Bit of a long shot but
Tim..
PostPosted: 11:24 - 18 Mar 2010    Post subject: Bit of a long shot but Reply with quote
I was wondering if anyone in south east london/north west kent area has got a fork seal driver (41mm) I could borrow?
Tim
www.marshallracing.co.uk
hmmmnz
PostPosted: 11:39 - 18 Mar 2010    Post subject: Reply with quote
use the old folk seal and a plastic mallet
the humans are dead
I kick arse for the lord
Tim..
PostPosted: 11:46 - 18 Mar 2010    Post subject: Reply with quote
Need it for a set of usd forks. They have had quite a bit of money spent and dont want to f#ck them up because I didnt use the correct tools.
Tim
pepperami
PostPosted: 11:52 - 18 Mar 2010    Post subject: Reply with quote
What hmmmnz said! i just did the seals on a ZZ6r exactly that way and they are fine Smile .
dont try to knock them in all in one go Shocked
once i got the old seal out i sanded off a tiny amount off the outside of the old seal so that it was`nt a tight fit.
that way once i had used it to tap in the new seal, it was easy to take it off the fork Smile
Tim..
PostPosted: 12:07 - 18 Mar 2010    Post subject: Reply with quote
Thanks for the tips guys but I would rather use the correct tool, I have spent far too much time and money to maybe mess these forks up.
Tim
el_oso
PostPosted: 13:34 - 18 Mar 2010    Post subject: Reply with quote
if you already spent so much money. take it to a shop. they should do it for next to nothing as it takes less than 5 minutes. especially if you have the forks in bits
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 14:01 - 18 Mar 2010    Post subject: Reply with quote
For USD forks, cut the old seal in half apparently (making sure no metal is sticking out, of course).
That's pretty much what a fork seal driver is.
I wouldn't mind getting a set of seal drivers at some point, but way down on the list as not found the need so far.
I suspect a lot of bike garages don't bother with 'official' drivers either.
I use a bit of drain pipe with a slit taken out of it as a slide hammer for forks - put some kitchen towel inside if you're being extra careful.
trisers
PostPosted: 15:32 - 18 Mar 2010    Post subject: Reply with quote
When the new seal is pushed up against the housing, tape a piece of A4 paper wrapped tightly around the fork tube so the rubber mallet can slide down against it to tap against half of one of the old seals to knock the new seal into place...easy to do and absolutely no damage to the fork tube Wink
PostPosted: 15:38 - 18 Mar 2010    Post subject: Reply with quote
Ensure the bush is forced fully in to the stantion then the seals should go in fairly easily. I use a blunt metal rod and a plastic mallet to knock it in.
Tim..
PostPosted: 21:22 - 23 Mar 2010    Post subject: Reply with quote
I hear what you're saying guys but I would still rather use the correct tool for the job. Think I will just buy one when i next get paid.
Has anyone had any experience with this adjustable one?
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390146718382&ssPageName=STRK:MEWAX:IT
Is it good quality? Has anyone got/used one?
Tim
hmmmnz
PostPosted: 22:59 - 23 Mar 2010    Post subject: Reply with quote
go for it,
im sure your going to ignore all our advice any way,
ive never seen a mechanic ever use one, but you seem determined
to do as the manual says Wink
the humans are dead
TUG
PostPosted: 00:11 - 24 Mar 2010    Post subject: Reply with quote
I just cut the old seals in half and use them, never thought of them scoring the stanchion either, hmm, normally its just a clean cut and i've never had one come back leaking oil yet, how very odd.
Haz ER-5, innit!
Tim..
PostPosted: 08:10 - 24 Mar 2010    Post subject: Reply with quote
Only when i hear 'hammer' and 'seal' in the same sentence Wink
The last post was made 15 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 80.59 Kb
