RXS Hard to get into neutral
UnspeedySam
PostPosted: 19:22 - 17 Apr 2010    Post subject: RXS Hard to get into neutral Reply with quote
Managed to survive the journey from Essex to Southampton even if it did take me over 4 hours. Got a bit lost in central london and whist trying to find a way from the a31 to southampton without using the m3.
However when I was in london and in stop start traffic, the bike got pretty hot and since then it's been a nightmare to get into neutral. All other gear changes seems to work fine.
Might turn out to be absolutely fine tomorrow when it's cooled down...
27cows
PostPosted: 19:35 - 17 Apr 2010    Post subject: Reply with quote
Yeah, I've had that happen. Many years ago I spent a couple of weeks using the RXS to despatch on, constant stop start for eight hours a day. Was more or less impossible to get into neutral sometimes.
It's possible to sort the problem, but only worth doing if you're going to use the bike like that all the time.
yen_powell
PostPosted: 20:02 - 17 Apr 2010    Post subject: Reply with quote
Clutch cable gets hot in stop start traffic and lengthens slightly. This makes getting neutral a bit of a bugger, adjust the lever to it's proper amount of play when the engine is hot.
XT1200Z and a DR350 in bits
UnspeedySam
PostPosted: 21:45 - 17 Apr 2010    Post subject: Reply with quote
Went for a little ride about an hour ago and it's all back to normal now.
yen_powell
PostPosted: 23:17 - 17 Apr 2010    Post subject: Reply with quote
Cos it all cooled down again.
TUG
PostPosted: 23:32 - 17 Apr 2010    Post subject: Reply with quote
I wouldnt imagine it would by too much unless the freeplay litterally takes the piss. Adjust if no cure then the plates may or may not be the problem.
Haz ER-5, innit!
PostPosted: 11:18 - 18 Apr 2010    Post subject: Reply with quote
Why did you go through London? Definately the Wrong way, I used to go to pompey on my RXS.
Go over the Dartford bridge then turn off on the A225, I can't rememeber the exact route but it involved the A264/A272, it is a nice little run and much better than going through London.
27cows
PostPosted: 11:37 - 18 Apr 2010    Post subject: Reply with quote
It's not the cable or the plates that causes the RXS neutral issue. It's the selector drum detent bearing spring - it needs to be slightly shorted (less pressure on the bearing) if you do lots of stop start riding in hot weather. This does mean it's easy to go through neutral when trying to find it when the motor isn't red hot, though.
UnspeedySam
PostPosted: 13:32 - 18 Apr 2010    Post subject: Reply with quote
The idea of going over the dartford bridge scared me a little bit. But central london now scares me a lot more so I'll definitely be taking that route in the future.
neil.
PostPosted: 13:42 - 18 Apr 2010    Post subject: Reply with quote
Ahhh the Dartford Bridge... Done it on the 125, really struggles to get 40-45mph on the incline. I swear I could feel the bike's pain. Laughing
UnspeedySam
PostPosted: 13:48 - 18 Apr 2010    Post subject: Reply with quote
It's not so much the speed that worries me. I know the bikes capabilities after using just about every kind of road (except motorways) yesterday. Even got the bike to 70 down some hills Smile It's just the large number of HGVs that use that bridge and if one doesn't see me I'm stuffed...
27cows
PostPosted: 16:25 - 18 Apr 2010    Post subject: Reply with quote
I've always found major roads (particularly the M25) more scary than central London, which is just one huge jam. The traffic doesn't really move fast enough to do you any serious damage, so long as you keep your wits about you and don't try to take on cabs or buses Shocked Laughing
One road I've always loved and hated in equal measure is the notorious Jubilee Way. Great on summer days with a following breeze, but fucking terrifying in bad weather with a couple of massive trucks bearing down on you Shocked
The last post was made 15 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 72.14 Kb
