NTL Broadband & routers
Sparks!
Sir Tart-a-lot
PostPosted: 08:16 - 09 Jul 2004    Post subject: NTL Broadband & routers Reply with quote
Just bought a router and a 2nd PC but need to network them.
Router goes with the NTL modem in the living room and will plug straight into my main computer (cable already exists). To plug in 2nd PC I'm going to need a 20 M cable which I am making up myself but it's just been brought to my attention that I may need a crossover cable rather than a normal CAT5E standard networking cable.
Any ideas?
Ian (GPX)
PostPosted: 08:22 - 09 Jul 2004    Post subject: Reply with quote
Nope, you need a standard cable for the second PC.
The router - modem is also a standard cable (or should be).
I have Blueyonder broadband here and use a Motorola Modem (from Blueyonder) and a Linksys SR81 router, all the leads used here are standard, not one is a crossover cable.
Sparks!
Sir Tart-a-lot
PostPosted: 08:26 - 09 Jul 2004    Post subject: Reply with quote
Hi, that's what I thought, but someone at work seems to think NTL is different (I work for an electrical contractors) - I just wanted some definete confirmation that they are standard cables.
I am inclined to believe you mate as that's what I think too, but need 100% confirmation otherwise I'll have a 20 meter network cable with no use for Laughing
Thumbs Up thanks for advice.
silentmemory
PostPosted: 09:03 - 09 Jul 2004    Post subject: Reply with quote
Shouldn't matter, I think most routers nowadays work with both types of cable. A crossover might actually be more use, since you could use it to link the PCs directly in future, or an xbox or something. Some routers have one ethernet port sharing the uplink port, meaning the socket nearest the one where you plug in the modem will be a crossover, while the other three could be straight patch cable jobbies.
R1stu
Shrek!
PostPosted: 09:55 - 09 Jul 2004    Post subject: Reply with quote
Check the back of the digibox! Most new NTL boxes have a built in crossover as well as routers.
So SW is all you would need. Look on the back of the digi box and see if there is an x on the ethernet port.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Mr Pants!
I Karma
PostPosted: 10:19 - 09 Jul 2004    Post subject: Reply with quote
I have NTL and a router with 3 PC's all on standard cables.
No need for crossover.
Cool
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
silentmemory
PostPosted: 10:35 - 09 Jul 2004    Post subject: Reply with quote
Cool
Unless he has a router which requires crossovers Rolling Eyes
Zero-G
PostPosted: 11:46 - 09 Jul 2004    Post subject: Reply with quote
You shouldn't need a crossover cable. They are mainly used for connecting 2 pc's directly to each other or connecting 2 routers/hubs together.
Milo
PostPosted: 12:05 - 09 Jul 2004    Post subject: Reply with quote
Your main modem...is it USB or ethernet?
I've got a modem/router with 4 port switch - makes life so much easier! Smile
Shaft drives rule. Razz
Sparks!
Sir Tart-a-lot
PostPosted: 12:07 - 09 Jul 2004    Post subject: Reply with quote
The main modem is ethernet but has a ethernet > USB convertor. My net is run from the usb (unwillingly) as I can't get the bastard thing to change over, I have the wrong disc I think, going to borrow my mates NTL disc when I install the router etc so that I can get the net working on my main pc with the ethernet instead of usb!
Milo
PostPosted: 12:17 - 09 Jul 2004    Post subject: Reply with quote
You shouldn't need any software to control the modem/router.
Should be a case of typing in it's IP address and it'll take you to it's config page.
Demonic69
The Pink Rhino
PostPosted: 19:55 - 09 Jul 2004    Post subject: Reply with quote
Most ports on routers and NIC's are auto MDI/MDIX anyways so there's rarely a need for a x-over cable.
You may need to log onto NTL and register the MAC address of the router as it's connecting via ethernet and not USB. You can probably register up to five so get on with it on USB then register it, then change it over. As said the software will be on the router, just use the IP addy, something like 192.168.1.1 most likely. The MAC addy will either be written on it, be in the software or be changeable in the router settings.
Back on a Blade. Just feels so right.
tgabber
PostPosted: 20:22 - 09 Jul 2004    Post subject: Reply with quote
I can confirm that this is necessary with NTL as they don't use username/password authorisation.
(at least in London, NTL bought up lots of different cable companies around the country so it's possible that different procedures apply in different places)
"It's all about dislocating expectation"
Kawasaki KMX125 -> Aprilia RS125 -> Kawasaki ZZR600
Milo
PostPosted: 09:41 - 11 Jul 2004    Post subject: Reply with quote
I've never heard of needing to register the MAC address. There's no reason for your ISP to know that info - plus do modem's even have a MAC address - I thought that was just a ethernet thing.
william
PostPosted: 09:56 - 11 Jul 2004    Post subject: Reply with quote
Hope you have got it set up from all the advice given.
It is nice to hear of at least one Company doing a modem with an ethernet port.
I ended up ditching my "free" USB modem and buying a modem, router and wireless access point.
William
Demonic69
The Pink Rhino
PostPosted: 11:16 - 11 Jul 2004    Post subject: Reply with quote
No Milo, the Router or NIC has the MAC address and cable connections need that info to prove it's you connecting as there's no dialing at all.
The last post was made 21 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 88.47 Kb
