Suzuki GP125 problem
P.
PostPosted: 22:54 - 24 Apr 2010    Post subject: Suzuki GP125 problem Reply with quote
Hey
asking on behalf of my friend who bought a non runner Rolling Eyes
Basically its a GP125, its got an overfuelling problem.
How is this solved simply?
P.
PostPosted: 15:08 - 25 Apr 2010    Post subject: Reply with quote
Anyone...before this gets pushed down further lol Razz
stirlinggaz
PostPosted: 15:36 - 25 Apr 2010    Post subject: Reply with quote
hi,
i dont remember much about the gp, but i presume it has the usual mikuni vm type carb?
if it is, there fairly easy to dis-assemble.
just remove the carb from the bike.
tip it upside down (dont do this while smoking, as petrol will now be pouring out of the carb onto your trousers,lol)
remove the carb bowl.
you will seee the float assembly & a couple of jets.
the floats hinge on a pivot pin, remove the pin with needle nose pliers.(you might need to tap it out with a suitable punch)
the float arm can now be lifted off/out GENTLY!!! as there is a small "needle valve" hanging off the tang of the float arm.
where this needle valve sits can become clogged up, especially if the bike has been sitting for a while.(all it takes is a couple of grains of sand)
give this orifice & the jets a good spray with carb cleaner & blow through with compressed air.
might also be worthwhile checking the float height while your there.
the floast assembly works like a toilet cystern,lol
ie once the bowl fills up to a certain level, the floats..erm...float & cut off the fuel.
im hoping this is what you meant my "overfueling"?
cheers,
GAZ
edit : just looked on cmsnl & it does indeed look like a vm carb https://www.cmsnl.com/suzuki-gp125-1983-d_model13391/partslist/FIG-05.html
P.
PostPosted: 17:08 - 25 Apr 2010    Post subject: Reply with quote
awesome will bookmark this and use it when the bike is within my reach Thumbs Up Karma
Nemo
PostPosted: 20:57 - 30 Apr 2010    Post subject: Reply with quote
Just to let you know we got this bike running in the end, was just the spark plug and a slight tweek in the carb in the end, nothing major, good deal me thinks Thumbs Up
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
The last post was made 15 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 44.12 Kb
