)
Kal
PostPosted: 02:07 - 22 Mar 2010    Post subject: Reply with quote
Pat
I used to do that, which is why I now own a large rubber mallet...
Kal...
PostPosted: 02:14 - 22 Mar 2010    Post subject: Reply with quote
I was hoping my flippant comment might of told him to buy some grips of the correct length. Wink Smile
Pat
The last post was made 16 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.91 - MySQL Queries: 13 - Page Size: 130.61 Kb
