New Member / Just Brought NSR
Scotty
Scooter Boi
PostPosted: 11:15 - 31 Jul 2002    Post subject: New Member / Just Brought NSR Reply with quote
HEY!
Ok i new to this posting but there seems to be some good advice and alot of people here so i thought i'd join up.
I've recently Brought an NSR125 after alot of research reviews and just personal accounts on them. i know there not the fastest 125 on the market but i think there a good all rounder with good reliability or so i've heard.
But ive noticed on my NSR that it gets very hot and the temp gauge after a while rises into the red. this cannot be normal. And i'm not reving the bollox out of the engine, only up to say 6'000 rpm b4 changing gear as i'm a bit new to all the bike and where its power is.
I stopped the bike to look at the coolent level and managed to top it up. Only to find it was still happening. There was also water over the back swing arm where i think it leaked from the over flow. I cant seem to find any leaks.
Any who i phoned the dealer up and he said if he cant think of something in the next day he'll come down with the trailer and pick it up and fix the problem. Which is nice of him. (Remember he is a dealer....)
Could you know whats up with the bike or how to solve it.
Maybe the pumps a bit dodgy or i might have a small leak somewhere that losing presure and not pumping correctly.
Apart from that i love the bike and is so much better than my old 50cc Speedfight. Very Happy
Scott
P.s. Its De-restricted.
Kris
PostPosted: 11:22 - 31 Jul 2002    Post subject: Reply with quote
welcome mate Very Happy
glad someone else with an NSR is on this forum....its all getting a bit big bike forum for my liking!
Zimma
Wheelie Junkie
PostPosted: 11:23 - 31 Jul 2002    Post subject: Reply with quote
either that or firestorm forum Smile
-Zimma
Demonic69
The Pink Rhino
PostPosted: 11:40 - 31 Jul 2002    Post subject: Reply with quote
It'll be the Imaginary RF400R Forum sooon!!
Muahahahahahahahahaaaaa Twisted Evil
Back on a Blade. Just feels so right.
PostPosted: 11:44 - 31 Jul 2002    Post subject: Reply with quote
Hi!... sorry can't really help with the problem though
/me waits a few years untill it becomes a GSXR1000/R1 forum Smile
PostPosted: 19:06 - 31 Jul 2002    Post subject: Reply with quote
Is the radiator getting hot as well as the engine? If the radiator is cold then the water is not pumping round. This could be a dead water pump, air block, too strong an anti freeze mix or a failed thermostat. If the radiator is hot then the problem is likely to be more serious.
Also, if you overfill the cooling system on some vehicles the system cannot cope with the preasure and bascially doesnt push the water round. However, although you might have overfilled it, it sounds like the bike has managed to dump some water out which would "correct" this problem
All thebest
TiN
Pocket Tin
PostPosted: 19:10 - 31 Jul 2002    Post subject: Reply with quote
lol...I managed to heat up my mate's NSR and make it leak...but I was revving the nuts off it, and *trying* to do burnouts! Laughing
TiN
dotgems.net
Annabella
Like a person, only smaller
PostPosted: 22:55 - 31 Jul 2002    Post subject: Reply with quote
Welcome to our happy home Scotty! Enjoy your NSR (and a word of advice - believe Keith!! He's not the Oracle for nothing)
If you're getting annoyed with your NSR overheating - look on the bright side - at least you wont freeze in the winter Laughing
Avast! Pirates ahoy!
I did Cadwell! Very Happy
Scotty
Scooter Boi
PostPosted: 23:17 - 31 Jul 2002    Post subject: Reply with quote
Thanks for the information i think the radiator is staying cold, it is dumping water but i did notice on the way home it was fine. Temp was all correct but i wasnt reving the crap out of it.
My first idea is that the thermostat is sticking or just completly failed.
If i want to check this i dont have to take the cylinder head of do i?
I can just unscew the top tap?
And remove it to see the thermostat?
I think the radiator is staying cold.
But thanks for the replys. Glad i have somewhere to run to when i dont understand the problem.
Cant the bike overheat from just reving the nuts of it any way?
I dont think it should but its just a question of mine i would like to know.
Scott
McJamweasel
BCF Junkie
PostPosted: 00:26 - 01 Aug 2002    Post subject: Reply with quote
It shouldnt do, I always rev the tits off mine(Im rarely in the bottom half of the tacho) and thge temp never rises much.
If you were revving it while not moving tho, yeah, it might overheat.
Could a wrong plug cause this?? Or mebbe a wrong air/fuel mix?
chunkielad
PostPosted: 10:00 - 01 Aug 2002    Post subject: Reply with quote
I had this issue on an old RK and it turned out to be the head gasket needed replacing! - Only took 10 mins and £5 and hey presto - Bobs you fanny!!!
Not that I am saying your has the same issue but basically the water was passing through to the cylinder (not good!) and burning up (whilst adding a whole lot of other problems). There was also a pressure comming out from the cylinder and pushing the water backwards and out of the overflow - sound familiar?
Mark Harrison R.I.P - 26th March 2003.
Remember you always and will ride in your honour.
Big revvs up for Mark!
Scotty
Scooter Boi
PostPosted: 13:20 - 01 Aug 2002    Post subject: Reply with quote
Hello again, thanx for replys. i just had the dealer phone me up and i explained the problem to him about a day ago and has come back with exactly what lunarcreek said.
Head gasket needs replacing, when you say there where other problems lunarcreek what other problems where there? did this cause the bike not to perform as well?
Scott
chunkielad
PostPosted: 14:25 - 01 Aug 2002    Post subject: Reply with quote
No - the water going into the cylinder caused issues whilst doing it - but once the gasket was swapped, all was fine!
Issues such as - loss of fluid (obviously) - loss of power - overheating
I assure you - once the gasket is swapped, everything will run smoothly - just get them to check the piston. If eccessive water has got in, you could bend the arm but it isn't very likely.
Scotty
Scooter Boi
PostPosted: 14:46 - 01 Aug 2002    Post subject: Reply with quote
Cheers for that the dealer has ordered the part though so at least its not a major problem that cant be fixed.
So his paying for it all to be done and fitted, no expense to me ..few.. Surprised
Apart from that i think the bike is excellent and hope it lasts a good few years with out any other problems.
And if theres more power to come from the 125 engine then woooohooo, i know you probably think thats silly since its only a 125 but when youve just swapped from a 50cc, its a bit of a defierence.
thanx for help.
Scott
chunkielad
PostPosted: 15:00 - 01 Aug 2002    Post subject: Reply with quote
An NSR125 RK was my first bike!! Imagine how that felt!!!!
Good luck with it and I hope you get years of reliable service to come.
Demonic69
The Pink Rhino
PostPosted: 15:06 - 01 Aug 2002    Post subject: Reply with quote
NSR125R-K Was the 1st bike I ever rode too:) Good fun
PostPosted: 19:52 - 01 Aug 2002    Post subject: Reply with quote
Head gasket would cause that problem, but I would expect it to use loads of water. Should be easy for the dealer to change the gasket. However, if the bike has run very hot then it can have damaged the piston. Depends on how hot and for how long it was run, but it could have nipped up.
Scotty
Scooter Boi
PostPosted: 20:06 - 01 Aug 2002    Post subject: Reply with quote
Well hopefully its not caused the barrel or piston any damage. I havent gone on any long rides because of the fear of doing the bike lots of damage. And when it does start to get hot (past 3/4 level) i usually stop the bike and let it cool down before heading of again.
Dont know weather this will actually help but i feel better in doing it.
Scott
PostPosted: 20:11 - 01 Aug 2002    Post subject: Reply with quote
Hopefully should be fine then
Ryan
PostPosted: 22:28 - 01 Aug 2002    Post subject: The navigater Reply with quote
Can anyone remember the film the navigator, a film where a boy goes into a space ship then flies everywhere in it, the spaceship is really shiny like a mirror, anyway the point of this is that on that ship there was a friendly robot that helped the kid and it knew EVERYTHING kinda like kieth, just thought the name of the robot would also be a cool name for that phrase under his user name. phew that took alot longer than i thought to explain
McJamweasel
BCF Junkie
PostPosted: 22:46 - 01 Aug 2002    Post subject: Reply with quote
Dude, it was Flight of the Navigator and hell yeah!!
I remember sittin in the pictures with my older bro and I was holding some bandage on my forehead to mop up the blood from where I crashed my (push)bike earlier that day.
chunkielad
PostPosted: 22:51 - 01 Aug 2002    Post subject: Reply with quote
The ship was dubbed Max by the boy - Davey and it spoke to him through RALF (Robotic Assistant Labor Facilitator) a Robot owned by NASA.
So I rekon you meant MAX
Robby
Dirty Old Man
PostPosted: 23:49 - 01 Aug 2002    Post subject: Reply with quote
what a film..
"i don't leak, you leak"
WildGoose
White Van Man
PostPosted: 00:40 - 02 Aug 2002    Post subject: Reply with quote
lol yeah
retrofly
PostPosted: 18:05 - 02 Aug 2002    Post subject: Reply with quote
hi
yo scott, i agree with kris its nice to see a new NSR rider on the forum most peeps seem to be getiing older and buying bigger bikes
Luke
"The food was not undelicious"
-Homer Simpson (Exceptional beast : Underachiving Human)
www.geocities.com/retrofly
The last post was made 23 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 126.61 Kb
