new d.b screen vibrating
AFleck82
PostPosted: 16:33 - 25 Apr 2010    Post subject: new d.b screen vibrating Reply with quote
Hi, i fitted a powerbronze double b. screen a few weeks back and with no lack of trying i cannot seem to solve the buzzing noise it makes around town at about 20-30 or so . When i pick up speed it stops but when i down change the the buzzing comes back in waves.
Is this some thing i can fix or are the powerbronze screens known tobe a pile of no good?
Any advice would be great, manythanks.
Past bikes - 94 DT125, NRG 50/70, 00/Runner 125/172, 03DNA 125/210, 03DNA 180/210,
04 Varadero, 00 ZX6R J2, 04SV650 S, 07 Fazer600 S2,
94 ZZR 600, 07 R6, 04 R1 carbon.
Handsome
PostPosted: 16:48 - 25 Apr 2010    Post subject: Reply with quote
Only thing I can think of is it's not seated right...
TUG
PostPosted: 16:49 - 25 Apr 2010    Post subject: Reply with quote
Get a popped innertube from a push bike and cut yourself some strips of that and place it inbetween the screen and nose cone. Are you possitive its the screen and not something you've left loose, sorry have to ask.
Haz ER-5, innit!
AFleck82
PostPosted: 17:51 - 25 Apr 2010    Post subject: Reply with quote
possitive its the screen as when i put the standard screen back on the buzzing stopped, Shocked
TUG
PostPosted: 17:56 - 25 Apr 2010    Post subject: Reply with quote
It will be the thickness of the new screen causing problems, like i said, popped bike innertube hidden under the fairing.
Haz ER-5, innit!
AFleck82
PostPosted: 18:26 - 25 Apr 2010    Post subject: Reply with quote
i'll give it a try and see if it makes a difference, many thanks Thumbs Up
TUG
PostPosted: 18:34 - 25 Apr 2010    Post subject: Reply with quote
It will help, its just hiding the tube that im worried about, just try and make it look as neat as possible. Thumbs Up
Let me know if it worked.
Haz ER-5, innit!
Gazdaman
I did a trackday!!!
PostPosted: 19:03 - 25 Apr 2010    Post subject: Reply with quote
Some screen bolts have got rubber 'cones' on them to give it a bit of damping.
It's just be the screen finds its resonating frequency and goes off on one.
Change the bolts, or find another way to dampen the screen (like with a bit of inner tube) and it'll be fine.
Gaz
Gazdaman
I did a trackday!!!
PostPosted: 19:05 - 25 Apr 2010    Post subject: Reply with quote
Sorry, double post.
https://media.ebaumsworld.com/picture/schango/DoublePost.png
Gaz
Handsome
PostPosted: 19:13 - 25 Apr 2010    Post subject: Reply with quote
Gaz...
Why didn't you just delete the second post before someone else posted ?...
Just curious Laughing ...
Gazdaman
I did a trackday!!!
PostPosted: 19:26 - 25 Apr 2010    Post subject: Reply with quote
I didn't know I could!!
I thought it was like the curse of BCF that you couldn't delete posts.
Oh well, it's preserved forever now.
Gaz
Handsome
PostPosted: 19:35 - 25 Apr 2010    Post subject: Reply with quote
Yep, so long as you do it before someone else posts you can delete it... Thumbs Up
DrDonnyBrago
PostPosted: 19:56 - 25 Apr 2010    Post subject: Reply with quote
You can use a thin smear of silicone bathroom sealant on the lip of the screen - it dampens out the vibrations so it will STFU Thumbs Up
TUG
PostPosted: 00:17 - 26 Apr 2010    Post subject: Reply with quote
I wouldn't... Silicone is for sealing. Lets just use it for what it was ment for in regards to vehicles.
Haz ER-5, innit!
DrDonnyBrago
PostPosted: 08:31 - 26 Apr 2010    Post subject: Reply with quote
It's fine on vehicles, have seen it used loads of times to stop fairings from squeaking. Obviously you need to let it dry first or you wont be able to remove the screen afterwards.
prawny1
PostPosted: 12:13 - 26 Apr 2010    Post subject: Reply with quote
Rubber washers between the screen and the fairing should cure the vibration, you should be abled to get something suitable from a hardware shop or plumbing merchants.
MarkJ
PostPosted: 12:49 - 26 Apr 2010    Post subject: Reply with quote
I wouldn't go using an innertube then, as they're for use in tyres Wink
Handsome
PostPosted: 12:54 - 26 Apr 2010    Post subject: Reply with quote
I best get rid of my ten rolls of Duct/Duck tape then, as I have no Ducks to tape to any Ducting... Neutral
TUG
PostPosted: 18:22 - 26 Apr 2010    Post subject: Reply with quote
You know what i mean guys, fuck off... Laughing
The reason i say this is because once people start to use it, they use it for stupid reasons, like siliconing their reg plates on... seen it done on 3 bikes now.
Haz ER-5, innit!
AFleck82
PostPosted: 20:40 - 28 Apr 2010    Post subject: Reply with quote
Screen went back on today and the news is good, no more vibration or buzzing sound running through it.
it took a bit of trial n error in the end the inner tube slices kept coming out and the noise would come back so i cut 1 one of those v2 visor sponges down as much as poss and wedged it in underneath either side of the screen. Thumbs Up
https://p1.bikepics.com/pics/2010%5C04%5C28%5Cbikepics-1963145-800.jpg
https://p1.bikepics.com/pics/2010%5C04%5C28%5Cbikepics-1963146-800.jpg
TUG
PostPosted: 21:23 - 28 Apr 2010    Post subject: Reply with quote
Told you it woild work, and i cant see it so looks good to me, like i said i was worried about if you could see it or not, things like that bug me. Thumbs Up Very Happy
Haz ER-5, innit!
The last post was made 15 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 106.96 Kb
