Bike fell over some time last night.......
Tom C RX50
PostPosted: 16:07 - 12 Feb 2006    Post subject: Bike fell over some time last night....... Reply with quote
Heya, got woke up by my dad this morning at 8am as he came in to tell me my bike was on its side out the front of the house. I jumped out of bed, ran outside in the rain in my boxers and picked it straight up. Gave it a quick look over and fortunately there was only a scuff on the hand guard and on the handle bar end, thankl god i chose a crosser.
Just wanted to know, as it could have been on its side for 8hours or so, will anything engine wise of been damaged, fluids leaking etc, it was raining a lot and there was petrol spill in the gutter, so what should I check?
Cheers Tom
**FOR SALE** Aprilia RX50, full system gianelli exhaust, 70cc MK big bore, MK pro race filter, 20mm Dellorto carb, aftermarket sticker set, small plate, carbon look indicators, new rear tyre, years tax and mot, new chain and sprockets, very fast bike. 1200 ono **FOR SALE**
phantomtek
Lil Joe Tek
PostPosted: 16:26 - 12 Feb 2006    Post subject: Reply with quote
First off, unlucky man, I know how you feel as my crosser went over a while ago in similar conditions, the sidestand wasn't too good. Fortunately it escaped with minor scuffs and a broken gear lever. If it was an RS50 it would have been so broken Laughing
All I can think of is to check the crank casing for any damage, hole etc (which I doubt there'll be) and just leave it for a few hours upright to let all the fluid return to it's normal position. It's likely that only the engine is flooded and not much else, in my experience.
Karma
0ddball
PostPosted: 16:29 - 12 Feb 2006    Post subject: Reply with quote
If it starts ok it should be fine.
Are you sure it fell? Or could it have been an attempted theft? They often go out on the rob on windy nights to disguise the noise.
Tom C RX50
PostPosted: 16:33 - 12 Feb 2006    Post subject: Reply with quote
Well is wud of fell over as i wont even say how rediculously easy it wud be to steal my bike. Had no locks on it last night, and the fact u can turn the ignition with a penny Embarassed well i got it upright, left it for 5 mins or so, started 2nd kik, im gunna give it another check over for cracks and stuff like that, but yer if it was an rs50 thats like 200+ damage, lol. Sportsbike fools
edit, from now on its gunna be garaged every night with all 6 locks I have Laughing
0ddball
PostPosted: 16:40 - 12 Feb 2006    Post subject: Reply with quote
What did you say your address was again? Very Happy
doggone
PostPosted: 19:35 - 12 Feb 2006    Post subject: Reply with quote
Have a look at battery.
May have spilled acid - wash off ASAP.
Batt may need top up with distilled water if levels are down.
lllN30lll
PostPosted: 20:03 - 12 Feb 2006    Post subject: Reply with quote
bloody hell, if i was your dad and i saw your bike on it's arse i'd go outside and pick it up straight away, i wouldn't go fetch you Laughing
Turbo R1
CRF450R
Tom C RX50
PostPosted: 00:09 - 13 Feb 2006    Post subject: Reply with quote
tell me about it, lol, oh well, there was no damage done at all but my bike is running like a bag of shit at the moment. its running like it did when it needed a new spark plug, not sparking properly and missfiring all the time, will barely run at all, and when it does get going it does the old jerk as if you ran out of petrol, just jerks along.
What do you think this could be? my guess is shit loads of water as it was on its side all night in the pissing rain...Im guessing leave it a few days to settle and dry off?
Cheers Tom C
Rookie
PostPosted: 00:15 - 13 Feb 2006    Post subject: Reply with quote
Possibly the engine oil has been sloshed to one side of the engine? I know if you leave a bike sat for too long, the oil tends to 'pool' at the bottom, so you should start it every week or so. It could be that.
Otherwise, being on its side could have brought up some sediment, so perhaps flushing your tank is in order. Might as well shove some Redex in there too. Mr. Green
If it's running like it did when your spark plug needed replacing, it's probably worth checking the spark plug too. Razz
Tom C RX50
PostPosted: 00:22 - 13 Feb 2006    Post subject: Reply with quote
good point, what is this redex stuff? is that the stuff to remove water from the petrol? or am i way of the mark with that guess?
Cheers, Tom C
LUXY DJ
PostPosted: 00:25 - 13 Feb 2006    Post subject: Reply with quote
i think it flooded over through the carbs so try tomorrow & it SHOULD be how it was before(however that was)
other stuff has proberly been sloshed around but the flodding would be the main issue 100%
GSXR750
Tom C RX50
PostPosted: 00:34 - 13 Feb 2006    Post subject: Reply with quote
cheers guys, i will try it tomoro, im off on holiday for 5 days at 10am tomoro so i will chek and if not it has 5 days to settle down till i am back to work.
Rookie
PostPosted: 00:55 - 13 Feb 2006    Post subject: Reply with quote
Redex flushes crap out of your carbs, it's a good policy to use it every couple of weeks. Cheap too. It's my generic cure for anything mechanical. Laughing
LUXY DJ
PostPosted: 01:09 - 13 Feb 2006    Post subject: Reply with quote
when did you last try it? like how many hrs ago? & was it still shitty?
cause when iv dropped mine it flooded & i had to leave it for about 15-20mins & it was BETTER then it kinda went
cant you take your airbox off the carb/s & see/listen to see if its hissing or bubbling?
GSXR750
There is a gap of 4 years, 58 days between these two posts...
wrightson93
PostPosted: 17:30 - 11 Apr 2010    Post subject: Reply with quote
my RX50 fell over aswell .. do you have a center stand because thats what i believe is the main problem with windy days... i managed a cracked back ferrin and tail light Sad. As im a girl i have many boy's to run arround after me and fix it Very Happy
kerry
PostPosted: 17:36 - 11 Apr 2010    Post subject: Reply with quote
Oh no, that's TWO RX50s that have fallen over in 4 years!!! Maybe the manufacturer should be informed, they might do a recall.
chrisw
PostPosted: 18:45 - 11 Apr 2010    Post subject: Reply with quote
No it's not, it's a waste of money as are most fuel additives and all oil additives. If your carbs need cleaning, take them off and clean them.
mistergixer
PostPosted: 19:09 - 11 Apr 2010    Post subject: Reply with quote
Whilst i agree with your statement, i doubt they can hear you back in 2006. I don't think you need Redex or carb cleaner, i think you need a flux capacitor and a DeLorean.
Space Monkey #7
MinhDinh
PostPosted: 19:37 - 11 Apr 2010    Post subject: Re: Bike fell over some time last night....... Reply with quote
Cheers Tom
I dropped it and was hiding in the bushes watching you in your boxers my friend Smile
I knew nothing would happen to the bike, all you need to do is let the petrol get back to normal and start it. Sorry if you were cold
Hit the G spot. Wink
yuri2085
PostPosted: 20:27 - 11 Apr 2010    Post subject: Reply with quote
Perhaps some water in the petrol tank? That isn't very good for it I am told. Maybe drain it and get some new fuel.
chrisw
PostPosted: 22:27 - 11 Apr 2010    Post subject: Reply with quote
Laughing That'll learn me!
The last post was made 16 years, 170 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 113.76 Kb
