wont start when hot
devonshireboy
PostPosted: 19:42 - 06 Apr 2010    Post subject: wont start when hot Reply with quote
Crying or Very sad . hi all, i have a kwak gpz 500s ex a model .now a few months a go down the bottom half the engine up, got a new battery no probs started up went well , so turn the engine off to take her for a run so turn her off to dress up went to start her an click click bloody hell now what went through my mine .so check all the charging with meter ok batt reading 12.3 volt so put the batt on my car charger for 5 mins tryed her again started no probs. stop the engine tried again click click change the solanoid an the regulator just in case still the bloody same. so can some please please help me out . cheers paul[/b]
yen_powell
PostPosted: 19:56 - 06 Apr 2010    Post subject: Reply with quote
Pardon?
XT1200Z and a DR350 in bits
Villers
Could still be the battery IMO. Had a very similar problem with my Hayabusa when I first bought it. It would start in the morning and when I came out of work at night but then if I stopped on the way home it wouldnt restart, would often just click and reset all the clocks. Often when left five or ten mins it would start as long as I turned on the ignition and did a quick start, i.e not leaving the ignition on while I was putting my gloves on. I went out and got a new gel battery with a massive current output and never had the problem again!
That_Hornet
PostPosted: 20:06 - 06 Apr 2010    Post subject: Reply with quote
Check it, take the battery off and charge it fully. Leave it for 24 hours and check the voltage.
Should be 12.7 or 12.8
Anything less is Thumbs Down Wink
HTH
or just change the battery for the sake of £30
PostPosted: 23:40 - 06 Apr 2010    Post subject: Reply with quote
From what I can decipher from that gobbldegook, your GPZ wont start and is clicking when you try to do so?
Find the starter solenoid (follow the big fat wire from the battery positive, the solenoid is on the other end of it, under one of the side panels). On the side of the solenoid is a connector block holding the main, 30A fuse. Pull this off and check the condition of the terminals and wires leading into it. Especially the fat white wire attaching to the main fuse.
This wire is really prone to corrosion where it attaches to the fuse. If the terminal is all green and shitty and the fuse terminal looks like it's been nibbled away, suspect this as your problem. That wire carries all the power to both the bike and the battery.
This post was brought to you today by hours of head scratching at the side of the road and years of experience of riding kawasaki 500 twins.
lil3600
PostPosted: 19:57 - 08 Apr 2010    Post subject: non starter Reply with quote
i had similar,with a pan european...would start fine ..go for a ride...would not start,if bike was left a while..then bike would start...
i was told to clean /tighten battery terminals and the battery ,,, look for any corrosion...maybe the earth in this case....... done this and bike was fine......not sure for your model weather lights come on with ignition...then you start the bike.. or maybe you switch the lights on when bike is running?? if battery is low ,then lights on with ignition will draw a little more power away from the starting of the bike
cloric_tzr
PostPosted: 19:59 - 08 Apr 2010    Post subject: Re: wont start when hot Reply with quote
yea seriously mate just out of intrest what the hell did u say in the 1st line? i understood the rest
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
Damon
PostPosted: 20:36 - 08 Apr 2010    Post subject: Re: wont start when hot Reply with quote
Crying or Very sad . hi all, i have a kwak gpz 500s ex a model .now a few months a go down the bottom half the engine up, got a new battery no probs started up went well , so [/b]
I think it was
hi all, I have a Kawasaki GPZ 550 EX model...
Nope, got the better of me. No clue either, something about a sparrow wearing slippers I think Neutral
The last post was made 15 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 58.43 Kb
