| -Ali- |
 -Ali- Trackday Trickster
| el_oso |
 el_oso World Chat Champion
| -Ali- |
 Posted: 14:13 - 04 Apr 2010 Post subject: |
Do you know someone with ubuntu?
If you do, they can make you a bootable flash stick using an admin tool that comes for that exact purpose.
Failing that you need to download the appropriate image file from Ubuntu. It will end in .iso.
To make an install disc, you need to be able to burn a bootable disc. You may need third party software to do this in windows (like nero). You have to burn the CD as an image, not a data file.
You should really check the MD5 Checksum to make sure the file is "good" but again, you'd need additional software to do it in windows. It's not strictly necessary if you trust where you downloaded it from.
Once it's burned, put it in and switch it on. It'll come up with a menu. I'd do a disc integrity check first off. Then I'd suggest trying it running as a live CD. The Ubuntu operating system will load up from the CD and you can have a play with it without changing anything permanant on your computer.
Once you're happy, there is an option to install Ubuntu. Click, follow instructions. If in doubt when it asks a question, go with what it suggests or what seems a sensible answer.
Once it's up and running, as said, install the restricted extras. You may need to go System > Administration > Software sources and under the "Ubuntu Software" tab, check the main, universe, restricted and multiverse boxes before you can do this. (Don't panic. It's all about American copyright laws and that Ubuntu only ships with open source software.. which adobe flash player isn't).
I don't think you can (easily) run safari but there is a selection of other browsers to choose from if you want. Ubuntu has firefox as an integrated part of the system though and it works well. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| neil. |
 neil. World Chat Champion
 Posted: 15:01 - 04 Apr 2010 Post subject: |
What you want to do is certainly possible. The only bit that will take some work to get going will be Spotify which does not have a native Linux version, so it needs to run under a Windows compatibility layer, called Wine, which you must also install.
As for Safari, the closest you'd get would be Epiphany, which is based on the same rendering engine (under the bonnet software that does all the work with loading and displaying webpages), Webkit, and would render pages in a very similar fashion with excellent performance, way above Firefox's.
If you can, hold off until the 29th of April as a new Ubuntu release is scheduled and it will be a Long Term Support version with 3 years of updates (usual releases have 18 months of support). At this point in time, there's little point to setting up a system with the current version, unless you're just messing about with it.
If you do plan to play with it now, which is a good thing, check out https://help.ubuntu.com/9.10/index.html  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| -Ali- |
 Posted: 16:43 - 04 Apr 2010 Post subject: |
| neil. wrote: | What you want to do is certainly possible. The only bit that will take some work to get going will be Spotify which does not have a native Linux version, so it needs to run under a Windows compatibility layer, called Wine, which you must also install.
If you do plan to play with it now, which is a good thing, check out https://help.ubuntu.com/9.10/index.html  |
Cheers neil, any links to what the new version is going to be like? |
| Pernig |
 Pernig World Chat Champion
 Posted: 13:44 - 07 Apr 2010 Post subject: |
Once you're up and running, here's how I got on installing Spotify on Wine. I find Spotify runs very well on Wine.
You may find, depending on your hardware, that it works better with OSS or ALSA, or only works with one (you will understand what I'm on about once you've read through the link). ____________________ H100 Breaking for spares |
The last post was made 16 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
