Snapped head bolt
vt6
PostPosted: 13:28 - 30 Mar 2010    Post subject: Snapped head bolt Reply with quote
Alright chaps, I've managed to snap a head bolt on my 1200 bandit whilst swapping downpipes. Not a lot of room around them to work, what do you find the best way to remove it?
Thanks in advance
Robby
Dirty Old Man
PostPosted: 13:58 - 30 Mar 2010    Post subject: Reply with quote
Depends on how it snapped.
Is there is still some sticking out, the lots of penetrating oil is your friend, then try to unscrew it with mole grips. I've found before that despite appearing seized solid, the action of snapping tends to shock it out a bit.
Otherwise, you'll probably need to the pop head off and drill it out. If you don't have a drill press and the patience to use it properly, take it to an engineering place.
I spent most of sunday drilling a couple of snapped off exhaust studs out of a cylinder head, then running a tap down the threads to clean them up. Not a job to do quickly.
Barry_M2
PostPosted: 14:51 - 30 Mar 2010    Post subject: Reply with quote
If there is still enough of it showing, get a stud remover on it.
If it snapper off flush with the head, drilling it out is your only option really!
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
MaybeGuy
PostPosted: 15:05 - 30 Mar 2010    Post subject: Reply with quote
get a left handed drill bit and start drilling.
Most of the time when you get a bit of depth it unscrews itsself.
Barry_M2
PostPosted: 16:18 - 30 Mar 2010    Post subject: Reply with quote
Vincent wrote:
Apart from spark erosion Wink
Well, in reality drill is the only option. How many people are likely to have a spark eroder in their home garage? Wink
temeluchus
PostPosted: 17:21 - 30 Mar 2010    Post subject: Reply with quote
Deffo. Most straightforward way when its snapped close or flush to the head.
The last post was made 16 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 62.94 Kb
