Premium petrol bikes
kawashima
PostPosted: 14:07 - 26 Mar 2010    Post subject: Premium petrol bikes Reply with quote
There are many bikes which drinks premium petrol. What I want to know is that if you own a bike which drinks premium petrol, are you happy with it? Or you wanted it to be regular petrol bike if possible?
Or if you own regular petrol bike, are you happy with it or do you wanted it to be premium petrol bike if possible?
For me, TDM is on a border line between regular and premium(*), and it is said that premium is "better" among users in Japan due to high comp twin and the Octane rating in Japan. But I wanted it to be regular petrol bike if possible even if its power goes down a little bit cause I use it as touring bike.
* TDM requires regular petrol with Octane rating over 91. But many bike shops in Japan suggest to use premium petrol to avoid Knocking at low revs.
The point is do you pay extra for premium petrol happily for extra few BHP?
own:2020 Serow 250
Dr. DaveJPS
PostPosted: 14:18 - 26 Mar 2010    Post subject: Reply with quote
i currently run a tank of premium/ tank of regular cycle due to teh fact (certainly in france) they've removed some of the additives from the regular and replaced them with ethanol. This mix is wrecking engines so i err on the side of caution in case they've done it over here.
Edit: have never noticed any power increase
www.davejps.com
kawashima
PostPosted: 14:24 - 26 Mar 2010    Post subject: Reply with quote
This fact is very interesting. I wonder if this is the same in UK Confused .
own:2020 Serow 250
Dr. DaveJPS
PostPosted: 14:27 - 26 Mar 2010    Post subject: Reply with quote
i dunno but for a few extra quid i ain't risking it.
www.davejps.com
Itchy
PostPosted: 14:28 - 26 Mar 2010    Post subject: Reply with quote
Change the CDI to the super tenere? a couple of blokes rode Super tenere across Africa with its 0 Octane petrol and they were fine.
PostPosted: 14:36 - 26 Mar 2010    Post subject: Reply with quote
I usually run premium in the four and regular in the TDM but I will splash a tank through every now and then to give it a clean out. I can get more miles with premium but not enough to justify the cost.
kawashima
PostPosted: 14:46 - 26 Mar 2010    Post subject: Reply with quote
0 Octane petrol Shocked ... that will surely destroy premium only engine Shocked . Super tenere CDI.. it is like BMW GS adventure. I heard GS adventure is designed for regular petrol not like other models, and its max power is a little bit lower.
I wonder why BMW doesn't apply this setting to all other GS models too. Normal GS models are for tough touring too.
own:2020 Serow 250
kawashima
PostPosted: 14:48 - 26 Mar 2010    Post subject: Reply with quote
I also heard and read that from TDM users. There's no problem with knokking? UK regular petrol may be better than here one though.
own:2020 Serow 250
PostPosted: 14:54 - 26 Mar 2010    Post subject: Reply with quote
Nope never had that problem with regular,
The standard petrol in the UK is 95Ron, Super is 97-99Ron
But there are different systems for measuring octane, the Yanks use Pon, 95Ron = 91Pon so assuming I assume in Japan you use Pon too as you stated standard is 91. I have had no problems running any bike on 95.
kawashima
PostPosted: 15:01 - 26 Mar 2010    Post subject: Reply with quote
Thanks. I just read the wiki, this is very complicated Shocked .
Ah that was why we must be careful when we buy import bikes..
Edit: regular petrol in Japan has about 90Pon average.
own:2020 Serow 250
Ghost
PostPosted: 15:31 - 26 Mar 2010    Post subject: Reply with quote
I would've thought any standard UK production bike will be designed to run on regular 95ron fuel. Plenty of people fill their sports bikes with super but there's no real need, I'm convinced any real performance increase is more of a placebo effect than anything else and the increased mileage is never enough to offset the extra cost in the first place.
I've just had to fill my ZX6R tank with Super as all the regular unleaded pumps were out of order, so I thought I'd give it a try. Honestly can't say I've noticed any difference at all. I might try running it to reserve though to see if I get any more mileage out of it than I normally do.
PostPosted: 15:41 - 26 Mar 2010    Post subject: Reply with quote
Not true several bikes/cars have sensors that detect the type of fuel and adjust the performance according in some bmw's it makes a 10-15 bhp difference. To to mention the cleaners and what not.
Does it make a difference? yes, is it worth it? probably not.
PostPosted: 16:04 - 26 Mar 2010    Post subject: Reply with quote
My car takes expensive petrol and it does hurt that bit more every time I fill up, but I don't drive it enough to excessively worry. I bought a fast car because I wanted the fastness, not being cheap to drive.
PostPosted: 17:52 - 26 Mar 2010    Post subject: Reply with quote
Plenty of bikes don't even need 95 RON fuel.
From an Autodata book the TDM850 and TDM900 only need 91 octane fuel (and fairly sure that is RON, so about 86 PON).
A few bikes do need higher octane fuel (earlier Aprilia 125 for example), and with these you will quite likely get serious engine damage from using too low octane fuel.
Some bikes can adjust the timing based on a knock sensor and these might well get a minor increase in power from using higher octane fuel. But not much. Only things that are going to see a major change are those with turbos which can adjust the boost to take advantage of the higher octane fuel.
Higher octane fuel on its own will give you zero extra power (and quite possibly less, higher octane fuel often has a slightly lower energy content). It just allows you to modify the engine / ignition so that it can give more power.
PostPosted: 18:53 - 26 Mar 2010    Post subject: Reply with quote
There are certainly more additives in the higher octane petrol, cleaners etc. just as there are more additives in the standard fuel at the oil companys' stations (BP, Shell etc.) that in supermarket fuels.
sweet angel
PostPosted: 19:24 - 26 Mar 2010    Post subject: Reply with quote
Always use premium, still knock and rattle like buggery tho Smile would worry if they didn't Shocked
Kawasaki Triples Queen Smile 1972 H2, 1974 H2B, 1977 KH250 B2, 1979 KH250 B5
PostPosted: 21:09 - 26 Mar 2010    Post subject: Reply with quote
I've yet to hear of a bike ECU that does it, the only bike I know that's fitted with a knock-sensor is the blackbird.
PostPosted: 21:22 - 26 Mar 2010    Post subject: Reply with quote
A load of BMWs do I believe. Few other bikes had knock sensor (think as an oddity possibly the XJ650 had one).
iooi
PostPosted: 22:10 - 26 Mar 2010    Post subject: Reply with quote
Isn't that what happened to the Tesco fuel that cost them a lot of money for destroying engines......
PostPosted: 22:29 - 26 Mar 2010    Post subject: Reply with quote
Wasn't that silicone contamination?
Ethanol should be fine as a fuel, but you need more of it. Hence a richer mixture and higher fuel consumption (car with a lambda probe should cope with this automatically, although it might cause issues when at full throttle if it just runs directly on the fuel map then and ignores the lambda probe). Other problem is that it attacks some materials such as some rubbers.
Itchy
PostPosted: 22:30 - 26 Mar 2010    Post subject: Reply with quote
Whatever happened with that and the ruined cars? I've never trusted Tesco petrol after a ride out up Snake pass, when Trev's bike began misfiring like crazy when he filled up with Tesco fuel.
smegballs
PostPosted: 22:46 - 26 Mar 2010    Post subject: Reply with quote
I can confirm the turbo XJ650 had a knock sensor.
MZ's have different head gaskets to allow for differing fuel quality! Laughing
PostPosted: 09:56 - 27 Mar 2010    Post subject: Reply with quote
I thought it was for manufacturing tolerances Very Happy
Rob W
PostPosted: 10:09 - 27 Mar 2010    Post subject: Reply with quote
Have to agree, I've tried it in a couple of bikes and personally think it makes absolutely no difference at all
barnhatter
PostPosted: 12:03 - 27 Mar 2010    Post subject: Reply with quote
All fuel must reach a certain quality to be sold. Tesco had a problem with a batch of fuel but I am sure that due to bad publicity their fuel will be tested and they wont allow dodgy fuel to be sold.
From my understanding most bikes will run as correctly on 95RON fuel. They are designed to be sold/used in all countries with different fuel quality. 95RON is the agreed calorific value that the fuel suppliers will supply fuel at for motor cars/bikes. Designers then produce engines to run at a minimum just below this value.
Putting in higher octain fuel will give a slight increase on power, if this is noticed is up to debate, improved cleaners might assist in a cleaner burn. But as I said the engine will run as designed with regular fuel so I am not sure that the extra cost for most engines is worth it.
The last post was made 16 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.73 - MySQL Queries: 14 - Page Size: 139.59 Kb
