Engine completely failed, no compression
The Artist
PostPosted: 18:12 - 17 Apr 2010    Post subject: Engine completely failed, no compression Reply with quote
This isn't asking for advice just telling you what happened.
Ragging it today on my Gs125, very hot as I had been stationary for a while and had been out a while already.
Anyway, suddenly it died. Pulled over and there was almost no compression.
Wheeled it home where me and Chris took the cam cover off and found that one of the tappets had come loose and the little lock nut had come off meaning the inlet valve was doing nowt.
Popped it back on and it was fine.
Lesson learnt. If valve clearances need doing, check locknut is tight
joan_worthy
PostPosted: 18:20 - 17 Apr 2010    Post subject: Reply with quote
Sound like what happened to me on my cg125... Difference is - i was in motion at the time, doing 'some' speed on an A road at 1am. Scared the shit out of me as the back wheel locked up because the collet dislodged a valve, the piston had smashed the valve completely bending it, knackered the piston which had in turn screwed the barrel...
The Artist
PostPosted: 18:24 - 17 Apr 2010    Post subject: Reply with quote
I was doing 60 round a corner overtaking a mate Laughing
Embarrassing slowing to a stop. Back wheel didn't lock up thank god.
joan_worthy
PostPosted: 18:33 - 17 Apr 2010    Post subject: Reply with quote
Sorry read it wrong, thought you said you were stationary... Lucky you didnt lock up, going round a corner
joan_worthy
PostPosted: 18:43 - 17 Apr 2010    Post subject: Reply with quote
I think my problem wasnt that i had done it wrong... More probable is that its because they were never done... Plus i used to ride it to its limits... Use to do 25 mile trip to work and then back every day at full throttle, pegs to the floor on every corner... You know, the usual stuff
Blue_SV650S
PostPosted: 18:47 - 17 Apr 2010    Post subject: Reply with quote
Surely you should have noticed a gradual power loss as it gently undid, not just a sudden loss!? Confused
27cows
One of the numerous reasons I love 2 strokes Wink
The Artist
PostPosted: 18:49 - 17 Apr 2010    Post subject: Reply with quote
Any tips to make sure locknut doesn't come undone again? It lasted for about 3 months since I last adjusted them, maybe the heat today just loosened it somehow.
I will try and get hold of a couple of nuts exactly the same to lock onto each other sometime but for now what shall I do?
The Artist
PostPosted: 18:53 - 17 Apr 2010    Post subject: Reply with quote
Now that you mention it, I just remembered, for about 200 metres before it happened a tapping noise from the bike. I thought it was my loobman hitting the teeth on the sprocket. Completely forgot about that noise.
The power loss was minimal before hand, like I said I was full throttle overtaking someone round a bend which was fun till power loss. The actual tappet hadn't moved much but the locknut was the problem I think wedging the valve.
27cows
PostPosted: 18:55 - 17 Apr 2010    Post subject: Reply with quote
The obvious answer would be to use Lock & Seal or similar thread locking compound.
joan_worthy
Nope... Held a steady ??mph and all of a sudden the rear locks. The valve had come out of place, dropping into the piston chamber jamming the piston down, all of this happened VERY quickly
The Artist
PostPosted: 19:06 - 17 Apr 2010    Post subject: Reply with quote
Yes but what about the temperature in there? Even after 30 minutes of not running, the inside was still pretty damn hot.
Alexio
PostPosted: 19:15 - 17 Apr 2010    Post subject: Reply with quote
Clearly you require either some blue tac, sticky tape or super glue Thumbs Up
Blue_SV650S
PostPosted: 19:22 - 17 Apr 2010    Post subject: Reply with quote
Tappet locknuts have been around since the dawn of time being ... well just done up, don't see the needs to do anything special to stop it coming undone!! Wink
joan_worthy
A garage had recommended lock-tight to me... Besides most things like that will say what levels of temperature etc they can withstand
neil.
PostPosted: 20:35 - 17 Apr 2010    Post subject: Reply with quote
Very weird, never ever had them work loose on the YBR after lots of miles and adjustments and that's a SOHC as well. I'd just do them up tight but not stupid (thread strippingly) tight.
27cows
PostPosted: 20:41 - 17 Apr 2010    Post subject: Reply with quote
I've used L&S on tappet lock nuts. Maybe the L&S burnt away but the nuts just stayed done up anyway Laughing
Cigaro
PostPosted: 09:26 - 18 Apr 2010    Post subject: Reply with quote
It's happened to me before. I think the locknut must have got wedged under the other rocker arm though as it came out oval-shaped Laughing
The Artist
PostPosted: 12:24 - 18 Apr 2010    Post subject: Reply with quote
It is still confusing me how it came undone. Ah well, I am waiting till it is cool again to adjust because just been to work and they were only set by eye yesterday.
temeluchus
PostPosted: 17:58 - 18 Apr 2010    Post subject: Reply with quote
I wouldnt use any thread lock. The Adjuster and Locknut, I would be tempted to replace as they can wear.
The upside with the oldschool rockers and locknut adjusters is they are more likely to fail like this than go tight and destroy your top end like shim adjusted engines.
The Artist
PostPosted: 16:28 - 22 Apr 2010    Post subject: Reply with quote
Well coming home today it started tapping again so I crawled home at 5mph for the last 2 miles and it didn't get louder. I am going to tighten and then locktite tomorrow and order a new adjuster and locknut when I can.
nightshaddow
PostPosted: 18:16 - 23 Apr 2010    Post subject: Reply with quote
I had a similar problem with my yammy sr, it wasnt the nut coming loose summat had buggered wrecking tappits, i went through 3 in 4 weeks, i sugest you take the head and check everything valves cam rockers, mine turned out the cam had buggered
PostPosted: 18:40 - 23 Apr 2010    Post subject: Reply with quote
Check it every 2 months? Smile
Alexio
PostPosted: 21:17 - 23 Apr 2010    Post subject: Reply with quote
Clearly you require a welding rod Thumbs Up
The last post was made 16 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 124.82 Kb
