Honda XR125 keep dying.........
j1mster
PostPosted: 14:54 - 19 Apr 2010    Post subject: Honda XR125 keep dying......... Reply with quote
Hi all,
purchased a bike last November, 20 years since I had one so got to go through all the tests etc, thought this bike might suit being not the quickest for now. The problem is this:
Honda XR125 L-4
3 month old battery, Bike engine has started to die, exhaust goes pop (backfire?), engine cuts out all together, battery almost completely dead wont restart bike, starter just clicks quickly.
A jump start from a car solves the problem immediately but keeps happening at irregular intervals
Has anybody got any ideas for a total newb?
Any help would be appreciated Thumbs Up
Cheers,
Jim
GSF650S, XR125L-4, CG125
homo sapiens non urinat in ventum
kingsknight
PostPosted: 18:02 - 25 Apr 2010    Post subject: Reply with quote
how many miles has the bike done? sounds to me like it still could be the battery dying! maybe the bike isnt charging the battery?
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
j1mster
PostPosted: 00:27 - 26 Apr 2010    Post subject: Reply with quote
Hi,
Bike has done approx 13K,
battery has done approx, 400 miles max.
I was thinking possibly an alternator issue, but no real clue tbh.
nightshaddow
PostPosted: 17:13 - 26 Apr 2010    Post subject: Reply with quote
possibly a charging problem check the voltage while engine running on tick over and while being revved, if the voltage remains at 12.5 volts or less while being revved it charging problem, at around 4000rpm should be showing 13.5 - 14.5 volts, if this is the case your battery almost certainly duff
skatefreak
PostPosted: 17:26 - 26 Apr 2010    Post subject: Reply with quote
Hey,
If you dont have a multimeter to check the voltage i'd suggest checking the bikes lights with the engine off and then starting the bike and revving the engine to see if the lights get brighter/dimmer , this will let you know if the altenator is doing its job or not.
Clicking suggests there isnt enough power in the battery to get the starter going though.
You do mention that the engine itself dies and this i would have to say is very strange indeed, as far as i'm aware the bikes battery is not involved with the running of the engine (Asside the starter of course).
Can anyone confirm if this bike relies on the battery for the spark or not?
I suspect this could be a clue for something other than the battery...
Am sure someone will chime in to help further.
Keep us updated though.
Best regards
-Jvr
Tank19Josh
PostPosted: 18:35 - 26 Apr 2010    Post subject: Reply with quote
alryt m8, i have a Honda XR125L
my bike battery died a couple of months ago, completely cut out ... i think my battery had more miles on it ...
I had to jump start it home!!
The Fix : 14hour charge, sorted it out ...
Smile hope this helps???
Josh Middle Finger
Honda Xr125
**-Pain is TEMPORARY ... Pride last's FOREVER-**
DrDonnyBrago
PostPosted: 19:16 - 26 Apr 2010    Post subject: Reply with quote
Josh Middle Finger
hahaha was the Middle Finger really required? Very Happy
Tank19Josh
PostPosted: 19:19 - 26 Apr 2010    Post subject: Reply with quote
Lol ...
im a rebel you see Smile
Josh Middle Finger
Honda Xr125
j1mster
PostPosted: 14:02 - 05 May 2010    Post subject: Reply with quote
Hi all,
sorry for the time to reply, but I finally managed to get hold of a voltmeter.
I rode my bike yesterday for about 20 miles or so then it happened again. Approximately 5-10 engine misfires with gradually dropping revs, then complete cut-out with no power left at all, not even enough to light up the neutral light.
Got my wife to bring the car and connect the jump leads and the bike starts immediately. Left charging for a minute then disconnected, put panels back on bike then after about a minute cuts out again.
Reconnect jump leads, leave for 5 mins charging, got home (about a mile or so). Turned bike off, tried to start again, no charge just quick clicking from what I presume is the starter.
That was about 7pm. I went to cover my bike at 1am and tried to start it, hey presto, it's going again! So I got hold of a voltmeter and this is what happened today:
At rest with no ignition the voltmeter displayed 11.76v
At initial tick-over (quite slowish) voltmeter displayed 10.93v but was dropping by .01v every second.
Left running for 2 mins or so and voltmeter then displayed 6.90v still dropping by .01v but now much quicker until a few seconds later, the bike cut out again.
10 minutes later, the voltmeter now displays 11.14v. As soon as I turn the ignition on, the voltage drops like a stone and there is not enough power to turn over the starter.
I hope this gives you enough information to give me some possibilities as to what may be the problem.
Cheers.
nightshaddow
PostPosted: 17:45 - 05 May 2010    Post subject: Reply with quote
this to me shows a problem with the charging, it is draining power but not replacing it, i would say it prob a regulator prob. did you test the voltage putting on any revs?
https://cgi.ebay.co.uk/HONDA-XR-125-REGULATOR-RECTIFIER-/280482861045?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item414e14cff5
couple of them on eBay, check for other responses first too, other things can cause the same symptoms i belive
umberto
PostPosted: 18:14 - 05 May 2010    Post subject: hi Reply with quote
hi
i didnt read the thread but im %99 sure that its the generator the woodruff key is either broken or breaking take the cover opposite the clutch cover off and put the bike into gear and try turning the engine by hand, if it turns the crank and wheel then in neutral with the cover off try starting it, sometimes ud have to hold the starting pinion(the gear that turns) with a socket i would advise to get help from a friend to hold it in or turn the bike on while u hold it, after it starts turn it off straight away and see if its wobbley, if it is then the woodruff key is broken. get a 15-17 mm socket put the bike into 5 gear hold break with a friend and undo the bolt holding the generator on and check the damage, for ur sake i hope im wrong...
nightshaddow
PostPosted: 18:29 - 05 May 2010    Post subject: Reply with quote
i would not think that personally but it is an option, i wouldent say it the battery as that is recharging when left so to speak, though the battery will need charging properly(good overnight charge)
umberto
PostPosted: 18:48 - 05 May 2010    Post subject: Reply with quote
ok but u said that it backfires and cuts out, thats either a really really bad battery or a doggy alternator, ive said the woodruff key cause it happened to me on my rs125 its broke i didnt replace it thinking it was something else and now ive had to repace the crank on it as when it broke it munched on the crank and generator.
nightshaddow
PostPosted: 20:43 - 05 May 2010    Post subject: Reply with quote
back fire could be that the fuel is flowing to much to fire properly cause of the failing electrics, the final spark ignites whats inside the cylinder and also what is in the exhaust header, i wouldent worry too much straight off the bat, work through methodicaly, we pretty much rulled out the battery though the strain will take its toll if not sorted soon,
fact is battery is not charging so cheapest and easyest option first replace reg/rec. run the volt test again, if you read 12.5 volt or more on tickover Thumbs Up in not we work through step by step,
agreed riding and putting strain on the motor not a wise idea at this point but would say unlikly to be a failed woodruff key
j1mster
PostPosted: 16:21 - 11 May 2010    Post subject: Reply with quote
Hi all,
thanks for all the advice, here is the latest update:
I bought a reg/rec off fleabay (£25ish from Ireland) and fit it today. Whilst I was disconnecting the old one, I also noticed some corroded joints within the connector blocks so replaced them at the same time.
I started the bike up with no problem (after realising I hadn't turned the fuel back on Embarassed ) and the voltage now reads as:
at idle, it dances a little around 13.10v +/- .02-3v
at revs it goes up to 14v+ and with heavy revs up to 14.3v+
Seems to have sorted this one out but can anybody verify that the voltage is doing what it should please?
Many thanks for all your help so far Thumbs Up Thumbs Up
nightshaddow
PostPosted: 16:30 - 11 May 2010    Post subject: Reply with quote
i can verify that the voltage is correct you have a 12v battery that now has voltage on tickover that is not draining that
the main reason for no beliving you had another problem was there was no report of any problems with your running and charging seemed to sort it out,
i suppose the lesson is work through the problem step by step till the conclusion is reached
good to see you back on the road Thumbs Up my work here is done Twisted Evil
Paxovasa
PostPosted: 16:32 - 11 May 2010    Post subject: Reply with quote
The readings are fine and sound right.
j1mster
PostPosted: 16:34 - 11 May 2010    Post subject: Reply with quote
Thanks for that nightshaddow Thumbs Up
I'm hoping that my bike is going to run correctly now, I've almost been scared to take it out as there was no real warning as to when it would cut-out.
The only thing I now have to do is replace a leaking fork seal Mad
Jim
j1mster
PostPosted: 16:35 - 11 May 2010    Post subject: Reply with quote
Thanks to you also Paxovasa Thumbs Up
prawny1
PostPosted: 17:58 - 11 May 2010    Post subject: Reply with quote
The backfiring was from the ignition system voltage dropping too low creating an intermittent spark.
hellkat wrote:
The Tot
PostPosted: 02:47 - 13 May 2010    Post subject: Reply with quote
I had a XR125L a while back (2004-2005) and I can recollect there being a recall being issued to certain frame numbers. It was SOMETHING related to the ignition system which would periodically cause the bike to cut out. I don't have the details personally, but I would BEST check since if yours is an L4, I can only assume that it was part of the affected batch. I would best check any recall history.
https://www.hoc.org.uk/help/
There should be one for the XR125 in there.
Arrow Concern : ENGINE MAY STALL
Arrow Description : On certain machines, due to an incorrect specification of the wire core material used, and the possible incorrect routing of the wiring harness, there is a possibility of poor durability which can cause an open circuit. Should this occur, the engine could stall, and the lighting system become inoperative.
Arrow Remedial Action : Potentially affected machines will be recalled and a countermeasure wiring harness fitted.
Arrow Vehicle Id : 9C2JD19A03R200006 to 9CJD19A03R201686
Never argue with autism
j1mster
PostPosted: 19:36 - 14 May 2010    Post subject: Reply with quote
Thanks for that "The Tot",
I do indeed have an L-4 and my VIN number is within the list, however I have checked with them and got this reply:
"According to our records there is no outstanding work to be carried out on your motorcycle."
Well worth checking though, just in case Thumbs Up
There is a gap of 5 years, 261 days between these two posts...
singhxr125
PostPosted: 14:26 - 30 Jan 2016    Post subject: Reply with quote
j1mster wrote:
Hi all,
Sorry to resurrect this thread again but i'm having the same problem with my XR125. How did you replace the rectifier where is it located?
any help appreciated
regards
The last post was made 10 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 133.3 Kb
