What tools do you guys use?
everyreasonto
PostPosted: 21:25 - 29 Mar 2010    Post subject: What tools do you guys use? Reply with quote
I was planning on investing in a really nice socket set. So far I've been looking at Teng and Snap-On.
Also should I get a 1/2" or 3/8" ratchet? They both have a full range of sockets, the only thing I can think is that the 1/2 will be a bit bigger and stronger.
The Artist
PostPosted: 21:31 - 29 Mar 2010    Post subject: Reply with quote
Halfords pro. Lifetime guarantee and not too expensive.
1/2 will do and you can get cheaper 3/8 kits from halfords for not much.
That_Hornet
PostPosted: 21:43 - 29 Mar 2010    Post subject: Reply with quote
Found half inch good for car. But for bikes 3/8 is better IMO
I have the Halfords advanced set in 3/8. Lifetime guarantee and cost £18.99
Awesome set.
I also have a Teng tool 1/4 set, a Kennedy 1/2 set and a halfords advanced 3/8.
IMO snap-on a waste of money unless your a mechanic or similar. Halfords suits most.
Edit:
Teng: https://www.screwfix.com/prods/52680/Hand-Tools/Sockets-Hex-Hex-Keys/Sockets-Hex/Teng-Mecca-Rosso-Basic-Socket-Set-23Pcs
Halfords: https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_525109_langId_-1_categoryId_165572
Kennedy: https://www.cromwell.co.uk/KEN5827991K
everyreasonto
PostPosted: 22:09 - 29 Mar 2010    Post subject: Reply with quote
Great thanks, never thoought about halfords. Think i'm gonna go for 1/2 though, there is only 3mm diff.
PostPosted: 22:20 - 29 Mar 2010    Post subject: Reply with quote
1/2" drive and 3/8" drive are both useful (and 1/4" drive for many things). 3/8" will do most things on a bike. 1/2" will sometimes be a bit bulky to use on a bike.
PostPosted: 22:26 - 29 Mar 2010    Post subject: Reply with quote
I find the best for bike is 1/4 and 1/2, 1/4 for anything <12mm 1/2 for things >12 Don't see the point to 3/8 myself as you are allways going to need the 1/2 for big stuff like rear wheel/front sprocket.
Noxious89123
PostPosted: 22:29 - 29 Mar 2010    Post subject: Reply with quote
The Clarke Pro stuff from MachineMart is good quality too, and cheap Thumbs Up
MachineMart usually have a much better choice than Halfords, and better prices.
Raffles
You are joking arn't you?
everyreasonto
PostPosted: 22:40 - 29 Mar 2010    Post subject: Reply with quote
No Razz But I was talking about the relative bulk of the head of the ratchet. Sort of what chris-red mentioned, 1/4" for smaller things because a 1/2" wouldn't fit.
Robby
Dirty Old Man
PostPosted: 22:52 - 29 Mar 2010    Post subject: Reply with quote
I use my 3/8 ratchet more than any tool, to the extent that the ratchet mechanism is starting to go. Comfortable with sockets from 8-14mm, short and deep reach, and my allen, torx, and star bits and sockets.
If you try and use a 1/2 ratchet on an 8 or 10mm bolt, you'll break the bolt. If you use a 1/4 ratchet on a stuck 12 or 13mm bolt, you'll knacker the ratchet.
My main set is a mastergrip 3 drawer box that was 60 quid in costco about 8 years ago. 3 sizes of ratchet with sockets to go with them. I have an awful lot of other tools as well. You can never have enough tools.
cloric_tzr
PostPosted: 23:13 - 29 Mar 2010    Post subject: Reply with quote
2 pound lump hammer.
mole grips.
claw hammer.
cable ties.
pliers.
and. . .
a miracal (stocks running out fast so hurry to avoid dissapointment! most major credit cards accepted)
Laughing Laughing Laughing Twisted Evil
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
PostPosted: 23:18 - 29 Mar 2010    Post subject: Reply with quote
It is easier to find a 3/8" drive torque wrench that goes low enough to do most of the fastners on a bike that you should really be using a torque wrench on.
You get a lot of stuff on a bike that needs to be done to 7 or 8ft/lb and a 1/2" torque wrench usually starts too high.
To be honest, I use a 1/4" set with plenty of extensions for a lot of the stuff on my bike.
I'd also say that for stuff that you need a 1/2" drive for, you'll get away with a cheaper socket set. You're a lot less likely to damage a bigger hex with a slightly poorer fitting socket.
For up to 12mm I use the 1/4" drive. For 12-17mm I use the 3/8" and for bigger stuff I use the 1/2". I'm giving serious consideration to getting a cheap 3/4" set for stuff over 24mm.
That said. If I was going to buy one good socket set, I'd go for a 3/8". I'd make sure I got a full set of wobble bars in with it for tight spots and I'd get some deep sockets in with it.
If I personally was setting out from scratch. I'd get a GOOD 1/4" set, a moderately good 3/8" set and a cheap and cheerful 1/2" set.
Halfords pro stuff is very good. I can't fault my Teng set either.
My "diamond in the rough" buy was a "draper expert" 1/4" drive set though. It's taken anything I have thrown at it for the last 9 years and has got me out of some tight corners. I can also use the sockets on my 3/8" torque wrench with a suitable adapter. It all fits in a 6"x6" box which tucks neatly either under the seat or in the side pocket of my panniers.
If you're throwing money about. Consider a 3/8" "Metrinch" socket set. It's flat drive so it's almost impossable to burr a head with it, even if the hex is cheaply made to slightly the wrong size (Japanese brake calliper bolts are a good example, a lot of them seem to have an 11.75mm hex on them). The same set will also fit all the imperial sizes in its range without the need for twice as many sockets.
Katier
Personally I have a mix and match set of all 3 sizes. Often find different ones handy for different jobs depending on access and torque of the bolts. When out travelling I keep the 1/4 set under the saddle too which can be handy.
sieversrichie
PostPosted: 23:30 - 29 Mar 2010    Post subject: Reply with quote
Halfords toolkit, although i do need to upgrade it as at least one of everything is missing Embarassed
StevenF
PostPosted: 00:35 - 30 Mar 2010    Post subject: Reply with quote
Awesome set.
Edit:
I thought the Halfords set you had cost you £18.99, the one you linked too is £44.99!
StevenF
PostPosted: 00:40 - 30 Mar 2010    Post subject: Reply with quote
Which would you go for, if it's your first proper ratchet set.
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_164275_langId_-1_categoryId_165572 or https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_176237_langId_-1_categoryId_165572
I like that the first one has the large extension and spark plug socket.
Ingah
PostPosted: 00:45 - 30 Mar 2010    Post subject: Reply with quote
What about the 120 piece (or something) Halfords Professional socket set. They periodically "discount" it down to £99.99 (usually from £199.99 Shocked) and i think it's as comprehensive as you'll ever need.
-- Ingah
mad4it028
PostPosted: 00:53 - 30 Mar 2010    Post subject: Reply with quote
on my bike i use mostly my snap on 1/4 set from 4mm 14mm
3/8 snap on set 14mm to 19mm
1/2 snap on set from 19mm to 54mm
ive spent well over £20k on tools over the years but if you just want tools for home ide go machine mart and buy there clarke tools
snap on are very expensive only needed for the trade even then you could get away with cheaper stuff but snap on come to you so its easy..lol
bobbertandsam...
PostPosted: 07:52 - 30 Mar 2010    Post subject: Reply with quote
I'll second the Halfords pro 120 piece or similar size set, bought one over 3 years ago and its been brilliant. Rarely find that I dont have the required size of socket/ratchet I need. Think they are on a t £99 just now again.
Its never easy
SlimRick
PostPosted: 08:09 - 30 Mar 2010    Post subject: Reply with quote
I use the Halfords Pro range too - never broke one yet!
On a side note, is it just me or does some fucker always nick my 13mm and 1/2" spanners?
Darth
PostPosted: 08:39 - 30 Mar 2010    Post subject: Reply with quote
StevenF wrote:
Wouldn't get either of those sets as they have the crap oddly shaped ratchet. Halfords professional sets are the ones to go for.
Also noticed they are doing the flex head ratchet spanner sets are half price - Buy me!!
You will never regret having a set of those Thumbs Up
PostPosted: 09:34 - 30 Mar 2010    Post subject: Reply with quote
Nature abhors a 13mm spanner.
They are in a constant state of existential flux and could spontaneously blink out of existance at any time, only to re-appear in someone elses toolbox on the other side of the world in the form of a set of rusted together feeler guages.
Similar properties are exhibited by 5mm allen keys and the chuck keys to electric drills.
PostPosted: 10:14 - 30 Mar 2010    Post subject: Reply with quote
Nature loves a 13mm spanner, got loads of them, some spares elsewhere in random draws etc.
THEN you need one and mysteriously they've all gone.
KTM understands this so well as the normal 13mm you get a second stubby one with a bottle opener on the other end in the tool kit!
bacon
i bought the halfords pro kit, the one that regularly gets knocked down to £100
its been great, has 1/2, 3/8 and 1/2 ratchets, with plenty of sockets both imperial and metric, spanners etc etc
Iv used it loads since i got it in december, dont have any other sets so cannot compare
trisers
PostPosted: 23:45 - 30 Mar 2010    Post subject: Reply with quote
For what it's worth I have a Teng tools 1/4in ratchet, it has more ratchet teeth than most (small swings in confined places)...I use it professionally on a daily basis and it's only just showing signs of wear after nearly 15 years of use!
For sockets I use Kamasa professional range...extremely durable too....
The last post was made 15 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 132.5 Kb
