Engine Oil
CptBlack
PostPosted: 16:30 - 22 Mar 2010    Post subject: Engine Oil Reply with quote
Had a search for this but couldn't find anything.
What makes good engine oil?
I've been recommended to change the oil every 1000 miles on my 125 and use decent oil. And have been (filter also)
But I'm not sure whether the oil I've been using is 'the best' (within reason of course - Can't afford too much!)
My manual states "SAE 10W-40 and the API is SF or SG"
My local MotorWorld sells a 4 stroke, semi synthetic API SL (Exceeds SG) but seems a little expensive at £10 a litre. I also think (from reading round here) that mineral oil would suffice for these changes, but it's not sold there.
So, where do you recommend getting oil? Decent brands? What should I look for specifically when choosing the oil?
Cheers,
Chris
PostPosted: 16:41 - 22 Mar 2010    Post subject: Reply with quote
Not sure what bike you have.
Small 4 stroke singles tend to have very little oil in them and no oil cooler, etc, to keep it cool. Seems to give the oil a pretty hard life.
In simple terms with the oil rating (ie, SE, SF, etc) the first letter is S for spark ignition engines while the higher the 2nd letter the more recent spec oil it is. Some of the latest specs can have friction modifyers that might cause clutch problems (but in my experience generally don't) and also are limited on some of the additives used to give the best engine protection (as they damage catalytic converters).
stirlinggaz
PostPosted: 17:37 - 22 Mar 2010    Post subject: Reply with quote
hi,
asda do a decent budget mineral oil (as do the other supermarkets) which is fine on a small 4t.
i just changed it a bit more often.
cheers,
GAZ
CptBlack
PostPosted: 17:49 - 22 Mar 2010    Post subject: Reply with quote
Hi, many thanks for the replies. I have a Hyosung Cruise II. It is oil cruise (or it says on the radiator mount that it is oil cooled)
According to the casing where the oil goes in, it says 950ml, and the manual says 1050 when changing the filter as well (to be expected) Will it be harmful to only put a litre in - 50 ml short?
I have noticed that when its getting to 1k since a change, sometimes the gears are hard to get in, and sometimes I go into neutral when changing up from 1st - is this due to losing oil (or burning up) therefore the gearbox not being properly lubricated or old oil fouling it? (Edit: likely to be the cause!)
Cheers again,
Chris
PostPosted: 18:09 - 22 Mar 2010    Post subject: Reply with quote
Oil level too high (ie too much oil) will cause crankcase pressure problems, and quite likely blow some seals in the engine.
Oil level too low will result in no oil pressure and a wrecked engine (likely cams or big end bearings first).
You have a bit of leeway, but not much. And if you don't keep an eye on the oil level then the chances are that the first you will know about the oil level dropping too low is the oil pressure warning light coming on to tell you that you have already done damage.
The Artist
PostPosted: 18:19 - 22 Mar 2010    Post subject: Reply with quote
Just put 950ml, run it for a minute. leave it for another minute or 2, then check the level on level ground. Top it up as you see fit. So long as you are above minimum you are fine till you can get hold of some more oil and top it up to the full marker.
LeeR
PostPosted: 20:28 - 22 Mar 2010    Post subject: Reply with quote
Hein Gericke's own brand oil (made by Motul) 10w40 semi-synthetic API SG and JASO MA rated, is a pretty good oil @ £19.99/4L inc "free" oil filter.
It had been very reasonably priced at £13.99 until their new catalogue came out, but it's still the best priced motorcycle oil around.
My claim to fame: Austin Vince nicked my pen...
oldbiker
PostPosted: 21:12 - 22 Mar 2010    Post subject: Reply with quote
Check this site for some basic info
https://www.carbibles.com/engineoil_bible.html
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
CptBlack
PostPosted: 21:36 - 22 Mar 2010    Post subject: Reply with quote
Cracking page - looking at the rest of the site now, cheers.
Cheers for that - will pop in tomorrow
and
PostPosted: 21:45 - 22 Mar 2010    Post subject: Reply with quote
WildGoose
White Van Man
PostPosted: 23:57 - 22 Mar 2010    Post subject: Reply with quote
A little expensive? Shocked
I wouldn't touch anything branded as motorcycle oil, you are simply paying for the clever marketing.
I can't believe I used to pay £20-25 for 4L of Castrol stuff. Makes me sick.
I generally pick up the cheapest stuff that meets the specs. API grades are pretty meaningless, in that anything but the cheapest crappy supermarket 20w50 will exceed their latest standards.
I use Comma 15w40 in my bikes, car and van. Never had any issues.
https://cgi.ebay.co.uk/COMMA-DIESEL-15W-40-SEMI-SYNTHETIC-5-LITRE-ENGINE-OIL_W0QQitemZ270459969261QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ef8ab9eed
Diesel oil just has extra detergents and stuff in it, so doesn't put me off. It is likely to be a better oil as diesels work their oil a lot harder.
£2 a litre, not including the postage. It's pretty much the cheapest I can find it.
If you are changing as regularly as every 1000 miles on a non performance bike, you can probably use any oil you like with confidence.
stugol
PostPosted: 23:41 - 08 Apr 2010    Post subject: fj1200 oil consumption Reply with quote
hi
can anyone please tell me the average oil consumption for a yam fj1200?
i have an old f reg with 51000 miles, it doesnt seem to smoke on start up, or smoke from the exhaust even on revving but after about 300 miles i noticed the oil level went from full to showing half way in the sight glass!?
i put around 300ml of oil to restore the full amount.
i guess this equates to about 1l per 1000 miles!
any ideas?
thanks
stugol
temeluchus
PostPosted: 17:53 - 10 Apr 2010    Post subject: Reply with quote
was it full after the change?
The oil level will settle a bit after a change as some is pumped to the various parts of the motor.
Robby
Dirty Old Man
PostPosted: 21:39 - 10 Apr 2010    Post subject: Reply with quote
Older big engined Yamahas were known for a bit of oil consumption, I think up to 1L every 1000 miles was within spec.
For another question elsewhere, an oil change every 1000 miles is correct on an air cooled 4 stroke 125, although you could change the filter every 2nd or 3rd time. The gearchange does tend to go off as the oil gets broken down.
temeluchus
PostPosted: 23:03 - 10 Apr 2010    Post subject: Reply with quote
My FJ1200 consumed next to nothing.
The culprit of that idea i think was early thunderaces as there was some problem with the way they were bored that lead to them drinking a fair bit.
Acemastr
PostPosted: 11:05 - 11 Apr 2010    Post subject: Reply with quote
I used fully synth 10-40w in my YBR every 1500miles, was a tad too often really lol, it just felt smoother, i'll change my CBR's far less as it really doesn't need it.
2016 Toyota Tacoma Limited
PostPosted: 22:27 - 11 Apr 2010    Post subject: Reply with quote
The FZR1000 had a reputation for drinking oil as well. Late FZ750s did as well,but early ones seemed to be fine (they changed the piston designs after the first series of FZ750).
tatters
Exxon Valdez
PostPosted: 00:42 - 12 Apr 2010    Post subject: Reply with quote
Slight oval bores and crapy valve stem seals and the most common blame, seems to be a radom thing as some are more worst than others.
My old YZF1000R once used up over 12 liters of oil on a 1500-2000 mile tour of scotland (hence my forum nickname) but the YZF750R uses only 0.5ml every 2000-2500 miles both have the same almost identical 20 valve EXUP engine (diffrent cylinder block and 1 less gear).
PostPosted: 00:54 - 12 Apr 2010    Post subject: Reply with quote
That's nearly as much as my TZR Shocked Laughing
temeluchus
PostPosted: 06:32 - 12 Apr 2010    Post subject: Reply with quote
Obvioulsy yamaha bought a bargain basement machine to do the cylinders in 89/90 then.
If anyone has a dipsomaniacal YZF1000R, get it bored out to first oversize and the problem will disappear Smile
PostPosted: 08:20 - 12 Apr 2010    Post subject: Reply with quote
Problem seemed to come along when they moved to slipper pistons. Interesting that a rebore and 1st oversize would fix it.
The last post was made 16 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 4.65 - MySQL Queries: 13 - Page Size: 115.12 Kb
