technical question exup
colin1
Captain Safety
PostPosted: 02:10 - 24 Mar 2010    Post subject: technical question exup Reply with quote
I've heard of exup valves, and have the vague idea its a bit like the power valve on a 2 stroke. ie fully open at high rpm, and partially closed at lower rpm to improve low rev torque by some dark art of back pressure or something.
I'm not wanting an explanation of a 2 stroke power valve here, but I do want an explanation on exups.
I found this https://en.wikipedia.org/wiki/Exhaust_ultimate_power_valve
I guess what I want to know is, do all sports 600s and 1000s have something like this where the 4 header piped meet the pipe to the exhaust, or just some ?
This is partly influenced by the fact I've got a full system I got cheap off ebay, that I may one day fit to my triumph TT600.
I've removed the standard exhaust before and didn't see any sign of wires to a servo of an exup.
I'm particularly interested in peoples views on this comment "Mostly I think it helps pass EPA tests since open pipes tend to pass unburned gas. With the EXUP the valves can then be put on a steeper cam and still hold the exhaust gas under control. "
If thats the case, I wouldnt lose any low end performance if my 600 did turn out to have an exup, as it would just be there to fiddle emmmissions.
Having said that, as far as I know the tt600 doesnt have an exup type valve, but if anyone knows different, say so.
Apparently the 675 has one, but i havent verified that.
PostPosted: 09:35 - 24 Mar 2010    Post subject: Reply with quote
im sure the FZR600 and FZR1000 had an exup model for the USA. All i know is they are the less powerful versions of the FZR as it restricts them in some way...
Feel free to correct me if im wrong..
robbieguy2003
PostPosted: 09:56 - 24 Mar 2010    Post subject: Reply with quote
The 600rr has one of these valves, the little motor in mine actually failed leaving it wide open.
It got replaced under warranty, however after phoning Honda they said it was there for emissions/some performance at low revs - so the back pressure trick.
They said it was fine to ride until I could get it into the shop. It took me nearly a week to get in with it.
Had no noticable performance problems but did get a lot more smoke out of the exhaust from a cold start, it would also continue to smoke for upto a few minutes after shutdown.
Obviously a different bike but the aboves my experience with the things on an IL4 based bike.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
PostPosted: 10:35 - 24 Mar 2010    Post subject: Reply with quote
The TT600 doesn't have an exhaust valve. Exup is a Yamaha trademark, and Honda have a similar thing on the 2000 onwards FireBlades called HVIX.
The Daytona 675 has a flap in the airbox that closes at around 5000rpm because this is where the type approval noise tests are done... but as far as I am aware it has no exhaust valve either.
PostPosted: 10:41 - 24 Mar 2010    Post subject: Re: technical question exup Reply with quote
Who made the system? what does it look like can I have it Laughing
If you aren't going to use it or want to flog it let me know.
AngelGrinder
PostPosted: 10:54 - 24 Mar 2010    Post subject: Reply with quote
The 675 definately has one. Had to free the bastard thing, as it had seized over winter!!
salty21
PostPosted: 18:14 - 24 Mar 2010    Post subject: Reply with quote
robbieguy2003 wrote:
The 600rr has one of these valves, the little motor in mine actually failed leaving it wide open..
was that in the 03 or 07?, if 07 do you know if the 03 has one?
robbieguy2003
PostPosted: 20:01 - 24 Mar 2010    Post subject: Reply with quote
That was on the 07. I don't think the 03 had one from memory.
woodyfjr
PostPosted: 20:08 - 24 Mar 2010    Post subject: Reply with quote
The EXUP valve on early 1000 FZRs were for more torque at lower rpm then opened up to allow more power as the cam timing was a bit wilder.
Racers took them off as they were always over the rpm range so the valve would have been open anyway.
If you don't pay your exorcist you can get repossessed.
If you have to rev it! Don't Buy it!
colin1
Captain Safety
PostPosted: 22:58 - 24 Mar 2010    Post subject: Reply with quote
Yeah after saying I hadnt verified it, i googled the 675 exup equivalent, and someone else had a seized one that they had to free too, so i guess its not that uncommon for them to seize.
Noxious89123
PostPosted: 00:39 - 25 Mar 2010    Post subject: Reply with quote
It's called HTEV (Honda Titanium Exhaust Valve). HVIX is the flap in the airbox. Thumbs Up
colin1
Captain Safety
PostPosted: 01:39 - 25 Mar 2010    Post subject: Re: technical question exup Reply with quote
It's a quill full system. Not the best brand, but it was only £50. Its just got a slight dent on the end can.
I've got a riveter, so I intend to drill out the rivets, bash out the dent, and then rivet back up.
Then get the bike set up on a dyno, with my tuneboy lead and software.
beatnick on here as already asked to by the full race system, and i said no. I said yes to him borrowing the tuneboy lead, but I still havent found it...
I am a bit of a hoarder...
PostPosted: 01:48 - 25 Mar 2010    Post subject: Reply with quote
Not sure if anyone makes an aftermarket system with an Exup style valve in it.
EXUP valve is there to allow sillier cam timing / manifold design, optimised for peak power. On a normal system this would land up with a dire mid range (and that is certainly what you get on an FZR1000 EXUP if you fit an aftermarket system without the valve), as the pressure waves that work at high rpm to draw mixture from the head does the opposite and rams the burnt gases back into the head. The EXUP valve screws up the pressure waves to prevent this problem.
woodyfjr
PostPosted: 09:32 - 25 Mar 2010    Post subject: Re: technical question exup Reply with quote
If it has a dent on the outside make you do is drill out the rivits at cap end re-fit it upside down which puts the dent on the inside (this dont work if yours has seam weld underneath) also Quill are very good quality cans at £50 you got a bargain.
PostPosted: 10:09 - 25 Mar 2010    Post subject: Re: technical question exup Reply with quote
I'm considering getting a tuneboy for mine, is it worth it in your eyes?
colin1
Captain Safety
PostPosted: 12:30 - 25 Mar 2010    Post subject: Reply with quote
When I bought mine it had been partially set up with the tuneboy. The guy had got the dyno place to do the settings, starting with the high revs. Unfortunately, as he was paying by the hour, and it was taking a while, he stopped the guy from doing the full range. Did most of it, but not completely the lower revs like 3k 2k.
Having said that, it was smoother at 4k. In the normal fuel map, there is a flat spot at 4k, to get the bike through emmissions tests that are about 55mph in top gear.
It also seemed smoother throughout the range. When cold with a standard tune, throttle can be a bit twitchy.
Unfortunately, when I took the bike to a shit triumph dealer, with an unrelated problem, he decided to repalce it with standard fuel map, and cap off my scott oiler. He was trying to eliminate possible cause of the problem I was having.
I do have a copy of the custom fuel map somewhere, but never got round to putting it back on the bike, or setting up the scott oiler again.
Id say the improvement with a standard can, is slight but noticeable, whether its worth buying tuneboy lead and software, is whether you have money to burn or not.
It would definitely be worth doing with a race can or full system though. Not sure I'd bother with standard can.
My tuneboy lead came with the bike.
I would recommend downgearing though. My bike came downgeared, but since then I'm too tight, so only fit standard sprockets as they are cheaper.
Nice to know that Quill are a good brand, I don't know much about exhausts really Smile and nice tip about refitting the exhaust bit on the inside before re-rivetting. I hadnt thought of that.
PostPosted: 12:49 - 25 Mar 2010    Post subject: Reply with quote
How much is Dyno time/ how long would it set up?
colin1
Captain Safety
PostPosted: 14:05 - 25 Mar 2010    Post subject: Reply with quote
I dont know, someone else might.
woodyfjr
PostPosted: 09:06 - 13 Apr 2010    Post subject: Reply with quote
It can cost quite a bit. The more experienced the dyno man the quicker generally.
neatbik
PostPosted: 20:58 - 13 Apr 2010    Post subject: Reply with quote
For the Tune Boy setup you are looking at about £280 - the same as a power commander.
But Tune Boy also works as a diagnostic tool, and rather than piggybacking the ecu you are actually re-writing it.
As for dyno costs, i think most charge around £40 an hour? I would say at least a couple of hours to set up, maybe more.
The last post was made 16 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.31 - MySQL Queries: 15 - Page Size: 114.59 Kb
