| colin1 |
 colin1 Captain Safety
 Posted: 02:10 - 24 Mar 2010 Post subject: technical question exup |
I've heard of exup valves, and have the vague idea its a bit like the power valve on a 2 stroke. ie fully open at high rpm, and partially closed at lower rpm to improve low rev torque by some dark art of back pressure or something.
I'm not wanting an explanation of a 2 stroke power valve here, but I do want an explanation on exups.
I found this https://en.wikipedia.org/wiki/Exhaust_ultimate_power_valve
I guess what I want to know is, do all sports 600s and 1000s have something like this where the 4 header piped meet the pipe to the exhaust, or just some ?
This is partly influenced by the fact I've got a full system I got cheap off ebay, that I may one day fit to my triumph TT600.
I've removed the standard exhaust before and didn't see any sign of wires to a servo of an exup.
I'm particularly interested in peoples views on this comment "Mostly I think it helps pass EPA tests since open pipes tend to pass unburned gas. With the EXUP the valves can then be put on a steeper cam and still hold the exhaust gas under control. "
If thats the case, I wouldnt lose any low end performance if my 600 did turn out to have an exup, as it would just be there to fiddle emmmissions.
Having said that, as far as I know the tt600 doesnt have an exup type valve, but if anyone knows different, say so.
Apparently the 675 has one, but i havent verified that. ____________________ colin1 is officially faster than god |
| P.addy |
 P.addy Red Rocket
| robbieguy2003 |
 robbieguy2003 World Chat Champion
| MarJay |
 MarJay But it's British!
| chris-red |
 Posted: 10:41 - 24 Mar 2010 Post subject: Re: technical question exup |
| colin1 wrote: | I've heard of exup valves, and have the vague idea its a bit like the power valve on a 2 stroke. ie fully open at high rpm, and partially closed at lower rpm to improve low rev torque by some dark art of back pressure or something.
Apparently the 675 has one, but i havent verified that. |
Who made the system? what does it look like can I have it
If you aren't going to use it or want to flog it let me know. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| AngelGrinder |
 AngelGrinder World Chat Champion
| salty21 |
 salty21 World Chat Champion
 Posted: 18:14 - 24 Mar 2010 Post subject: |
| robbieguy2003 |
| woodyfjr |
 woodyfjr Scooby Slapper
| colin1 |
| Noxious89123 |
 Noxious89123 World Chat Champion
| colin1 |
| Kickstart |
 Kickstart The Oracle
 Posted: 01:48 - 25 Mar 2010 Post subject: |
Not sure if anyone makes an aftermarket system with an Exup style valve in it.
EXUP valve is there to allow sillier cam timing / manifold design, optimised for peak power. On a normal system this would land up with a dire mid range (and that is certainly what you get on an FZR1000 EXUP if you fit an aftermarket system without the valve), as the pressure waves that work at high rpm to draw mixture from the head does the opposite and rams the burnt gases back into the head. The EXUP valve screws up the pressure waves to prevent this problem.
| woodyfjr |
| chris-red |
 Posted: 10:09 - 25 Mar 2010 Post subject: Re: technical question exup |
| colin1 wrote: | | chris-red wrote: |
If you aren't going to use it or want to flog it let me know. |
It's a quill full system. Not the best brand, but it was only £50. Its just got a slight dent on the end can.
I've got a riveter, so I intend to drill out the rivets, bash out the dent, and then rivet back up.
Then get the bike set up on a dyno, with my tuneboy lead and software.
beatnick on here as already asked to by the full race system, and i said no. I said yes to him borrowing the tuneboy lead, but I still havent found it...
I am a bit of a hoarder... |
I'm considering getting a tuneboy for mine, is it worth it in your eyes? ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| colin1 |
 Posted: 12:30 - 25 Mar 2010 Post subject: |
When I bought mine it had been partially set up with the tuneboy. The guy had got the dyno place to do the settings, starting with the high revs. Unfortunately, as he was paying by the hour, and it was taking a while, he stopped the guy from doing the full range. Did most of it, but not completely the lower revs like 3k 2k.
Having said that, it was smoother at 4k. In the normal fuel map, there is a flat spot at 4k, to get the bike through emmissions tests that are about 55mph in top gear.
It also seemed smoother throughout the range. When cold with a standard tune, throttle can be a bit twitchy.
Unfortunately, when I took the bike to a shit triumph dealer, with an unrelated problem, he decided to repalce it with standard fuel map, and cap off my scott oiler. He was trying to eliminate possible cause of the problem I was having.
I do have a copy of the custom fuel map somewhere, but never got round to putting it back on the bike, or setting up the scott oiler again.
Id say the improvement with a standard can, is slight but noticeable, whether its worth buying tuneboy lead and software, is whether you have money to burn or not.
It would definitely be worth doing with a race can or full system though. Not sure I'd bother with standard can.
My tuneboy lead came with the bike.
I would recommend downgearing though. My bike came downgeared, but since then I'm too tight, so only fit standard sprockets as they are cheaper.
Nice to know that Quill are a good brand, I don't know much about exhausts really and nice tip about refitting the exhaust bit on the inside before re-rivetting. I hadnt thought of that. ____________________ colin1 is officially faster than god |
| chris-red |
| colin1 |
| woodyfjr |
| neatbik |
 neatbik World Chat Champion
The last post was made 16 years, 150 days ago. Instead of replying here, would creating a new thread be more useful? |
