| smegballs |
 smegballs World Chat Champion
| finpos |
 finpos World Chat Champion
| smegballs |
 Posted: 11:21 - 30 Mar 2010 Post subject: |
The bike was running fine, then started cutting out in the wet which lead my mate to put it away for about a month. We tried to start it a few days ago and after a lot of failed bumping found it had no spark.
With the coil unplugged, and the clip attached to the frame/ground, the probe lit up when touched to the coil's positive feed.
Then with the clip attached to the battery positive the probe lit up in short pulses when attached to the coil negative (controlled by the TCI) and the engine cranked.
From this there is definitely some pulse of some description leaving the TCI, so I there should be some sort of spark, even if the spark timing was wrong for whatever reason.
I did try the end of the spark-plug in the HT lead with no cap but that didn't give some much as a flicker either.  |
| Vincent |
 Vincent Banned
| chris-red |
| Frost |
 Frost World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 14:48 - 30 Mar 2010 Post subject: |
Ah right, not an SRX600 then. I wish people would state what bike it's for, makes things a bit easier  |
| finpos |
| Frost |
 Posted: 15:21 - 30 Mar 2010 Post subject: |
| temeluchus |
| smegballs |
 Posted: 01:37 - 31 Mar 2010 Post subject: |
I've got a GS 500 coil around in one of my spares boxes, I'll give that a go.
The SRX4 coil has an integral HT lead so if the HT lead is fucked it means the coil is scrap  |
| Vincent |
 Vincent Banned
The last post was made 16 years, 92 days ago. Instead of replying here, would creating a new thread be more useful? |
