| puremagic72 |
 puremagic72 Brolly Dolly
 Posted: 11:21 - 27 Mar 2010 Post subject: oil change that went wrong! |
Help pips, done an oil change on my gixxer 750, when i emptied the oil, felt a small bit of tension on the plug after just 1 turn, took it out, tried again, and again, eventually it done it, i was pretty carefull,but now i think i cross threaded the engine end, as it keeps turning and not really tightening.
I have done oil changes before, but this is the 1st problem i had.
Is there any way of making sure the oil does not leak out, maybe tape round the thread?
Thanks..i feel such a friggin noob now.
Baz. ____________________ Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids. |
| The Artist |
 The Artist Super Spammer
| el_oso |
 el_oso World Chat Champion
| CaNsA |
 CaNsA Super Spammer
| The Artist |
 Posted: 14:38 - 27 Mar 2010 Post subject: |
| puremagic72 |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 16:04 - 27 Mar 2010 Post subject: |
if you get it drilled and tapped. Take the sump off. For obvious reasons. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| puremagic72 |
| Damon |
 Damon World Chat Champion
 Posted: 17:25 - 27 Mar 2010 Post subject: |
correct
Maybe you could take the sump off youself and give it to a garage to do for you? Shouldn't cost too much |
| puremagic72 |
| Damon |
| supZ |
 supZ World Chat Champion
| puremagic72 |
| supZ |
| Pickledswede |
 Pickledswede Traffic Copper
| Cigaro |
 Cigaro World Chat Champion
 Posted: 07:43 - 28 Mar 2010 Post subject: |
Odd that you should post this as I've just had the sump plate on the GN helicoiled (I turned it the wrong way and stripped the threads), cost less than a tenner  |
| puremagic72 |
| puremagic72 |
| Cigaro |
 Posted: 10:31 - 28 Mar 2010 Post subject: |
The GSXR11 sump screwed up 2 weeks ago (took the bolt out and it came out with a thread insert).
Sumps tend to be held on with a lot of small bolts which are only done up to a fairly low level of torque (about a dozen with the GSXR11). There will be a gasket between the sump and the cases and this will need to be replaced. The O rings you might get away without replacing. However make very sure that they are all back in position (entirely possible for one to be missing and to land up losing lots of oil pressure through the resulting leak inside the engine).
| puremagic72 |
 Posted: 10:02 - 29 Mar 2010 Post subject: |
Well...think i may have been very lucky, laying in bed last night thinking, if i put the old drain plug in, thinking that maybe the other one was shot(a long shot as ali casing v's steel plug), fitted it, went in straight away, poured new oil in, and no leak as of yet, will give it a couple of hrs just to check.
Is this a rarety when the plug go's and not the pan which is made of ali?
Thanks for all your help,
| The Artist |
| puremagic72 |
The last post was made 15 years, 281 days ago. Instead of replying here, would creating a new thread be more useful? |
