crm125 water leak!
maully
PostPosted: 13:31 - 25 Apr 2010    Post subject: crm125 water leak! Reply with quote
brought a crm125 today bit tatty but runs pretty well but gets hot pretty quick without thrashing it. its currently got a rear sprocket thats tops it out at 60ish so bin doing 45-50ish at 7-8k revs to keep the revs down a bit to keep it cooler. had no coolant in it it so topped it up, got home from mates about 4 miles away, and half the water had gone and seemed to be leaking. i noticed the coolant top up seal is a bit shagged so maybe leaking under pressure from there? any ideas or help would be great
cheers maully
TUG
PostPosted: 13:36 - 25 Apr 2010    Post subject: Reply with quote
My Gilera DNA50 leaked from the water pump seals. But as with any leak it could be anywhere, you need to remove as much panels and things in your view as possible, then top it up again and run it.
If your using just water on its own it will boil and give you the impression of a leak.
Buy some coolant after finding your leak pre-mixed or mix yourself, its pretty easy.
Haz ER-5, innit!
maully
PostPosted: 13:44 - 25 Apr 2010    Post subject: Reply with quote
sound will run some proper collant through it and see what happens, if it still happens after that will take it to the local bike garage at town there always good blokes and pretty happy to help Smile
cagiva gezzer
PostPosted: 14:09 - 25 Apr 2010    Post subject: Reply with quote
2-strokes can leak into the gearbox. Check the oil levels.
maully
PostPosted: 15:32 - 25 Apr 2010    Post subject: Reply with quote
the oil levels are fine Smile will get my mates trade discount at halfrauds and give the bike some coolant tomorrow
maully
PostPosted: 16:45 - 25 Apr 2010    Post subject: Reply with quote
jus to make sure is it normal for the water to boil after a 5-10 min ride? or does it sound like there could be a more serious problem?
TUG
PostPosted: 16:47 - 25 Apr 2010    Post subject: Reply with quote
I'm not sure, but i'd look for a leak, be careful where you take your bike to be fixed. Just a warning.
Haz ER-5, innit!
alains
PostPosted: 12:42 - 26 Apr 2010    Post subject: Reply with quote
it's more likely a head gasket gone
maully
PostPosted: 13:34 - 26 Apr 2010    Post subject: Reply with quote
the excessive wihte smoke would also confirm thats its the head gasket, will get it striped down by the weekend Smile
The last post was made 15 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 57.51 Kb
