TPS on a Carb
Ichy
PostPosted: 14:57 - 14 Apr 2010    Post subject: TPS on a Carb Reply with quote
What does the throttle position sensor do on a carbed CBR600?
What happens if you disconnect it?
I can understand on a FI that it would be used to control the fuel or air flow but on a carbed bike?
PostPosted: 15:16 - 14 Apr 2010    Post subject: Reply with quote
1200 Bandits have them as well (well, on some markets, think the US ones do without them). Not sure exactly what it is used for but my guess would be to change the ignition mapping depending on throttle position.
temeluchus
PostPosted: 15:17 - 14 Apr 2010    Post subject: Reply with quote
It is used in conjunction with the electronic ignition. It will advance and retard the ignition dependant on the throttle postion in order to maximise throttle response.
Leave it connected.
Ichy
PostPosted: 17:33 - 14 Apr 2010    Post subject: Reply with quote
Taking your advice on board I disconnected it and rode 20 odd miles. I can't tell the difference?
baldy
PostPosted: 19:46 - 14 Apr 2010    Post subject: Reply with quote
My old sv650 had one. I disconnected it and rode it for a bit. It ran fine for a few hours then it started to backfire and would cut out if i shut the revs off.
One day i will rule the world, just not today.
andys675
PostPosted: 21:41 - 14 Apr 2010    Post subject: Reply with quote
if you want to feel the difference find yourself a steep long hill and try to get to the top in top gear, then try it with it disconnected
the ignition will adjust to assist you, you need a wide open throttle in a high gear but low engine rpm to feel the difference.
I used gorsty hill in halesowen, 2 up, 6th gear on a hornet, just whack the throttle back at 35-40 mph and it pulls you to the top of the hill without having to change down a gear
The last post was made 15 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 47.99 Kb
