best free method of cleaning please
badas
PostPosted: 01:39 - 11 Apr 2010    Post subject: best free method of cleaning please Reply with quote
hi all, just wanting to know the best and free way of cleaning an air filter??
simple case of using warm water?
ty
alun111
PostPosted: 01:49 - 11 Apr 2010    Post subject: Reply with quote
If it's a foam type then clean it with petrol and then once dry drip some oil on it and then squeeze it.
If it's card type then use compressed air.
baldy
PostPosted: 02:01 - 11 Apr 2010    Post subject: Reply with quote
If it's a foam filter, i just use hot water and lots of washing up liquid. If you put loads on the filter and squeeze it in, it gets it spotless.
Petrol is too expensive these days to be wasting on a filter.
One day i will rule the world, just not today.
neil.
PostPosted: 07:32 - 11 Apr 2010    Post subject: Reply with quote
Depending on the bike, it might be that you aren't meant to oil the sponge filter after cleaning. The YBR has a paper element and sponge element. I personally use compressed air on the paper part and a can of Putoline filter cleaner on the sponge bit, but might try soapy water next time. Thumbs Up
Robby
Dirty Old Man
PostPosted: 09:57 - 11 Apr 2010    Post subject: Reply with quote
Foam filters are traditionally cleaned with petrol, although it works out cheaper these days to use a can of proper foam air filter cleaner (mine cost a fiver for a big spray can). You could also clean them with white spirit. No need to waste the solvent, after cleaning duties I pour the dirty solvent into my waste solvent drum, where it will be used to clean tools and start fires in the future.
when I get really desperate I'll probably even try filtering it through kitchen roll and seeing if I can get a bike to run on a mixture of petrol, white spirit, meths, and accumulated amounts of oil, dirt and water.
After cleaning and fully drying. The fully drying bit is very important here. Oil it. Traditional things is two stroke oil, then squeeze out the excess so you have a wet feeling but not dripping bit of foam, then slide the foam back over the metal assembly without ripping it.
You can also oil with a proper air filter oil, again a big can of it for foam filters cost me about £5 and lasts for ages. The oil is far stickier than 2-stroke.
badas
PostPosted: 12:58 - 11 Apr 2010    Post subject: Reply with quote
i am asking for a honda mtx 125,
its foam filter
i have read that petrol messes with the foam making the wholes expand or what ever :S?
also the air filter box connects to the carb by a rubber hose, am i best off tkaing this off of hte bike and clean hte air filter box and hose also?
ty
alun111
PostPosted: 14:33 - 11 Apr 2010    Post subject: Reply with quote
If it's been used off road, I would.
badas
PostPosted: 21:54 - 11 Apr 2010    Post subject: Reply with quote
may have been a long time ago before i bought it, iel give it a good cleanout then Smile ty
The last post was made 16 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 54.55 Kb
