SUPERBYKE POWERBAND 50 57 PLATE
ozzyd1979
PostPosted: 22:01 - 25 Apr 2010    Post subject: SUPERBYKE POWERBAND 50 57 PLATE Reply with quote
JUST BOUGHT THIS AND GOT IT STRARTED BUT KEEPS CUTTING OU THE THING CLEANED CARB FRESH FUEL CLEANED SPARK PLUG STILL NOTHING JUST KEEPS CUTTIN OUT AFTER COUPL OF MINS
OZZYD1979
ian789
PostPosted: 22:02 - 25 Apr 2010    Post subject: Reply with quote
This some sort of joke?
ozzyd1979
PostPosted: 22:07 - 25 Apr 2010    Post subject: Reply with quote
NAH IT AY ITS ALL I COULD AFFORD AND ITS ONLY FOR WORK
OZZYD1979
ian789
PostPosted: 22:08 - 25 Apr 2010    Post subject: Reply with quote
What colours the powerband?
ozzyd1979
PostPosted: 22:10 - 25 Apr 2010    Post subject: Reply with quote
EH WHAT U MEAN
OZZYD1979
Walloper
PostPosted: 22:13 - 25 Apr 2010    Post subject: Reply with quote
If it starts well then I would guess the sparking bits are sound.
If it peters out after a few minutes then the fuel mixture is wrong.
The mixture screw could have been given a 'golden handful' before the sale as the previous owner (Was it a pikey?) knows the thing wont start without tunz of fuel.
Does it keep running if you open the throttle? If so then you have a carburettor issue
Does it have enough poke when you ride it?
Not enuf info in your initial post.....
ozzyd1979
PostPosted: 22:15 - 25 Apr 2010    Post subject: Reply with quote
REVS UP FINE RIDES AROUND BUT JUST CUTS OUT LIKE ITS FLOODING NOISE OR COLD NOISE
OZZYD1979
Walloper
PostPosted: 22:17 - 25 Apr 2010    Post subject: Reply with quote
"FLOODING NOISE OR COLD NOISE"
Am away tae ma bed....
ozzyd1979
PostPosted: 22:18 - 25 Apr 2010    Post subject: Reply with quote
I NO THE EXHAUST GASKETS GONE BUT THAT SHOULD CAUSE THIS
OZZYD1979
ozzyd1979
PostPosted: 22:19 - 25 Apr 2010    Post subject: Reply with quote
LOSES POWER
OZZYD1979
-Savage-
PostPosted: 22:24 - 25 Apr 2010    Post subject: Reply with quote
Shocked
ozzyd1979
PostPosted: 22:29 - 25 Apr 2010    Post subject: Reply with quote
just want me bike sorted see what all u peeps think that all
OZZYD1979
m0l0t0v
PostPosted: 22:32 - 25 Apr 2010    Post subject: Reply with quote
P.
PostPosted: 22:43 - 25 Apr 2010    Post subject: Reply with quote
check the carb settings, make sure its not got a leak around the carb/engine and sort that exhaust gasket out.
Try the mixture as said above.
Also you should speak in sentences, clear ones as other users here cant decode short dodgy sentences Wink
Walloper
PostPosted: 22:48 - 25 Apr 2010    Post subject: Reply with quote
This phukerz more spoof than troof.....
Joined today born yesterday.
Bed time now......
nightshaddow
PostPosted: 11:50 - 26 Apr 2010    Post subject: Reply with quote
i take it you have the rbp, i know the bike well as i have one under a different name,
if it this bike then it almost cirtainly is a carb issue, and tbh with the standard carb on it it will take you a month of sundays to set up the fuel air mix.
easyest and best way to remedy this is to put ya hand in ya pocket and buy this
https://www.mypurerush.com/product-info.php?proID=122
i fitted a couple of these to a couple of bikes for people now and they run like a dream though you will need a new throttle cable to.
and also as a warning dont get the 30mm one the engine cant handle it
also these things dont come with an exhaust gasket i got mine from new and it never had one
DrDonnyBrago
PostPosted: 14:11 - 26 Apr 2010    Post subject: Reply with quote
£18 for a carb Shocked Thumbs Up
ozzyd1979
PostPosted: 22:20 - 26 Apr 2010    Post subject: Reply with quote
also noticed worn inlet manifold just ordered one though ill have to try that
OZZYD1979
ozzyd1979
PostPosted: 05:17 - 28 Apr 2010    Post subject: PARTS Reply with quote
new parts come yesterday will be trying it tonight as need to know if still gonna do i or it
yeah guys does look like previous owner was messing with it so it down to me to figure it out if not its either send it in garage or i might have to get rid off it already
thank you all to have helped out
OZZYD1979
The last post was made 15 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 102.28 Kb
