| rac3r |
 rac3r World Chat Champion
 Posted: 16:36 - 18 Mar 2010 Post subject: Tips for Grips |
My new grips came today and I can't bloody put them on! I can get it about 1/2 way then it's too hard to move.
Is there a way of putting the grips on like using some water or something? ____________________ Bikes : 2006 CBR125R - 2004 Monster 620ie - 2004 ZX-6R B1H - 2005 Monster S2R 800 - 2011 Street Triple - 2009 Streetfighter 1098 - 2014 ZX-6R 636
| Ste |
 Ste Not Work Safe
| chris-red |
| virus |
 virus World Chat Champion
 Posted: 17:04 - 18 Mar 2010 Post subject: |
check youve got them the right way around, one has a larger ID for the throttle body, fitting the left grip on the right doesnt work too well. also as said hairspray, lubes em up to get em on and dries sticky so they dont fall off.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| rac3r |
 Posted: 17:10 - 18 Mar 2010 Post subject: |
Yep they're the right way round. I'll try the hairspray then  ____________________ Bikes : 2006 CBR125R - 2004 Monster 620ie - 2004 ZX-6R B1H - 2005 Monster S2R 800 - 2011 Street Triple - 2009 Streetfighter 1098 - 2014 ZX-6R 636
| Fawbish |
 Fawbish World Chat Champion
| rac3r |
| Serendipity |
 Serendipity World Chat Champion
 Posted: 17:50 - 18 Mar 2010 Post subject: |
I soaked mine in rubbing alcohol which evaporates off after they've slipped on. ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| CRF_Rider |
 CRF_Rider Spanner Monkey
 Posted: 18:49 - 18 Mar 2010 Post subject: |
hair spray works a treat. ____________________ Why is it everything i race, seems to be going backwards?
Current: Honda CRF 450 R Supermotard
Previous: Yam TY250 x2, Gas Gas TXT 200, Sherco 290, Suzuki TS 50,Honda CG 125, Yam SR250, Suzuki DR-Z400E, Yamaha YZF R6 112rwbhp |
| Dibble |
 Dibble Scooby Slapper
 Posted: 21:25 - 18 Mar 2010 Post subject: |
If you have an airline you can use the blowgun thing and a penny washer as a spacer if needed.
You blow air down the open end of the grip whilst pushing it on and blocking the other end of the bars.
Sounds complicated but the air expands the grip and it slips on, once you have the knack it's easy.
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 21:47 - 18 Mar 2010 Post subject: |
Thouroughly clean bar/throttle tube.
Bowl of boiled water.
Submerge new grips.
Leave for a min.
Shake excess out of grips.
Slide on.
Wipe grips.
Ready to ride in 5.
Always worked better than hairspray for me.
Pat ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| rac3r |
 Posted: 14:53 - 19 Mar 2010 Post subject: |
I used the boiling water trick and it worked....only to find out the grips are short!!
On the left it doesn't look too bad but on the throttle side you can see about 1/2 inch of the throttle. Any ideas?  ____________________ Bikes : 2006 CBR125R - 2004 Monster 620ie - 2004 ZX-6R B1H - 2005 Monster S2R 800 - 2011 Street Triple - 2009 Streetfighter 1098 - 2014 ZX-6R 636
 Posted: 16:42 - 19 Mar 2010 Post subject: |
On all bikes there is a small gap between the end of the grip and the block of switches etc. (Throttle side) But 1/2 inch like you say is abit on the large side. If it were me i'd live with them for abit and then source some OEMs/Genuine when i was flush.
The softer of the rubber types will stretch abit so maybe try twisting them clockwise abit more.
The kettle of boiled water is again your friend with this task
| rac3r |
| Peirre oBollox |
 Peirre oBollox Could Be A Chat Bot
 Posted: 18:34 - 19 Mar 2010 Post subject: |
Probably a bit late
But if you lube the grips, the odds are they`ll stay slightly slippy.
Compressed air is ideal for getting grips on/off.
Ideally you need a mate with a compressor, but basically just loosen the bond of the grip with a screwdriver, then shove the metal tip of an airline into the end of the grip, try & get the tip of the airline between the grip and handle bar, with air pressure the grip will be like the end of a balloon your letting the air out of, flapping around. While this is happening, pull the grip off.
fitting the new grip ............. push it on slightly to line it up, apply compressed air and push on. Once in place stop, the grip should be fixed onto the bar because the joint in between them is dry
simples https://www.youtube.com/watch?v=buwXnnHWHVg ____________________ I accept no responsibility for swearing, drinking, motorcycle riding or your pregnant teenage daughter. |
| Kal |
 Kal World Chat Champion
| Dazbo666 |
 Dazbo666 World Chat Champion
| seantobin43 |
 seantobin43 Nova Slayer
 Posted: 00:25 - 20 Mar 2010 Post subject: |
washing up liquid works really good to ____________________ SEAN TOBIN  |
| Imonster |
 Imonster World Chat Champion
 Posted: 02:29 - 20 Mar 2010 Post subject: |
It's totally counter-intuitive, but I always use (a light spray of) WD40 on mine. Works fine, to the extent where I've done it and then gone offroading half an hour later.
Much easier than compressed air guns and the like  ____________________ Those who make peaceful revolution impossible will make violent revolution inevitable. |
| rac3r |
 Posted: 11:47 - 20 Mar 2010 Post subject: |
OK Ok I've got them on but there's a new problem now....they're too short  ____________________ Bikes : 2006 CBR125R - 2004 Monster 620ie - 2004 ZX-6R B1H - 2005 Monster S2R 800 - 2011 Street Triple - 2009 Streetfighter 1098 - 2014 ZX-6R 636
| Peirre oBollox |
 Posted: 11:15 - 21 Mar 2010 Post subject: |
Having a tape measure handy before you buy them is a good ideal  ____________________ I accept no responsibility for swearing, drinking, motorcycle riding or your pregnant teenage daughter. |
| Jamie S |
 Jamie S World Chat Champion
| Kal |
The last post was made 16 years, 205 days ago. Instead of replying here, would creating a new thread be more useful? |
