| Blue_SV650S |
 Posted: 20:36 - 07 Apr 2010 Post subject: Fork me seals |
I have done 3 days out on my KTM now and it is a great bike to ride
But its running/maintenance costs are hideous!!
Basically I replaced the fork seals for genuine KTM seals and after 3 days laning they are fecked!!!
Now I know 'laning is a bit harsh on components, but how long are your seals lasting??
p.s. there is no obvious signs of damage or pitting to the stanchions ... ____________________ The purpose of life is to fight maturity. |
| silky666 |
 silky666 Captain Rulebook
| G |
 G The Voice of Reason
| Blue_SV650S |
 Posted: 21:02 - 07 Apr 2010 Post subject: |
I did smack pretty hard into a log/step down water lane ... I wonder if I 'popped' the seals there ...
G, I know I squeak when I walk, but 3 rides from some genuine seals takes the p1ss!!
Changing seals is a right PITA ... that is why I went for proper (and expensive) KTM ones ... not some cheap ebay ones or something ... ____________________ The purpose of life is to fight maturity. |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:23 - 07 Apr 2010 Post subject: |
my guess is neither judging by his ''expertise'' ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Blue_SV650S |
 Posted: 21:54 - 07 Apr 2010 Post subject: |
They're upside downies on a KTM aren't they?
Lots of sharp edges to catch a seal on while fitting them. Very, very easy to damage the lip of the seal on any of the parts it goes over (the end of the stanchion and the recess where the bushing was removed from). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Blue_SV650S |
| Blue_SV650S |
 Posted: 20:15 - 10 Apr 2010 Post subject: |
Right, took the forks apart today, long story short, muck had got past the dust seals (not that surprising as I hadn't replaced them) - now the dust seals were not torn, so clearly they will prevent larger particles from passing, but there was other grit/sh1t/grime/slime behind it and therefore some of it had made its way into the seals.
Anyway, after disassembling the forks and taking the seals out (presuming they would need to be replaced), they actually looked in good condition, with sharp edges, the lot!! ... so I wiped away any muck that was on the seal, slid back over the stanchion and tested their 'wiping' ability ... sure enough they were NOW wiping the stanchion clear!!
So re-assembled and tested with the forks full of oil and under pressure (bounce up and down) - sure enough they were working again!!
Anyway, bought some of these to prevent it happening again (HOPEFULLY)!!
KTM NEOPRENE FORK GAITORS https://shop.jimaimracing.co.uk/acatalog/Fork_Gaitors.html#a59504090050
So basically the seals were ok, but where they had some muck in them, they were not sealing properly and therefore weeping.
I haven't tested the bike properly yet, but the 'bounce test' is showing perfect results (the bounce test was clearly leaving oil residue before with only 2-3 bounces, I can now do 20 and there is essentially NONE!! ).
So fingers crosses the neoprene gaitors will keep the crud off. Lets face it, muck now has too get past the neoprene AND the dust seal to get into the oil seal, so it has its work cut out!!  ____________________ The purpose of life is to fight maturity. |
| G |
| Blue_SV650S |
 Posted: 22:25 - 10 Apr 2010 Post subject: |
| G |
 Posted: 22:52 - 10 Apr 2010 Post subject: |
I presume you do have front fork protectors?
Oh and you could always use a re-usable cable tie . (Or be ultra-cheap like me and re-use normal cable ties!) |
| Blue_SV650S |
The last post was made 16 years, 200 days ago. Instead of replying here, would creating a new thread be more useful? |
