Fork me seals
Blue_SV650S
PostPosted: 20:36 - 07 Apr 2010    Post subject: Fork me seals Reply with quote
I have done 3 days out on my KTM now and it is a great bike to ride Thumbs Up
But its running/maintenance costs are hideous!! Shocked
Basically I replaced the fork seals for genuine KTM seals and after 3 days laning they are fecked!!! Shocked
Now I know 'laning is a bit harsh on components, but how long are your seals lasting?? Thinking
p.s. there is no obvious signs of damage or pitting to the stanchions ...
silky666
Captain Rulebook
PostPosted: 20:55 - 07 Apr 2010    Post subject: Reply with quote
I get through 2 or 3 sets a year.
1) Before replacing them, try the feeler guage method.
(has worked numerous times for me)
2) Spend £20 on some 'seal savers'
(Kreiga ones look best).
3) Its not always the stanchions ... someone told me that if the bushes are worn / teflon coat gone .. then that can make the seals wear and leak.
PostPosted: 20:56 - 07 Apr 2010    Post subject: Re: Fork me seals Reply with quote
A lot longer than that, including Hare and Hounds, enduro practices etc.
Sounds like there's a problem somewhere (slightly bent fork?)
Still stop moaning, there are cheaper hobbies as I mentioned elsewhere Wink:
https://1.bp.blogspot.com/_BouOpfHoYlU/STQIDCc6FtI/AAAAAAAABWE/hYX_WxYfkkA/s400/knitting.jpg
Blue_SV650S
PostPosted: 21:02 - 07 Apr 2010    Post subject: Reply with quote
I did smack pretty hard into a log/step down water lane ... I wonder if I 'popped' the seals there ... Confused
G, I know I squeak when I walk, but 3 rides from some genuine seals takes the p1ss!! Shocked Crying or Very sad
Changing seals is a right PITA ... that is why I went for proper (and expensive) KTM ones ... not some cheap ebay ones or something ...
PostPosted: 21:22 - 07 Apr 2010    Post subject: Reply with quote
Wonder if you nicked them putting them on?
Did you tape up the end of the stanchion or use a seal bullet to slide them over initially?
https://www.motionpro.com/images/items/08-0276.jpg
MaybeGuy
PostPosted: 21:23 - 07 Apr 2010    Post subject: Reply with quote
my guess is neither judging by his ''expertise''
Blue_SV650S
PostPosted: 21:40 - 07 Apr 2010    Post subject: Reply with quote
It is possible, but for me to damage BOTH of them would be pretty unlikely (and they did seal perfectly at the start).
I don't use a gadget to get them on, no, but I have done what must be dozens of them now and simply 'lube' them nicely and make sure they are slid on gently - has never failed me yet Thumbs Up
I think it would be blatantly obvious to me if I had shaved an edge off them on assembly.
PostPosted: 21:54 - 07 Apr 2010    Post subject: Reply with quote
They're upside downies on a KTM aren't they?
Lots of sharp edges to catch a seal on while fitting them. Very, very easy to damage the lip of the seal on any of the parts it goes over (the end of the stanchion and the recess where the bushing was removed from).
Blue_SV650S
PostPosted: 22:14 - 07 Apr 2010    Post subject: Reply with quote
Yep, USD, but I think I would have noticed any slithers of seal if I had shaved them off. I am/was very careful when going over edges and always lube well Thumbs Up
To be fair, what I didn't do is replace the dust seals at the same time. I would expect this to mean more premature wear ... but again, 3 rides?!!? (it is not like the dust seals were totally fecked) Confused
Blue_SV650S
PostPosted: 20:15 - 10 Apr 2010    Post subject: Reply with quote
Right, took the forks apart today, long story short, muck had got past the dust seals (not that surprising as I hadn't replaced them) - now the dust seals were not torn, so clearly they will prevent larger particles from passing, but there was other grit/sh1t/grime/slime behind it and therefore some of it had made its way into the seals.
Anyway, after disassembling the forks and taking the seals out (presuming they would need to be replaced), they actually looked in good condition, with sharp edges, the lot!! Thinking ... so I wiped away any muck that was on the seal, slid back over the stanchion and tested their 'wiping' ability ... sure enough they were NOW wiping the stanchion clear!! Shocked
So re-assembled and tested with the forks full of oil and under pressure (bounce up and down) - sure enough they were working again!! Cool
Anyway, bought some of these to prevent it happening again (HOPEFULLY)!! Wink
KTM NEOPRENE FORK GAITORS https://shop.jimaimracing.co.uk/acatalog/Fork_Gaitors.html#a59504090050
So basically the seals were ok, but where they had some muck in them, they were not sealing properly and therefore weeping.
I haven't tested the bike properly yet, but the 'bounce test' is showing perfect results (the bounce test was clearly leaving oil residue before with only 2-3 bounces, I can now do 20 and there is essentially NONE!! Cool).
So fingers crosses the neoprene gaitors will keep the crud off. Lets face it, muck now has too get past the neoprene AND the dust seal to get into the oil seal, so it has its work cut out!! Razz
PostPosted: 21:57 - 10 Apr 2010    Post subject: Reply with quote
Apparently you do need to be careful and check the neoprene ones after every ride you've been in deep water as they can trap water in there.
Blue_SV650S
PostPosted: 22:25 - 10 Apr 2010    Post subject: Reply with quote
I did wonder if they would hold more muck in than they would keep out!! Very Happy
I also presumed that like a wetsuit, they would let water in and potentially cause water related problems ...
However, they are only cable-tied on ... so simply snipping and replacing a cable tie every ride is no great issue!! Thumbs Up
I have no idea how durable they are going to be, but at £22 for some poxy neoprene sleeves, they better last a few rides!! Shocked
PostPosted: 22:52 - 10 Apr 2010    Post subject: Reply with quote
I presume you do have front fork protectors?
Oh and you could always use a re-usable cable tie Smile. (Or be ultra-cheap like me and re-use normal cable ties!)
Blue_SV650S
PostPosted: 23:22 - 10 Apr 2010    Post subject: Reply with quote
The standard plastic ones you mean??? Yes.
Oh and for ultimate re-usability, I could always just tie a shoelace round it!! Laughing
The last post was made 16 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 2.02 - MySQL Queries: 13 - Page Size: 87.31 Kb
