| CptBlack |
 CptBlack Trackday Trickster
| Kickstart |
 Kickstart The Oracle
 Posted: 16:41 - 22 Mar 2010 Post subject: |
Not sure what bike you have.
Small 4 stroke singles tend to have very little oil in them and no oil cooler, etc, to keep it cool. Seems to give the oil a pretty hard life.
In simple terms with the oil rating (ie, SE, SF, etc) the first letter is S for spark ignition engines while the higher the 2nd letter the more recent spec oil it is. Some of the latest specs can have friction modifyers that might cause clutch problems (but in my experience generally don't) and also are limited on some of the additives used to give the best engine protection (as they damage catalytic converters).
| stirlinggaz |
 stirlinggaz World Chat Champion
| CptBlack |
| Kickstart |
 Posted: 18:09 - 22 Mar 2010 Post subject: |
Oil level too high (ie too much oil) will cause crankcase pressure problems, and quite likely blow some seals in the engine.
Oil level too low will result in no oil pressure and a wrecked engine (likely cams or big end bearings first).
You have a bit of leeway, but not much. And if you don't keep an eye on the oil level then the chances are that the first you will know about the oil level dropping too low is the oil pressure warning light coming on to tell you that you have already done damage.
| The Artist |
 The Artist Super Spammer
| LeeR |
 LeeR World Chat Champion
 Posted: 20:28 - 22 Mar 2010 Post subject: |
Hein Gericke's own brand oil (made by Motul) 10w40 semi-synthetic API SG and JASO MA rated, is a pretty good oil @ £19.99/4L inc "free" oil filter.
It had been very reasonably priced at £13.99 until their new catalogue came out, but it's still the best priced motorcycle oil around. ____________________ My claim to fame: Austin Vince nicked my pen... |
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 21:12 - 22 Mar 2010 Post subject: |
| CptBlack |
| and |
 and World Chat Champion
| WildGoose |
 WildGoose White Van Man
| stugol |
 stugol L Plate Warrior
| temeluchus |
| Robby |
 Robby Dirty Old Man
| temeluchus |
| Acemastr |
 Acemastr World Chat Champion
| Kickstart |
| tatters |
 tatters Exxon Valdez
 Posted: 00:42 - 12 Apr 2010 Post subject: |
| Robby wrote: | Older big engined Yamahas were known for a bit of oil consumption, I think up to 1L every 1000 miles was within spec.
Slight oval bores and crapy valve stem seals and the most common blame, seems to be a radom thing as some are more worst than others.
My old YZF1000R once used up over 12 liters of oil on a 1500-2000 mile tour of scotland (hence my forum nickname) but the YZF750R uses only 0.5ml every 2000-2500 miles both have the same almost identical 20 valve EXUP engine (diffrent cylinder block and 1 less gear). ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| ms51ves3 |
 ms51ves3 Super Spammer
| temeluchus |
| Kickstart |
The last post was made 16 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
