BIOS access problem
R34lN1nj4
PostPosted: 22:09 - 21 Apr 2010    Post subject: BIOS access problem Reply with quote
I am trying to upgrade my XP to W7, which I have to do by wiping and reinstalling windows.
In order to do that I need to be able to boot from the CD, which is sitting in my drive and is trying to boot, as on the start up is asks me to press any key to boot from cd.
However, it wont take inputs from my keyboard cos it's a USB board and doesnt power up until after the set up.
I have tried plugging in an older type keyboard with the round plug socket at the back, and not only does it ignore that, it also fails to boot at all - hanging after the 'press any key to boot from disk' message
Obviously I need some way of accessing the BIOS, but cant do it before XP starts, is there any other way of accessing it, it forcing it to enter BIOS any other way?
Frost
PostPosted: 02:46 - 22 Apr 2010    Post subject: Reply with quote
Plug in the older keyboard, make sure it goes into the blue socket. You will often have to restart before it detects it. During loading press delete repeatedly until you get to BIOS. Then set the boot order to be CD first. To be honest it sounds like it is already CD first so you can probably leave BIOS alone. Just try the old keyboard in the correct socket and a restart.
R34lN1nj4
PostPosted: 08:16 - 22 Apr 2010    Post subject: Reply with quote
OK, tried that, and to no avail.
As I mentioned the older keyboard gets ignored also, but causes the PC to hang just before where it would normally bring up the windows logo and the 'loading' type bar.
Keyboards (all of them!) work fine if I leave it to boot properly and then use them, but obviously it is too late by then, cos then I cant access the BIOS or boot from CD.
One question though...
The older keyboard I am using for this has a purple, round connection on it and not a blue one. The only blue connector I can see is a short oblong one, similar to an old joystick port, is this the one i should be connected to?
Also...
If I was to set the jumpers on my main HD to slave and set the jumper on the CD to master, would that make it boot from CD automatically?
Pernig
PostPosted: 09:09 - 22 Apr 2010    Post subject: Reply with quote
Easier solution:
Boot into XP as normal, then run the Windows 7 setup CD. Select a 'custom' install on the same drive where XP is already installed. Setup will move the files in the Windows folder to 'Windows.old', and will reboot automatically after the first steps, allowing you to continue with Windows 7 setup as normal.
H100 Breaking for spares
sweetleaf
PostPosted: 13:36 - 22 Apr 2010    Post subject: Reply with quote
Keyboard is purple, VGA (monitor) is blue.
My USB keyboard is fine for getting into the BIOS, but as that's sod all help to you at the moment, I would go with Pernig's suggestion - we often have to do this with Windows 7 due to problems booting from the CD.
R34lN1nj4
PostPosted: 09:20 - 23 Apr 2010    Post subject: Reply with quote
Pernig wrote:
Easier solution:
Yeah, thats what I've done now, the problem I was having was I was trying to upgrade not only from XP to W7, but 32bit XP to 64bit W7 and to do that you have to boot from the disk rather than installing from the OS.
Still can't access the BIOS though, which is a little worrying to me.
Stowelly
PostPosted: 09:27 - 23 Apr 2010    Post subject: Reply with quote
try resetting the bios, by removing the cmos battery from the motherboard for a few seconds..... most bios have a option to enable usb keyboards for boot, not too sure whether this should be on by default. but wont hurt to try i guess
The last post was made 16 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.45 - MySQL Queries: 13 - Page Size: 52.87 Kb
