| kawashima |
 kawashima World Chat Champion
 Posted: 14:07 - 26 Mar 2010 Post subject: Premium petrol bikes |
There are many bikes which drinks premium petrol. What I want to know is that if you own a bike which drinks premium petrol, are you happy with it? Or you wanted it to be regular petrol bike if possible?
Or if you own regular petrol bike, are you happy with it or do you wanted it to be premium petrol bike if possible?
For me, TDM is on a border line between regular and premium(*), and it is said that premium is "better" among users in Japan due to high comp twin and the Octane rating in Japan. But I wanted it to be regular petrol bike if possible even if its power goes down a little bit cause I use it as touring bike.
* TDM requires regular petrol with Octane rating over 91. But many bike shops in Japan suggest to use premium petrol to avoid Knocking at low revs.
The point is do you pay extra for premium petrol happily for extra few BHP? ____________________ own:2020 Serow 250
owned: 2012 YB125SP, 2008 TDM900, 2005 W650, 2002 LS125R, 2002 CB400SF, NS50F, C50 / Trip to UK(2009), Hokkaido touring(2013) |
| Dr. DaveJPS |
 Dr. DaveJPS World Chat Champion
 Posted: 14:18 - 26 Mar 2010 Post subject: |
i currently run a tank of premium/ tank of regular cycle due to teh fact (certainly in france) they've removed some of the additives from the regular and replaced them with ethanol. This mix is wrecking engines so i err on the side of caution in case they've done it over here.
Edit: have never noticed any power increase ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| kawashima |
| Dr. DaveJPS |
 Posted: 14:27 - 26 Mar 2010 Post subject: |
i dunno but for a few extra quid i ain't risking it. ____________________ "intelligent inattention is preferable to unintelligent tinkering"
www.davejps.com |
| Itchy |
 Itchy Super Spammer
 Posted: 14:28 - 26 Mar 2010 Post subject: |
Change the CDI to the super tenere? a couple of blokes rode Super tenere across Africa with its 0 Octane petrol and they were fine. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| chris-red |
| kawashima |
| kawashima |
| chris-red |
| kawashima |
 Posted: 15:01 - 26 Mar 2010 Post subject: |
| chris-red wrote: | Nope never had that problem with regular,
The standard petrol in the UK is 95Ron, Super is 97-99Ron
But there are different systems for measuring octane, the Yanks use Pon, 95Ron = 91Pon so assuming I assume in Japan you use Pon too as you stated standard is 91. I have had no problems running any bike on 95. |
Thanks. I just read the wiki, this is very complicated .
Ah that was why we must be careful when we buy import bikes..
Edit: regular petrol in Japan has about 90Pon average. ____________________ own:2020 Serow 250
| Ghost |
 Ghost Could Be A Chat Bot
| chris-red |
| G |
 G The Voice of Reason
 Posted: 17:52 - 26 Mar 2010 Post subject: |
Plenty of bikes don't even need 95 RON fuel.
From an Autodata book the TDM850 and TDM900 only need 91 octane fuel (and fairly sure that is RON, so about 86 PON).
A few bikes do need higher octane fuel (earlier Aprilia 125 for example), and with these you will quite likely get serious engine damage from using too low octane fuel.
Some bikes can adjust the timing based on a knock sensor and these might well get a minor increase in power from using higher octane fuel. But not much. Only things that are going to see a major change are those with turbos which can adjust the boost to take advantage of the higher octane fuel.
Higher octane fuel on its own will give you zero extra power (and quite possibly less, higher octane fuel often has a slightly lower energy content). It just allows you to modify the engine / ignition so that it can give more power.
| Polarbear |
 Polarbear Super Spammer
| sweet angel |
 sweet angel L Plate Warrior
 Posted: 19:24 - 26 Mar 2010 Post subject: |
Always use premium, still knock and rattle like buggery tho would worry if they didn't  ____________________ Kawasaki Triples Queen 1972 H2, 1974 H2B, 1977 KH250 B2, 1979 KH250 B5 |
| iooi |
 iooi Super Spammer
 Posted: 22:29 - 26 Mar 2010 Post subject: |
Wasn't that silicone contamination?
Ethanol should be fine as a fuel, but you need more of it. Hence a richer mixture and higher fuel consumption (car with a lambda probe should cope with this automatically, although it might cause issues when at full throttle if it just runs directly on the fuel map then and ignores the lambda probe). Other problem is that it attacks some materials such as some rubbers.
| Itchy |
 Itchy Super Spammer
| smegballs |
 smegballs World Chat Champion
 Posted: 09:56 - 27 Mar 2010 Post subject: |
| Rob W |
 Rob W World Chat Champion
| barnhatter |
 barnhatter Nitrous Nuisance
The last post was made 16 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
