brake lever dial
lee8040
PostPosted: 17:27 - 13 Apr 2010    Post subject: brake lever dial Reply with quote
the dial on the brake lever number 1-5. is number 1 to have the brakes sharper with less play in the lever or is number 5?
yuri2085
PostPosted: 17:30 - 13 Apr 2010    Post subject: Reply with quote
Turn it to 1, press the brake.
Turn it to 5, press the brake.
See which one has more play/reach(edit Razz )
In my defense, I wasn't actually suggesting I knew anything about the subject, only had the information he gave me plus a brain.
tutton
PostPosted: 17:33 - 13 Apr 2010    Post subject: Reply with quote
How fast before the brakes activate
1 means the lever comes in very slightly and brakes hard
5 means lever comes in quite a far way and can be used for much slower progressive braking
or thats how the fzr and zx6r work.
The Tot
PostPosted: 17:56 - 13 Apr 2010    Post subject: Reply with quote
Effectively... yes
I use it to compensate for brake fade... usually when pads get thinner or fluid needs flushing. Midpoint setting is a good datum since you can always make adjust the span to take up the slack in the system.
Never argue with autism
Noxious89123
PostPosted: 19:53 - 13 Apr 2010    Post subject: Reply with quote
What are you lot on about Confused
It just adjusts the reach of the lever, not the sensitivity or how far you have to pull it before the brakes bite. Laughing
The last post was made 16 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 44.1 Kb
