Stuck Bearing.
chrisio
PostPosted: 15:54 - 24 Apr 2010    Post subject: Stuck Bearing. Reply with quote
OK, I knaffed up and now Im stuck, I am replacing the bearings in my rear wheel and 1 side is in ok along with the spacer tube, but its the other side that is causing me problems, Its a recessed bearing and I needed a drift to seat it in fully and the only thing that I had that fitted was the old bearing which I successfully used as a drift - but then I realised what I did and have now jammed that bearing HARD against the new bearing which is seated fully in place.
In my attempts at removing said bearing I have managed to remove the inner race and balls but the outer race is stuck fast and nothing I seem to do will shift it.
I have tried dremmle it but the bearing just laughed at it. My normal grinder made mince meat of the inner race but I darent use it on the outer race as I may kill the wheel...
Any suggestions....
Chris (who feels a fool!)
cloric_tzr
PostPosted: 16:20 - 24 Apr 2010    Post subject: Re: Stuck Bearing. Reply with quote
Any suggestions....
lol not to worry you could try heating the wheel up to expand the metal around it get a biiig bowel or som suitable container and submers it in boiling water for a few mins. use plenty of grease to.
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
dodgydog
PostPosted: 16:52 - 24 Apr 2010    Post subject: Reply with quote
as an alternative to heating the wheel, you could try freezing the bearing race. Get some plumbers freeze spray (wickes sell it) it's easier to concentrate the spray, I used to use it a lot to put bearings in.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
PostPosted: 17:11 - 24 Apr 2010    Post subject: Reply with quote
Have you got a welder? Run a bead of weld around the inside of the race and when it cools it will fall out. Put a disc of something non-weldable like ally or brass in there to protect the new bearing.
chrisio
PostPosted: 17:27 - 24 Apr 2010    Post subject: Reply with quote
I have tried the freeze spray and that didnt work - the problem is I cant get any purchase on it and I cant get behind it because of its hard against the new bearing which is hard against the seat and the spreader tube.
Think welding a bead around it might be my best bet but Im worried about distroying the new powdercoating!!!!
Rollocks
PostPosted: 19:36 - 24 Apr 2010    Post subject: Reply with quote
Rollocks
Right then, do you still have the balls, the inner race and a slide-hammer?
If you do, fit the inner race to the slide hammer somehow - you could improvise something if you don't have a hammer. Now grease-up the outer race and put half the balls into it all next to each other. Now place the inner race into place where it would be and use a pick or thin screwdriver to spread out the ball bearings evenly around the bearing. Your inner race should now be captured inside the outer one by the balls and you can use the slide hammer to drift it out.
TUG
PostPosted: 19:47 - 24 Apr 2010    Post subject: Reply with quote
You need 2 things, heat, lots off it, and WD-40 or some kind of penetration oil.
Haz ER-5, innit!
dodgydog
PostPosted: 17:16 - 25 Apr 2010    Post subject: Reply with quote
Rollocks
you need a good bearing puller, it should be able to seat on the chamfered lip under the bearing, whereabouts are you? I have set of pullers, slide hammer.
Dog
Bikeless
PostPosted: 17:21 - 25 Apr 2010    Post subject: Reply with quote
For the cost of a new bearing i would drift the new and old bearing out together and fit a new one properly.
steven_191
PostPosted: 17:52 - 25 Apr 2010    Post subject: Reply with quote
CHR15 wrote:
get a dremel on it.
ive dremeled outer races before, and then split them with a cold chisel, you just have to be careful and take your time.
+1. That's how I used to do them. Once it's cracked it drops in and out no troubleO
dodgydog
PostPosted: 09:16 - 26 Apr 2010    Post subject: Reply with quote
Sometimes the obvious answer is the last one I think of.
Surprised Surprised Surprised
Dog
PostPosted: 11:07 - 26 Apr 2010    Post subject: Reply with quote
Next time drift it in with a socket Thumbs Up
dodgydog
PostPosted: 16:38 - 26 Apr 2010    Post subject: Reply with quote
On the outer race.
Not like I did, on the inner race, (a very long time ago )
everyone has to learn.
Embarassed
Dog
The last post was made 15 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 79.57 Kb
