When overtaking...
Ditto
PostPosted: 21:33 - 05 Apr 2010    Post subject: When overtaking... Reply with quote
...what do you normally do? Generally on NSL roads at about 60mph if there are 2 or more cars ahead and im in 6th, I go down 2 gears to 4th and open the throttle to get past quick. There isnt really enough pull in 6th to get past at that speed. Mirrors and signals too obviously.
Once past the cars and pulled back in kick back into 6th. This is on a Bandit 600, imagine its probably pretty similar for others on 600s?
So, how do you like yours?
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
swiftb
PostPosted: 21:42 - 05 Apr 2010    Post subject: Reply with quote
I dont overtake I just ride over the top of any cars in front.
Welshd1k
PostPosted: 21:43 - 05 Apr 2010    Post subject: Reply with quote
drop it into second and hoon it to the redline. pull back in drop it into 3rd or 4th
Alexio
PostPosted: 21:48 - 05 Apr 2010    Post subject: Reply with quote
On my CG if I wanted to overtake some cars at 60MPH I would wait until I was going downhill (if possible), stay in 5th gear (4th tops out at 65MPH, so I might change down to begin with sometimes).... pin the throttle.... wait 20 seconds to hit somewhere close to 70MPH, pray the engine doesn't explode and then pull back in once I've eventually passed them.
And then most likely just get overtaken again the next time we hit a hill Neutral
Or even worse watch the cars just zoom off in to the distance the second I pull out because they can see what I'm trying to do.
Crying or Very sad
instigator
PostPosted: 22:05 - 05 Apr 2010    Post subject: Reply with quote
Keep it in whatever gear I'm in (usualy top) and roll on/off the throttle as required. I don't find I ever need to put it down a gear to overtake when I'm doing 60mph+ on my gsxr1000. And if I did, I'd imagine it'd be a pretty dangerous overtake.
PostPosted: 22:05 - 05 Apr 2010    Post subject: Re: When overtaking... Reply with quote
It all depends on the space available etc.
If it's under 80mph or so and I want maximum go I may well drop it to first with the GSXR.
However, even at 40mph it still has enough go to over take faster than most car can accelerate in gear when it's the bike's in top gear.
Villers
PostPosted: 22:24 - 05 Apr 2010    Post subject: Reply with quote
Would have to agree with G here. The gear or the car in front is normally pretty irrelevant if I want to get past, quarter turn of the throttle in sixth at 60mph is still pretty impressive, full turn at a ton in sixth is even better though Laughing
Ditto
PostPosted: 22:26 - 05 Apr 2010    Post subject: Reply with quote
I think thats probably one of the areas the difference between a 600 and a 1000 can really be seen. Or a 1300 going by your signature Smile
PostPosted: 22:33 - 05 Apr 2010    Post subject: Reply with quote
Aye but a stockish 'busa is only coming on cam in top at 135-140mph, I think they did it to show the EVO boys what's what Smile
Wilson1234
PostPosted: 22:34 - 05 Apr 2010    Post subject: Reply with quote
I do this while doing a front and back stoppie, blindfolded
These MC's wanna diss my baby mum
You're so lucky that I don't have a child
Swear to God, would've gone WILD, bust a mans face off the bathroom TILES
It's still a case of adapting to your situations - do you want all out go (in which case you don't want to choose a generic gear, you want the right one for your speed) or a leisurely cruise past.
Oh and missed zoidburg's post - you put it down a gear or siz so it's not a dangerous overtake Smile.
Villers
PostPosted: 22:39 - 05 Apr 2010    Post subject: Reply with quote
Very Happy
cyberglass
PostPosted: 00:31 - 06 Apr 2010    Post subject: Reply with quote
dl 650 i would drop it to 5th
R1 id just turn the throttle and hold on as tight as i can and hope i dont fall off the back Twisted Evil
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
binge
Emo Kiddy
PostPosted: 00:37 - 06 Apr 2010    Post subject: Reply with quote
Depends what bike im on, And what mood im in. What car im following etc.
If I'm on the TZR pit bike, I can overtake up to about 70mph, Then it gets a bit slow, And end up creeping past cars, And looking like a knob.
60mph, and there abouts, I can kick it into 4th, And get a pretty fast overtake.
I make sure to look at the driver im overtaking though, most of the time they have to double take, to make sure what they are seeing is legit! Laughing
On the TLR, up to about 70mph, I had a bad habit of clutching it up in second to overtake. Again, Entirely depends on the location.
Ben
Towton 1461
PostPosted: 01:44 - 06 Apr 2010    Post subject: Reply with quote
Open the throttle. Close my eyes. And hope for the best.
What else can you do?
This post is sponsored by QUILLIES LOZENGES. Suck QUILLIES for fast throat relief!
Meshuggah
PostPosted: 02:31 - 06 Apr 2010    Post subject: Reply with quote
that's how i do it
https://www.youtube.com/watch#!v=GiWIGRcKlew
the end.
Triumph Tiger 800 2012
Frost
PostPosted: 02:36 - 06 Apr 2010    Post subject: Reply with quote
Around here the roads are too twisty and with too much stuff coming the other way for a standard overtake. I normally drop back a bit before a tight corner, take it faster than them so i'm on the power and along side them 10 meters after the corner if safe to do so. Occasionally i have to slow down pretty quick if theres something coming the other way. If i get it right i can be past someone and back in the correct lane in 2 seconds.
The Tot
PostPosted: 07:05 - 06 Apr 2010    Post subject: Reply with quote
NSL at 60 i'doing about 4k rpm in top, I usually drop it to 4th and make a clean & prompt move. Otherwise, I'd pull back on the throttle and wait a good 1-2 seconds for it to spin up and by 7-8k, it's spinning up nicely and doing 100mph. That's the option I take if there's multiple cars I want to block overtake on a straight road and the opposite lane is clear. I'm normally in the centre of the opposite lane for visibility rather than on the centreline of the road.
Never argue with autism
Clanger
Stirrer
PostPosted: 19:34 - 06 Apr 2010    Post subject: Re: When overtaking... Reply with quote
If it's under 80mph or so and I want maximum go I may well drop it to first with the GSXR. However, even at 40mph it still has enough go to over take faster than most car can accelerate in gear when it's the bike's in top gear.
I agree with what G says...(except I don't have a GSXR) Smile
The last post was made 16 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 102.32 Kb
