| psalliss |
 psalliss L Plate Warrior
| Kaph |
 Kaph Nitrous Nuisance
| psalliss |
| TUG |
 TUG World Chat Champion
| psalliss |
 Posted: 21:10 - 20 Apr 2010 Post subject: |
Your dealer is full of it. The Hayabusa clutch is one of the strongest put into a bike, can handle 4x the power of a stock engine and usually last well past 50,000 miles on the original clutch.
The cure for this is not difficult, al you need to do is clean the slave cylinder:
You need to remove the sprocket cover on the left hand side. Remove the left fairing for access and un-bolt the cover. You should be able to get it off without removing the gear change arm (just) but if you can't then put a mark on it with tip-ex or a permanent marker so it goes back on the same spline to save you lining it up later.
Once you have the bolts out pull the cover off. You'll see a steel rod in front of the sprocket poking out of the engine. It'll be covered in black gungy horribleness. Pull it out, clean it up, put it back in again. A small amount of oil might dribble out.
The slave cylinder is mounted on the cover and it'll now be hanging by the hydraulic hose. Look inside the cover and you'll find the same crap all over that, and covering the piston. Clean everything insode the cover with de-greaser and a 2" paintbrush that you've cut the bristles down to 15mm long. Now pump out the piston using the clutch lever using something to catch the fluid that escapes (an up-turned dustbin lid is good). Clean the piston thoroughly and then you can replace it in the cylinder. Push it all the way home.
Now you can replace everything and bleed the clutch. ____________________ a.k.a 'Geri'
| andys675 |
 andys675 World Chat Champion
| DrDonnyBrago |
 Posted: 22:09 - 20 Apr 2010 Post subject: |
Unless you drag race it then your dealer is a twat, try as above first sounds very plausible  |
| temeluchus |
| psalliss |
| chris-red |
| psalliss |
 Posted: 17:15 - 22 Apr 2010 Post subject: |
Fair enough price I think, the rear brake can be a bugger to sort out if those pins are seized.
Well done in getting it sorted  ____________________ a.k.a 'Geri'
| Vanishing Point |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 Vanishing Point L Plate Warrior
The last post was made 16 years, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
